Cayenne Coding - The Ultimate Guide & Discussion
you cannot change the power it gets heated, but you should check the threshold temperatures coded.
I believe upper threshold for heating it up is around 40 degrees centigrade. Beyond that, it stops heating any further.
If that value is set too low, steering wheel will not heat up properly. I‘ve seen 3 retrofits in a Macan and in all cases the defaults values were the same and ok. Not sure you changed some of the threshold values?
Temp sensor sits at the lower part of the wheel, close to the area where the switch resides, just FYI.
(EDIT): Here's the coding values you may want to check:
(Not sure how your launch might translate those, engineering FAP always throws out those values in German)
Zieltemperatur Lenkradheizung 35 °C (read as "target temperature")
Einschaltschwelle Lenkradheizung -12.0 °C (read as "lower threshold" from where it starts to heat)
Ausschaltschwelle Lenkradheizung 40.0 °C (read as "upper threshold", beyond that temp it stops heating any further")
Zeit Kurzzeitmemory Lenkradheizung 180 s (second) (read as "short term memory steering heating" - I have no clue what it steers. possibly 3 minutes memory in case you stop the engine and restart or something like that)
FWIW my wife says it’s heating her hands enough, so maybe I’ll just count my blessings and leave it alone
I would be surprised of any deviation, but you never know... maybe there are cases in cars which came w/o heated steering where values are just not coded correctly ...
siberian
I just did a bunch of coding. I wanted to do two more items that I'm pretty sure I saw somewhere but can't remember:
1. Turn off the "passenger airbag off" warning light in the overhead console.
2. Change the speed at which the rear view camera turns off. Currently the camera comes on in reverse, and then stays on when in drive until about 11mph - I'd like to change that to like 5mph.
If anyone remembers where these are, I'd appreciate it!
The second item was also reported by someone - try the Coding 992 threads. HTH
siberian
Select module for door; rear left or right > Code/brush Hiding > Brush Hidden/Modified > Control Unit Coding > Control unit coding_0 > Control unit coding -- Vehicle coding 2 -- Sunblind
At this point you can set the feature from Active to Inactive, then Write and it disables the rear passenger sun blind. I hit the window button and the shade never moved but the window did. Set back to Active and resumed normal operation of the sunblind with window switch.
Cheers!
I dont want to buy the seats without a guarantee it will work.
I will update this table of contents so it will be easier as this thread grows. Please PM me if I forget to add yours. MODS, feel free to edit.
- Turning off the seatbelt chime and warning (Park Assist Bug)
- Change the number of flashes for one touch
- Mirror auto retract and center vents colder
- Windows up/down via your keyfob
- Use LED bulbs in sidemarker
- Battery coding
- Turn off the tailgate sound when opening/closing
- Auto retract the rear window shades when in reverse
- Use LED bulbs for the license plate lights
- Teardrop wipe for your wipers
- Cornering light coding options
- Adjust ringtone volume
- Set footwell lights to use LEDs
- Disable Start/Stop Permanently ( not working)
- Change the boost pressure value limit (if you're running a custom tune)
- Enable hidden instrument display settings and change cayenne model logo
- Enable Pre Heating and Cooling for hybrid models
- Change at what speed when the doors auto lock (It's located in front-end electronics)
- Change when services are due
- Top off engine oil to max level
- Top off engine oil to max level (simplified)
- Check when transfer case fluid was last changed.
- Enable fog lights as welcoming light
- 958.2 Heated Steering wheel retrofit
- Boost and Accelerometer in MFD
- Battery Coding using iCarSoft
- PCM Function Activation (Map Update Disc)
- Parking Brake Adjustment. Easypeasy with the x431
List of people that can help you code. If you want to help other members, PM me and I'll add you to the list below.
- @9000RPM - Princeton, NJ. PM for details. Only available on Sundays.
- @sterod - Great Toronto Area, Canada. PM for details.
- @volcanogts - Rindge, NH. PM for details.
All these codings are done with a Launch X431 V+. I'm not promoting this company. People are asking if other launch x431 models that are cheaper can do it, I don't know. If you decide to try it, let us know here as well and I'll update the info.
- - bfly reported that the Launch x431 Diagun IV has the coding feature.
- - Launch x431 PROS Mini is confirmed to work
- - darrenbt reported that his iCarScan running Porsche 23.20 DOES NOT have the coding feature. Confirmed that iCarScan does not have coding.
::WARNING::WARNING::WARNING::WARNING::WARNING::
You can read about that one time when I actually did hit the "Restore Default Setting" and completely zeroed out my parking brake module here:
https://rennlist.com/forums/cayenne-...ing-brake.html
I'm also including a link to the thread I made for my 2014 base model that includes all its default coding values for each module. Might be a good backup reference.
https://rennlist.com/forums/cayenne-...ding-list.html
Also in post #2, there's a photo of a selection showing "Back Up All Coding", it doesn't work. It fails and kicks you back to the main screen. So please keep a record of changes you make by taking screenshots.
Now the final disclaimer: DO NOT hold me responsible if anything goes wrong!
