Isudar Carplay for PCM 3.1
#391
Same issue with the connection. I actually just pulled everything apart, removed the board, reinstalled the board and FFC's etc...to solve a display issue. I set everything up again and it connects just fine. That was an hour ago so I'll go back to the garage in a bit to see if the phone connects or if I have to forget the device (iPhone) and pair it up again.
CX301: BSJ1211124-1124
Software: 2.2.21
Hardware: S7.8
Board (printed on circuit): Ver 2.0 211103
Software: 2.2.21
Hardware: S7.8
#392
I didn't open the PCM again to check the board.. when I received it, I confirmed that it's the new board (as ordered) when I compare it with previous pictures posted here (new chip, etc.). The package also shows the new model number that ends in 8813WP3 vs 8013WP3.
Where can I find the latest firmware? The one in Isudar page seems to still link to 1124
RR911 (01-09-2022)
#393
Hello together,
I also installed the Isudar CarPlay mainboard (new version) and everything works great except wireless CarPlay.
I am able to connect my iPhone to the CarPlay module (just sometimes) but the connection sometimes gets lost and the music is stuttering or lagging. Sometimes wireless CarPlay is not lagging for some seconds and everything works great.
Sometimes I also get kicked out of wireless CarPlay and the music stops playing.
The antennas aren’t damaged, I already checked that.
For me it seems so be a software problem.
Does someone have an updated version for the CarPlay module or a bug fix?
#394
Hello together,
Does someone had the same issue or a software update which helped solving this issue?
#396
I am not sure why, but I can not write you a private message, maybe my account is too new?
#397
#398
perfect, thank you!
where did you get these firmwares? And did you had the same issue like I currently have?
#400
See if this link works for Isudar Firmware updates (let me know if it doesn't). I'm sharing all I have. I can continue to post in this drive as I get them or if anyone else get them...
https://drive.google.com/drive/folde...S1?usp=sharing
Use at your own risk…
#401
What did I do wrong?
This showed up and I pressed ,"Updated SOC" . After pressing the button the screen goes black, assuming it's installing files and doing its thing.
After 3min, this screen appeared. Is it done at this point? I shut the car down thinking it was done and removed the USB.
- Format USB (256 Megabyte) to FAT 32
- Downloaded the Firmware. Unzipped the folder. Copied the two file .BIN and the Other to the root.
- Left my phone in the house, far away from the car
- Went to the car, inserted the USB, went to Settings and started the update.
- After 3 min everything appeared to be updated. The new firmware showed up on an ancient looking screen.
- I turned the car off. Pulled Fuse 51.
- Restart the car, when I press 'Info' I get a black/empty screen.
#403
You should contact Kimi at kimi@isudar.com.
#404
