Cayenne Coding - The Ultimate Guide & Discussion
#1246
But will it work on 7?
siberian
siberian
#1248
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Hey y'all, loved this thread and went out and got myself a Launch x431 v+ pro whatever version exactly it is (bigger tablet, like 5000 connectors that are probably useless).
I'm located in Austin TX and happy to help out any other members that want to play with coding, just give me a jingle. Or message, that probably works better than jingling me. I'm on the south side/West Oak hill and also have an automotive lift for any really fun projects that I can at least spectate (that is, if you don't want me wrenching on anything).
For my first fail, I tweaked coding something on my 2016 SEH that caused it to refuse to go into reverse. And switching to the "surround" view just killed off the backup camera entirely (reverting these flags fixed everything). I've also got a german brother in law that I might send some screenshots to for translation help if/when I get stuck trying to figure out what the kuhlerjalousie flag means.
Still trying to figure out the comfort open/close on the pano roof from key fob. Windows work, but now the roof one-touch open/close is no longer working :shrug:
#1249
jbehren (10-09-2021)
#1250
Update on my ordeal with Launch.
After speaking with seller, they had Launch issue Porsche version 23.86 software. I haven't updated yet, but read another person who upgraded and this version is same as 23.82, so the German menu should be fixed now. I'll confirm tomorrow when I'm able to update and connect to the CS.
#1251
Any news as to 992 support or is 23.86 only labels add-on (German/English) stuff?
siberian
siberian
#1252
Update: tested for language fix, still a problem.
siberian (10-13-2021)
#1253
I hold my phone over the tablet and use google lens to translate ... Works fairly well, though I still haven't figured out why my stupid pano roof no longer has one-touch opening/closing, even after trying to re-train the position sensors several times.
If anyone has a 958.2 with pano roof and an x431, can you check the default settings for the roof (there's an MD1 and MD2 section, it's really confusing to me). I believe under front or rear-end electronics.
#1254
It's like having a Porsche and towing it with an F-150 every time you want you want to use the Porsche. Where's the pleasure in that?
#1255
Dear All,
i have updated the latest version on my launch X431 V+, it is the 25.8 version. seems it is showing the instrument cluster modules in German with some Chinese caracters in betrween, did anyone face the same problem ?
Regards,
Regards,
#1256
If you can revert back down to prior version, do it before it's too late. Doesn't seem like they want to fix this issue.
#1257
Yes, that's the reason I sent mine back to seller until they fix this problem. Apparently a new version was to be released in November. I guess you got the new version.
#1259
23.80 and 23.82 seem to be in English. I had tested the Diagun, ProMini and V+. All same problem and had to return all 3. Provided downgraded software didn't help when Launch added it to my account.
#1260
