Cayenne Coding - The Ultimate Guide & Discussion
#1366
Just for reference, can anyone post a picture of the PIWIS screen where you would enter such a hex code for what specific function?
TIA
siberian
TIA
siberian
#1367
Greg,
here we go. It's an older Piwis2 screenshot, but basically the same. Can be found under Maintenance & Repair / Activations (I know you can do the translation yourself easily .. LoL..)..
There's 2 functions in the steering wheel where you need an activation code: Heated Steering Wheel and Cruise Control.
At least for heated steering wheel you cannot buy it at the dealer, Porsche simply does not sell this, so the only way is the grey market for this code.
This is from a former retrofit of a heated steering wheel.
You can find a couple of functions apart from steering wheel under PCM. They vary depending if it is a PCM 3.1, PCM 4 etc. Some of it can be bought at the dealer (like CarPlay), some not (like different Region conversion in PCM4, Android Auto), so there's more than 1 way in some cases.
#1368
Herzlichen Dank Rainer!
I'd never come across this. I doubt though that selecting a color for the tach and sport chrono requires such a code, so I was hoping there'd be a way to change the wavelength. If indeed there isn't, then it proves why at least on the 2020 Macan, the red tach looks washed out pink. They just shine a white LED onto a red face plate.
siberian
siberian
#1369
Greg,
the only ECUs where I came across these activation codes so far were in steering wheel and PCM. No codes in dash cluster yet - but this might be different in recent model years (e.g. Taycan surely has tons of functions which will need some kind of activation/certificate to be enabled, most likely with online/OTA distribution)
#1370
BTW are these codes VIN dependent? Meaning if you get or decipher a code I couldn't use it on my car due to different VIN numbers, or is it just one code activates?
siberian
siberian
#1372
Thanx Rainer.
siberian
siberian
#1373
Coding
in recent times I have become familiar with the piwis2 and some retrofits on my cayenne 958 with pcm 4.0. I managed to retrofit the stopwatch with function in the instrument cluster, then I installed LED headlights and added PDLS plus function, and finally I coded the speed limit info.
Old watch
New chrono
Chrono in cluster
New led headlights
New led headlights
New led drl
Speed limit info
Speed limit info
Speed limit info
Now I have seen that there is the possibility to change the background of the menu with icons ... does anyone know the value to change in pcm 4.0?
i have this background:
and i mean this background:
thank you in advance
Old watch
New chrono
Chrono in cluster
New led headlights
New led headlights
New led drl
Speed limit info
Speed limit info
Speed limit info
#1374
Out of interest, what enables the speed limit info?
siberian
siberian
#1375
#1376
Sweet, what option was the front camera?
siberian
siberian
#1377
i think there is no option only for front camera.
i am a little confused …. there is options for park assist only , for park assist + rear view camera , rear view camera only and park assist + surround view.
look images:
Now i have rear and front camera but not original…. Is connected to china ecu camera adapter…but i am not satisfied….
my next project is original surround view … stay tuned
look images:
#1378
Keep us posted!
siberian
siberian
#1380
