Ok guys maybe you can help me. I have just spent the last couple hours looking through modules and I can't find what I'm looking for. I'm looking to turn on the the steering wheel menu in the multi function display. I swapped my sport steering wheel for a multifunction steering wheel a while back and had the race shop in town code the new clock spring so everything is working. But I believe you guys that have factory multi function steering wheels have a menu option for it.
I don't have the menu option and I'm thinking it has to be in there somewhere. Has anyone come acrossed it yet?
Using PIWIS2 a while back, I recall seeing it in either front end electronics or the gateway. These menus here are more/less same as PUWIS2
I can confirm that all the ECU Coding works on the 2018 Macan S using the LAUNCH X431+ DIAGUN IV. If anyone in the GTA (Greater Toronto Area, Canada) wants some coding done, PM me.
glad you’re seeing the same functionality I saw last week. Enjoy!!
BTW...were you able to change the boost pressure??
Yes, I changed it to 1.6 BAR (about 24PSI) which is higher than the 22PSI the Cobb Stage 1 OTS map targets so I will always get an accurate reading.
The only thing I wanted to find a way to remove through coding, that sadly doesn't appear to exist, is the "5 Strongest Signal FM Stations" that the PCM adds in addition to your 15 stored presets. I hate this "feature" and wish it could be disabled.
I finally have one to add. The automatic door lock is set to 5 kh. I set mine to 10 kh. Every time I back my car down the driveway to pick up my wife by our front door the auto lock would lock the doors. Then I have to fumble around to find the unlock button. Not cool especially in the rain. This did the trick. It is in front end electronics, general parameter.
so no go on the trailer module with this tool? I have a module installed, but its not working properly. 9000rpm, if you are able to do stuff with the towing, I may stop by princeton (on a sunday ) if you wouldn't mind.
Just an update... 10 kh wasn't enough for us so I bumped it up to 15.
In the "Rear Lid" module, we can disable the beep beep beep sound when we open the tailgate.
Ig
But the problem that I'm having is I need to experiment and figure out what these abbreviations mean...
edit...FFB, ST, FIT and HKIT were all default to active. I set them all to inactive and no more beeping sound when closing.
9000RPM, did you set VIT to inactive also? What about your first screen shot, did you do anything with warning signal when close by button pressing and when open by button pressing?
Thanks, added link to first post.
We have the factory tow package on our Cayenne. We have never used it. I get an error message when I select the trailer module. I'm thinking maybe the trailer harness needs to be plugged in in order to get into the module settings?
I thought this was useful. The shades will auto retract if they are in the up position when you shift into reverse.
Edit: This feature is not working. The rear passenger sun shades do not go down when I'm in reverse. Need to investigate further.
Were you able to find anything out about this feature? When I change mine to yes, and write code, it says that it was written but remains no. I did find it in the instrument cluster and have it in the menu, but it's working.
I only coded in the rear end electronics module. You saying this option is also located in the instrument cluster module and I need to code it there as well?
