Sponsored By:
Sponsored By:
Cayenne Coding - The Ultimate Guide & Discussion
Old 03-16-2022, 07:49 AM
  #1381
Lyolik
3rd Gear
Lyolik's Avatar
Originally Posted by cayo
in recent times I have become familiar with the piwis2 and some retrofits on my cayenne 958 with pcm 4.0. I managed to retrofit the stopwatch with function in the instrument cluster, then I installed LED headlights and added PDLS plus function, and finally I coded the speed limit info.
Speed limit info
Speed limit info
Speed limit info
thank you in advance
Hello!
Can you please explain how activate speed limit step by step?
Thanks in advance
Old 03-16-2022, 09:26 AM
  #1382
cayo
cayo's Avatar
Originally Posted by Lyolik
Hello!
Thanks in advance
it is very easy , but front camera on the windshield is required.
First edit vehicle order >>> in principal menù select F7 and after choose “manteniance vehicle data” and go on until you find the option code >>> scroll until you find the item 9Q0 (which means without recognition of road signs) and click on the drop-down menu, you will see that it will be possible to choose alternatively only option 9Q6 (which means with recognition road signs), then go ahead and accept the replacement. With this step you have updated the vehicle order. Then code with the automatic coding function the following control units:
BCM FRONT
GATEWAY
FRONT CAMERA
KOMBI INSTRUMENT
PCM
It is very important to code 5 control units all together.
if you need other help you are welcome!
execuse me for bad english
The following 3 users liked this post by cayo:
JUN6817 (05-20-2023), Lyolik (03-16-2022), sac02 (03-18-2022)
Old 03-16-2022, 09:31 AM
  #1383
cayo
cayo's Avatar
Originally Posted by rnlst_log
MU High/PCM--Coding programming-Manual Coding-Kodiewer:byte_17_Skinnig: Select skin
hi friend!
a big thanks to you
on porsche I am very very poor ... I know that it is not the right forum, but I can offer great support on the whole bmw range
——EDIT——
tried today but unfortunately do not work
siberian (03-16-2022)
Old 03-16-2022, 09:43 AM
  #1384
cayo
cayo's Avatar
Default 360 degrees real top view retrofit
Today arrived first item
Old 03-16-2022, 09:03 PM
  #1385
F SANE IL
F SANE IL's Avatar
Originally Posted by TMC.
I used a place in Russia, my Sport Chrono was $50, this place wants $100
Too bad internet is kinda cut off in RU now.
The following 2 users liked this post by F SANE IL:
dollarlongnecks (03-16-2022), TMC. (03-17-2022)
Old 03-17-2022, 05:33 AM
  #1386
cayo
cayo's Avatar
Is possible to encode wireless apple carplay on my car that have wired factory apple carplay?
Old 03-17-2022, 11:58 AM
  #1387
siberian
siberian's Avatar
Received 2,304 Likes on 1,370 Posts
@cayo yes, I didn't get anywhere with the skins either. I can't remember if the number of skins was dependent on the number of FOBs but whatever the case was I never got any skin other than default to work...
siberian
Old 03-17-2022, 07:13 PM
  #1388
rainer
rainer's Avatar
no
Old 03-18-2022, 12:54 AM
  #1389
dollarlongnecks
dollarlongnecks's Avatar
You can't code it with a coding tool like this, but they sell little adapter boxed that will turn your regular Carplay into a wireless Carplay. Do a google search for wireless carplay adapter and look at the results to see what is available.
Old 03-20-2022, 05:12 AM
  #1390
cayo
cayo's Avatar
siberian
i am not sure , but it could be a pcm firmaware update to a newer version which allow to change skin via encoding.
Old 03-21-2022, 07:13 AM
  #1391
sami_cayenne
sami_cayenne's Avatar
Hello!
Thanks in advance
Thanks for the steps
Would you be able to share part no of the front camera for the speed limit function and is wiring there for the front camera (on windscreen/behind rear view mirror) ??
TIA
Old 03-21-2022, 11:58 AM
  #1392
siberian
siberian's Avatar
BTW when you mention "front camera" it's part and parcel of the 360 surround view right?
siberian
Old 03-25-2022, 08:23 AM
  #1393
cathalferris
cathalferris's Avatar
My first Cayenne coding question. I've a decade's familiarity with the Ross-Tech software for VAG cars, but the Cayenne is different enough to warrant asking the subject matter experts
I've received my iCarsoft POR v3 this morning, and attached to the car, checking for various things. I did find a few odd codes that I cleared after saving them, but one code is reappearing even after clearing:
C11004 1/1
Active
Programming
I'm not seeing anything useful online for a C11004 code apart from this link to a Russian owner's site
I will be replacing the rear hatch locking mechanism in the next week or two whenever it arrives, and I wonder if the error state of the current mechanism may be a cause of the error code.
​​​​​​​Would anyone here have anything to add?
Old 03-28-2022, 03:59 PM
  #1394
cayo
cayo's Avatar
siberian
i mean camera on windshield.
Old 03-28-2022, 04:01 PM
  #1395
siberian
siberian's Avatar
What build code is that?
siberian
Quick Reply: Cayenne Coding - The Ultimate Guide & Discussion
