What did you do to your 997 today?
Old 04-17-2021, 08:00 PM
  #11596
rtl5009
rtl5009's Avatar
What symptoms does a cracked clutch plate spring have?
rtl5009 is offline
Old 04-17-2021, 08:01 PM
  #11597
D977
D977's Avatar
Where was the cars and coffee in NJ? I know there's one next weekend.
Millers Ale House Mt. Laurel NJ has a C&C every Saturday Morning until about 10am weather pending that usually have a nice turn out.
D977 is offline
Old 04-17-2021, 08:18 PM
  #11598
Khloesdad
Khloesdad's Avatar
Curious as well.
Khloesdad is offline
Old 04-17-2021, 08:29 PM
  #11599
Snakesm13
Snakesm13's Avatar
Not 100% sure yet but I have a thread started on it. (Not sure if appropriate to post it here). But there was a lot of drivetrain noise that the seller attributed to the lightweight flywheel. One day clutch failed to disengage(possibly slave cylinder) and that’s when the tear down started. No slipping or gear disengagement symptoms, just lots of racket.
Snakesm13 is offline
Old 04-17-2021, 08:42 PM
  #11600
rtl5009
rtl5009's Avatar
Any vids of the noise?
rtl5009 is offline
Old 04-17-2021, 09:00 PM
  #11601
JAAM
JAAM's Avatar
Installed:
ECS spacers; 10 front and 15 rear
Eibach springs
Sharwerks center muffler delete
Wheel balancing
Alignment
JAAM is offline
The following 5 users liked this post by JAAM:
ABNJOE (04-22-2021), ElectricChair (04-18-2021), EMC2 (04-17-2021), kkswow12 (04-26-2021), misterdega (04-21-2021)
Old 04-17-2021, 09:13 PM
  #11602
Snakesm13
Snakesm13's Avatar
Best I got:
Hard to hear over the wind and exhaust but you might get the idea.
Old 04-18-2021, 12:45 AM
  #11603
axl886
axl886's Avatar
Pictures speak for themselves...
axl886 is offline
The following 14 users liked this post by axl886:
BHMav8r (04-21-2021), EMC2 (04-21-2021), JAAM (04-18-2021), JerryK (04-18-2021), kru911 (04-25-2021), NE1N-11 (04-21-2021), Ohio Performance (04-18-2021), Presto (04-18-2021), quickxotica (04-20-2021), Ratchet1025 (04-21-2021), Rdsawyer35 (04-24-2021), Snakesm13 (04-18-2021), tegraphile (04-24-2021), VT Blue (04-24-2021) and 9 others liked this post. (Show less...)
Old 04-20-2021, 12:31 AM
  #11604
voidopolis
voidopolis's Avatar
Plugs & coils time & a fresh oil & filter. plus time to do some spring cleaning after taking her out of storage. This is my first 911 so I was excited to get in there and do some more maintenance. Had done oil & filters and brakes/rotors before putting her away in the fall.
2009 997.2 C2S full Fabspeed exhaust setup from headers back. I did not need to remove anything except the rear wheels to do the plugs and coils. Put her up on jack stands, removed the rear tires, and just had to remove the upper heat shields. Very easy procedure. The heat shields were a bit of a challenge to move out of the way - but manageable. Definitely need the right set of swivel / wobble extensions and contorting your arm into tight spaces - but it was pretty easy. Tried to scope the cylinder walls, but my scope/cam was only able to really see the bottom of the piston. That looked clean enough - just a bit of carbon build up...
Plugs and coils - 911 / 997.2 C2S = full fabspeed exhaust
dirt, debris, nasty dirty behind the rear wheel arch liner... Definitely need to clean there in the future.
while watching a DIY video on YouTube and it suggested removing the rear wheel wells and clean behind them as they tend to collect a lot of crap. I'm REALLY glad I did that. Just looks at the amount of debris that was back there - it was moist and really compacted dirt and stones and very likely would have led to some nasty rust in the future! The wavy stuff above the sensor is all caked on dirt. Definitely strongly recommended to take those off and clean well behind them ASAP if you have not done so.
voidopolis is offline
The following 3 users liked this post by voidopolis:
EMC2 (04-21-2021), Ohio Performance (04-20-2021), VT Blue (04-24-2021)
Old 04-20-2021, 12:56 AM
  #11605
BLU997
BLU997's Avatar
@voidopolis I love the exquisite surface finish machined inside the plug recesses.
BLU997 is offline
Old 04-20-2021, 02:12 AM
  #11606
brocski
brocski's Avatar
Swapped in a new voltage regulator, new idler pulleys, new tensioner pulley, and new drive belt. Check your alternator voltage on high mile cars. My .1C2 has 146k miles and the voltage regulator was clearly failing. When idling I was getting 15.2V at the battery. New regulator is a $40 part and may prevent more expensive component failure. You can see the worn contacts on the old vs new in the image below. ...and now I can run my clear LED markers without them flickering due to the high voltage!
brocski is offline
irnnr (04-20-2021)
Old 04-20-2021, 11:43 PM
  #11607
darrenj
darrenj's Avatar
Put a ducktail on the cab.. Have been debating for awhile if I wanted to get one. Came across a used one for a good price.
darrenj is offline
The following 6 users liked this post by darrenj:
ABNJOE (04-22-2021), EMC2 (04-21-2021), IrishLegend (04-26-2021), Optionman1 (04-22-2021), Ratchet1025 (04-21-2021), Rpena3 (04-28-2021) and 1 others liked this post. (Show less...)
Old 04-21-2021, 12:18 PM
  #11608
MissileFlyer
MissileFlyer's Avatar
Default PROPER Dead Pedal Installed on my GTS
Why Porsche provided cheap OEM dead pedal I don’t know...Perhaps so they can charge $150+ for the matching unit. Thanks SunCoast. Porsche? Not so much...Get it right the first time. Rant off.
MissileFlyer is offline
Hootsama (04-21-2021)
Old 04-22-2021, 11:11 AM
  #11609
Freakhead
Freakhead's Avatar
New Michelin tires, numeric spacers (7/15) and H & R sport springs. Next up window tint.
Freakhead is offline
The following 5 users liked this post by Freakhead:
ABNJOE (04-22-2021), GTS Sully (04-22-2021), Jaws1 (04-22-2021), PacNW3 (04-22-2021), rtl5009 (04-22-2021)
Old 04-22-2021, 12:08 PM
  #11610
ABNJOE
ABNJOE's Avatar
Wink
JAAM,
Is 10mm front and 15mm rear what's necessary to fill the gaps? Are you happy with how it turned out?
ABNJOE is offline
Quick Reply: What did you do to your 997 today?
