Note to Porsche classic - 997 PCCM plus request
Old 01-20-2023, 07:28 PM
  #751
medicus
medicus's Avatar
[QUOTE=Carfan1;18583809]Here are pics. As you can see I'm using an AA wireless dongle that is stored in the cubby under the HVAC. But the cable could easily come out anywhere.
But what's in the front USB socket?
Old 01-20-2023, 07:36 PM
  #752
Carfan1
Carfan1's Avatar
A flat USB cable. https://www.monoprice.com/product?p_id=41940
Old 01-20-2023, 09:08 PM
  #753
fritzcurtis
fritzcurtis's Avatar
If you go into the map itself, touch the bottom right corner to get into settings. Go to About, next touch Content, next touch Maps. Hope your state exists. As Steve mentioned, they are listed alphabetical, and every state after New York is missing.
Old 01-20-2023, 09:14 PM
  #754
fritzcurtis
GIG. The satellite info on your gps strength is located in a section in the maps area called Usefull Info. Touch that area and the last item is GPS strength
Old 01-20-2023, 09:23 PM
  #755
fritzcurtis
Okay, this is really interesting about the maps. I took the card out and loaded it into a laptop running windows. Found some interesting stuff. The system is actually run by something called iGo. TomTom supplied the maps to them. It is an app on the iPhone that looks just like our maps in the car. Same layout. When I went into the iGo file I found a subdirectory called content. In this directory I located all the states for the map. They are all there! Each state has two files associated with it. I tried moving Texas to top and no luck. I am thinking this might be a licensing issue where they are not allowed to show states. I will share with Porsche Grapevine who is working with Classic team.
The following 2 users liked this post by fritzcurtis:
myw (01-21-2023), signde (01-21-2023)
Old 01-20-2023, 09:26 PM
  #756
fritzcurtis
I also tried renaming Texas to Alabama to fake out system. Still no luck. I’m happy to try any suggestions you guys have.
Old 01-20-2023, 10:03 PM
  #757
Summerjack
Summerjack's Avatar
Default Ordered mine today. Can't wait
Anyone have a recommendation of an installer in Los Angeles?
Old 01-20-2023, 10:35 PM
  #758
Carfan1
Carfan1's Avatar
Ask ryanla997. His installer can also add a rearview camera I believe.
Summerjack (01-20-2023)
Old 01-20-2023, 10:37 PM
  #759
onnastick
onnastick's Avatar
Please just scroll up a few posts to #732. Evolution Motorsports was already recommended.
Old 01-20-2023, 11:04 PM
  #760
ryanla997
ryanla997's Avatar
The camera installed was a redeen lip cam. I'll have to get a picture up later. It's very discrete and hardly noticeable from the back of the car. I do a lot of work on my car, but I am not skilled with electronic installations. I asked the shop owner what he did and he said it was complicated. They worked on the car for an entire day before they figured it out. He said that he had to find another pin connection for the back of the unit since it didn't have one. I realize this is probably not very helpful and can try getting more information.
The camera works perfectly. It interrupts whatever is playing on the PCCM when the car is put into reverse. Music is muted but still audible when you're reversing.
I have no white noise at all.
I have to admit, I am disappointed with the internal mic. I did a bunch of testing with the external versus internal mic. I may wind up going back to the external mic. Voice quality is quite muted.
The following 2 users liked this post by ryanla997:
myw (01-21-2023), snowtx1 (01-29-2023)
Old 01-20-2023, 11:05 PM
  #761
ryanla997
ryanla997's Avatar
Originally Posted by myw
im guessing the lines coming from the camera itself ? not from the pcm correct
Correct, the lines are from the camera.
Old 01-20-2023, 11:09 PM
  #762
ryanla997
ryanla997's Avatar
Old 01-20-2023, 11:15 PM
  #763
Summerjack
Summerjack's Avatar
thank you. Any idea what they will charge to install (labor)?
Old 01-20-2023, 11:21 PM
  #764
csmab
csmab's Avatar
Agreed. Internal mic is fine when parked. It is horrible when driving. Too much road noise. My TranzitBlu external mic was great in the car. I might see if I can splice the 4 pin connector from the included external mic to the TranzitBlu mic to see if that works.
Regards
Old 01-21-2023, 12:10 AM
  #765
G.I.G.
G.I.G.'s Avatar
Regards
Did you install the external mic and if so, were you able to compare the internal mic to the external mic while driving? My test yielded slightly better results with the internal mic, but I was parked. I'm curious if that would be consistent while driving, or if the external mic, for whatever reason, might be better. Regardless, neither the external nor the internal mic are fantastic.
Quick Reply: Note to Porsche classic - 997 PCCM plus request
