Cayenne Coding - The Ultimate Guide & Discussion
#1321
I don't think those versions translate exactly between Launch and actual/clone PIWIS, and as far as I know the PIWIS II had an 18.x something as the last available update... The highest I can find mentioned online in a quick search is v18.15
niaditmas (01-20-2022)
#1323
#1324
Will you piwis work on a 2014 s hybird
Thanks. I will dig thru manual coding settings.looks like Launch tool and PIWIS differ on how they expose those settings.Also looks like PIWIS has some preferences under special category of "Customer set preferences" line - which was the case for Comfor Open. I bet comfort close is under manual coding. By the way - if anybody needs access to PIWIS2 in chicago area - you are welcome to reach out and use mine. At your own risk of course. Either bring your own laptop with PIWIS software installed or you can use my full set up.
#1325
has anyone been able to code auto hold on level surface? in the psm ecu there are options for auto hold and they are active yet it only works up hill or down hill. 2015+ models come this way automatically. i assume this is just a coding change.
#1326
#1327
it's not really over looked.. it's semi active. The abs module will hold pressure on incline or decline
#1328
delete
#1329
#1331
Anyone know of a way to disable Auto Start/Stop on a 2019 Cayenne (Base 3.0T) without the Chrono package? The list on the first page states that disabling this feature is not working... Thanks in advance.
#1332
Don't have a 2019 here to test, but try the following:
1. Select all ECUs in Piwis, use "V" Mode (Aftersales) before attempting anything in "E" mode
2. Select Manual Coding - for earlier models at least it shows the option for Start/Stop to set to "Last Mode".
3. Select "coding" - Piwis codes the correct ECUs automatically
4. Get into VO, look for S/S and select the same. Update VO and store that value
If S/S is not shown under step 2 for any ECU, try step 4 first and then select "Automatic Coding" for all ECUs.
BTW - we're in the 958 (= Gen 2) section here, and Start/Stop not possible statement on the first page here is wrong. Thus, most stuff discussed here is not relevant for you as you should likely have a Gen 3 Cayenne?!
JUN6817 (05-12-2023)
#1333
I retrofitted a heated wheel into a 2016 base cayenne, which is working (got the code from code-porsche). However, for whatever reason, start/stop has been deactivated (get a message when starting the car) and unfortunately cruise control has stopped working as well. I wonder if I messed something up while coding in the heated wheel a couple months ago. I did purchase a new (not used) clockspring with the heating element for the heated wheel retrofit. Wondering if anyone has any insight - do I need to get a code for cruise control too? Is there a way to code in the VIN to the clockspring? Thanks!
FWIW I have a C11006 error in the steering wheel electronics module which I take to mean that coding is not correct.
Edit: I have the Launch x431 pro-s for coding.
#1334
Wish I could find a way to permanently disable *** on my 992.
As to heated steering wheel issues, I retrofitted mine into my Touareg and indeed in addition to the heated steering wheel (from Poland) one does need not only a new clock spring but ensure that the clock spring actually has the two pin connectors to enable it and then code in VAG-COM. As to cruise control, could it be that you forgot to connect some of the wires in the steering wheel? There are several and it's easy to miss. I don't believe there is a way or need to link the VIN to the clockspring.
Here are some possible hints:
https://mhhauto.com/Thread-Porsche-P...ce-mode-SOLVED
siberian
siberian
