Cayenne Coding - The Ultimate Guide & Discussion
#1276
I would guess right now that the tool could code out that sunshade option, then dig in and disconnect the shade motor possibly. Or just disconnecting it may work. I would have to hook up my car to find the option coding and verify, but from previous experience it can probably do that.
#1277
^ jonUFO2 if you could do that it would be hugely appreciated. I have access to a X431 but am not familiar with it, and this no rear windows is driving me nuts. Cheers
#1279
Is it possible to disable the rear sunshade using the X431 tool? I just purchased a 2011 Cayenne base and the rear windows are both inoperable because of problems with the sun shade. I would be quite happy to have an operational window and no sunshade, which I would probably never use anyway. Thanks!
I actually thought on buying the door panels that have the shades and install on my car when I first got it. Still kinda curious on doing that. Don't know if there's wiring in the door. But I suspect there might be.
Here you go.
US $16.14 5%OFF | iron for 2011-17 Porsche Cayenne rear door window glass curtain shade motor internal gear repair kit
https://a.aliexpress.com/_mNpFTLY
Also, check the DIY section. I thought I saw someone did the repair.
But to your question....yes, probably possible to disable them. Only issue is that if you buy a new x431 right now, it will have the messed up language issue. No clue if they will ever fix it.
imalek (12-07-2021)
#1280
Maybe you can DM me your serial number and I can tell them that you have 23.82 and I want a copy of what yours has?
#1282
#1283
How do you point it to access that file rather than the mothership? I see still no support for 992...
siberian
siberian
#1284
#1285
I still have the English version. But it seems different distributors have different versions out. Some claim their version supports 992s while the one I got it from clearly doesn't. I only have about a month of the free update left so I'm hoping there will be a last update that will include the 992
siberian
siberian
#1286
so i have an old laptop that i could install any operating system on - what exactly would i need to be able to code this car - software and hardware - would that be better and/or cheaper than buying any of these other devices - i would mostly be turning off service codes but if i could get into some of the other coding and diagnosing and it didn't cost too much i might like that better - thanks in advance
#1287
#1288
I want to upgrade my scanner for my Cayenne. I want to do oil change reset, battery replacement and be prepared for troubleshooting the subsystems.
I’ve been looking at choices like the Foxwell 680 and others.
Thanks for any recommendations you guys can offer?
#1290
