Isudar Carplay for PCM 3.1
#541
Not so sure man that it is killing your battery.....unless you have a defective kit, and that is possible. Many have this board running for some time now with excellent results. I agree 30 mins connect time is too long and needs to be addressed.
Any chance you have a faulty battery? As its new ? I would return it now...after depletion like what you have experienced.
#542
I also build in an automatic trunk module, which can also close the trunk again with the key, maybe that's causing the drain, I took both fuses out to see if the battery still drains tomorrow. If not I put the PCM fuse back and continue testing.i will post the result when i know if it is the pcm or the trunk :-)
AngelDutchy (01-17-2022)
#544
Can someone give me a step by step instruction for pairing an iPhone for wireless CarPlay?
I see the WiFi network. I see the Bluetooth. Once in a great while I can pair to the Bluetooth but connection is not reliable.
#546
In other words, I don’t need to go to the isudar setup page and manage the pairing there?
erase all pairings? Including pcm and other cars. Or just any previous isuadar attempts.
the ‘manual’ says to attach the usb cable to the phone and then remove it and that starts the process. I suppose I should could to 10 or something. Any other details?
on the setup pages I see support for 2.4 and 5.0 ghz does this matter
on the advanced ‘factory’ pages I see support for internal BT or external….can you elaborate on this?
#548
CarPlay Bluetooth pairing is standard procedure like in all devices. Go to Wireless CarPlay settings. Once you are done with that, future wireless connections will be via Wifi. 2.4 vs 5Ghz is your choice. But you need the latest firmware for that to work automatically. You have the latest board version so can install version 0105b.
#549
I received today the MCU Firmware update to correct steering wheel behavior, and I'm happy to report that the issue has been corrected with this new update.
This update makes the Isudar PCM3.1 platform almost perfect (4.5 stars in my view). A few lingering issues remain, that are less intrusive:
1. Calls going on-hold when pressing the steering wheel phone button (this behavior observed when phone is paired with PCM)
2. Connection time after turning car off
981BGTS (01-18-2022)
#550
So far I agree, this is definitely a good product with at least some technical support and updates.
#551
#552
AngelDutchy (01-18-2022)
#553
I received it today too, but haven’t installed it yet. But anyways great news! As for calls I’m not using pcm Bluetooth and don’t have any issues with accept / hang up buttons. I even like the sound quality of phone calls better with CarPlay. Connection time is an issue to me but in a kind of opposite way: since the module stays on for some time when I jump out of car and then get back in shortly, wireless CarPlay doesn’t connect automatically because of that and I have to manually connect again.
#555
@konkab when you are outside of CP, like using radio or CD (which I rarely do anyway, but like to have flexibility), you can’t make of receive calls (correct?), if not paired to PCM.
