Sponsored By:
Sponsored By:
Cayenne Coding - The Ultimate Guide & Discussion
Old 09-12-2019, 12:51 AM
  #61
9000RPM
9000RPM's Avatar
Originally Posted by gabylonfive
Interesting on the BMW coding front. Were the feature coding options about on the same level as what you’re seeing on the Cayenne? If this thing will do most of the same stuff as my esys and NCsexpert setup that will make life a whole lot easier.
We coded a F32. Found a coding guide and just followed it. I let my friend play with it mostly as it was his car. He was happy with it.
Old 09-12-2019, 07:51 AM
  #62
hotrod2448
hotrod2448's Avatar
Not exactly coding but, have you seen anything in this software for resetting engine and trans adaptations?
Old 09-12-2019, 09:47 AM
  #63
Valvefloat991
Valvefloat991's Avatar
Originally Posted by twodollardoug
I did some digging on the launch X431 V+. Apparently it works for a good number of makes and models of cars. So you didn't have to pay extra for the Porsche software. Did you just download everything you could for it? I'm sorry for the dumb questions but this is the first I've heard of the X431 V +. When I bought my cayenne I got the durametric enthusiast and it sucks. Too glitchy. Then I got the iCarsoft POR-II. It's better, but no coding and not very easy to use. So close to 600 bucks in tools that I'm not very happy with.
Where can one find a list of the vehicles compatible with this thing? In addition to my 958, I have a 2017 991.2 that could use it and my 2014 BMW S1000R motorcycle also needs something to reset its service indicator.
Old 09-12-2019, 09:48 AM
  #64
sterod
sterod's Avatar
Look at my post #53
Old 09-12-2019, 09:59 AM
  #65
bfly
bfly's Avatar
Originally Posted by 9000RPM
On my '14, the module is listed and the options are in there. I can't confirm for an '11 though.
No clue what "HKL" stands for. Probably a German abbreviation.
Radio remote control functions and Driver interior button functions options were listed a little bit further down on the list:
It was active for both "one-touch", but inactive for the regular "touch"
same thing for "driver interior button" section:
Thanks for the research. I don't think I have the Comfort Close option on my '11. I'll check again when I get home and report back.
Old 09-12-2019, 03:53 PM
  #66
Eskimo1
Eskimo1's Avatar
SOOOOO many features I've wished to be able to modify...and a few that I'd change just because! Next time I'm planning on getting to that part of NJ, I'm sending you a PM!
Old 09-12-2019, 05:58 PM
  #67
RallyJon
Weathergirl
RallyJon's Avatar
This looks really awesome, but it would be great to see a) what can this do that PIWIS II can't (other than non-Porsches of course) and b) is there anything that can ONLY be done with a PIWIS II. That's pretty crucial information for someone like me ready to plunk down for a tool like this.
subaru335i (05-18-2020)
Old 09-12-2019, 06:04 PM
  #68
9000RPM
9000RPM's Avatar
The window up/down was also under comfort entry but isn't enabled. So it might not be a requirement.
Old 09-12-2019, 06:05 PM
  #69
9000RPM
9000RPM's Avatar
No problem. I can only meet up on Sundays though.
Yes, I'm curious as well
Eskimo1 (09-19-2019)
Old 09-12-2019, 06:13 PM
  #70
gabylonfive
gabylonfive's Avatar
Same here. A couple of things off the top of my head that I know for sure typically require a piwis are ehybrid clutch flush/adaptations and activating pdk fill-mode. I will report back on whether this can do the hybrid clutch flush shortly and have a buddy with a 991 that I can try the pdk fill-mode on. I know there’s also an air suspension setting in piwis that allows you to modify the normal ride height on some air-equipped p-cars, I can test that on my cayenne too. I’d also like to shut off the external sound generator on my ehybrid for true stealth mode (another piwis only option .)
If it does all of those things then I see no reason really to get a piwis over one of these unless you have a doip car (2018+ I believe) which this won’t work on. OP has already confirmed that the coding abilities are there (it even looks similar to the piwis coding/adaptation menu structures, albeit in English) so that in itself is a huge value.
Old 09-12-2019, 10:44 PM
  #71
9000RPM
9000RPM's Avatar
Originally Posted by sterod
Ok, the value I am trying to change in English would be "Max Boost Pressure / Boost Pressure Sport" and it would likely be set to 1.2 BAR from the factory. The reason I am trying to change this is because with the COBB Stage 1 map, it raises the boost pressure to 1.6 BAR but the MFD maxxes out at 1.2 unless it is re-coded.
Played around with it some more tonight...I know it doesn't support the 2018s but maybe in the near future?
Enable hidden menus in the instrument display (boost pressure, acceleration, deceleration, door relock timer, disable start/stop, change the cayenne model logo
Choice of BAR or PSI.
I set it to BLANK after this.
Old 09-12-2019, 10:57 PM
  #72
9000RPM
9000RPM's Avatar
I'll report back on this. In post #48, the remote control button function for "activation of touch closing function" is listed but I thought it was set to active. Just tested with the keyfob and it doesn't close. I'll need to test it further.
So not sure if the module is not programmable or the Launch software has a bug. This is the first time that I've encountered a write code failed when I tried to change a setting.
But in the default programming, "Activation of touch closing function" for the radio remote control is set to active. I tried holding it down (this opens the trunk), I tried double press and holding on the second press (this didn't do anything.
Old 09-12-2019, 11:02 PM
  #73
9000RPM
9000RPM's Avatar
I wonder how the x431 V+ does with Initializing new modules. For instance, I changed my steering wheel from a sport steering wheel to a multi function steering wheel and had to replace my clock spring. Then I had to take the cayenne to my local race shop that has a bootleg piwis 2 to get the car to recognize the new clock spring and wheel. I am curious if the X431 V+ could have done it?
See anything in here?
duffman04 (04-01-2021)
Old 09-12-2019, 11:04 PM
  #74
9000RPM
9000RPM's Avatar
I've been getting home late lately so haven't had time to test the headlight sensitivity. I have a dashmat to combat the luxor beige glare so it's really bad for me.
Old 09-12-2019, 11:10 PM
  #75
twodollardoug
twodollardoug's Avatar
Looks like it is the very first entry. Does your car have the multi function steering wheel or sport wheel?
Quick Reply: Cayenne Coding - The Ultimate Guide & Discussion
