Cayenne Coding - The Ultimate Guide & Discussion
#1456
Hi Guys,
I am thinking of buying the Launch x-431 V or V+ but I am wondering if any of you guys tried the Level Control / PASM special functions?
My plan is to change my front air suspension struts but I need to be able to calibrate / bleed the strut / system.
Much appreciated!
Much appreciated!
#1457
Oh that’s great! Would you mind telling me which version you have of X431? Still don’t really understand the difference between all the models. Is that also supported by the PROS MINI?
#1458
It took me a long time to figure out the true difference between all the x431.
The large screen version has more visibility, like charts if live data. The mini just gives you values for live data streams.
As far as coding, they all have same selections.
#1459
Keep us posted.
#1460
The system does not care about the serial number or part number, it only has to match a numbering sequence, it only cares about the AH rating so it can modify the charging accordingly.
I coded my battery successfully with icarsoft I just entered in the default brand in icarsoft the proper porsche part number and put in the old serial number with one digit changed and it coded no problems.
I think people are over analysing the details needed. It’s just code not Porsche magic
Great stuff! Hoping for the best! I'm going to try same this week for a 105ah agm varta in my 2016s 4.2d with icarsoft. Fingers crossed!
#1462
Very interesting. After being scared of this happening for 2 yrs, i finally swapped the oem battery with a varta h15 105ah (exact oem copy for s diesel 2016). Only to get stuck on coding step. i'm trying to exactly like yu on icarsoft por v 2 v50 sw but to no avail. i have tried many combinations described here but nothing seems to work. the tool reads gateway info of battery ageing etc all ok that tells me it is communicating well. one thing im thinking maybe its not taking a reset as i has the vehicle on external supply and i read somewhere that registration is only allowed in cayenne if battery disconnection is detected, not sure how much its true.
i plan to finally disconnect ground and then try registering again if nothing works.
fwiw, i also tried panamera and 911 options in the bms section as some with macans had success this way but it doest work since 911 fields do not have more than 99ah options and hence 2 digits fields for ah rating.
let me know if you see what im doing wrong.
#1463
Activation heated steering wheel
here we go. It's an older Piwis2 screenshot, but basically the same. Can be found under Maintenance & Repair / Activations (I know you can do the translation yourself easily .. LoL..)..
There's 2 functions in the steering wheel where you need an activation code: Heated Steering Wheel and Cruise Control.
At least for heated steering wheel you cannot buy it at the dealer, Porsche simply does not sell this, so the only way is the grey market for this code.
This is from a former retrofit of a heated steering wheel.
Would tryouts disclose where to look for a code to activate a heated steering wheel?
pm open
Thanks in advance!
[/QUOTE]
pm open
Thanks in advance!
[/QUOTE]
#1465
I have canbus lights but they still stay on so I need to code them.
#1467
Are you still using POCOM? I'm somewhat used to VAGCOM so it's it similar to tha?
Was able to code functions with PoCOM. Successfully enabled the boost pressure in the cluster, mirror fold on door lock (in Instrument Cluster), and open & close sunroof/windows via key fob. I was not able to access the PCM fully, but a quick e-mail to PoCOM should get their enginerds to look into the issue and fix it.
Still experimenting but at 50% less than the X431, I'm sold. Granted things are labeled a little differently than what the X431 lists them as, and there's no search function yet available, but PoCOM is constantly updating their software. Since I've purchased it there have been 5 updates in the past two months.
#1468
#1470
