Any Rennlisters from New Zealand?
#9706
Hey John, here's the 964 I was telling you about today. Notice how good the tail lights and reflector strip is on the rear. In his thread in the 964 section "my 1991 c2..." He shows a few shots and describes how he got them looking like this.
Looking at the top of his wheels in relation to the guards looks like the stance you outlined to me today, but check out how low that makes the car!
Some nice photos you should all checkout on this blog here. Really nice photography too....
http://www.stanceworks.com/2014/02/j...s-porsche-964/
Interesting article. Lovely car. Way too slammed for our roads and youd never get any decent track camber on a car with wheels that tight in the guards. Interesting to read hes done similar to your plans. Air con fix and rebuilt the calipers. I love those drilled Adams rotors he has on that rig and if I were a 964 owner and those had a good rep Id put them on right away to reduce the issue of pads sticking with hot with brakes on etc. Some good ideas in that article...
You can run up to 7mm spacers (cub centric not bolt on) fine on these wheels on the track.
#9707
John. Check with Dean to make sure that switch isnt redundant on ROW config 964s. You must be running WOT maps so something is triggering it. I looked up my management files and my ECU is programmed to revert tables at 60% TPS. Infact I run open loop system 100% of time (no o2 sensors in my car as was motorsport variant for leaded fuel).
#9708
PSS10's have landed, had to pay a couple bucks in customs. I should be fine for this. I will take the c3 if 993 is in bits.
#9711
Spacers for show. No spacers for go.
They certainly do emphasise the cup 2's though.
#9713
My Fuchs rub front and back with Z221s. The fronts rub on full lock, but there is nothing vital there so I've done nothing yet. The rears have 6mm spacers fitted because the driver side has vital oil lines. Sam had rubbing there as well. It would pay to check before hitting the road.
#9715
Thanks Dave. Agree 100%
#9716
I assume the track tyres don't rub without spacers on? My Fuchs rub front and back with Z221s. The fronts rub on full lock, but there is nothing vital there so I've done nothing yet. The rears have 6mm spacers fitted because the driver side has vital oil lines. Sam had rubbing there as well. It would pay to check before hitting the road.
#9717
#9718
Edit: previous post timed out on posting. rRpeating myself thinking the post failed. First post of the day on iPad often does that to me :-(
#9719
Good point re my 17" track tyres. Apart from jacking up one side to get a bit of suspension travel on the opposite side and checking clearances, what's the appropriate way to test without hitting the road and potentially damaging tyres? Edit: precious post times out. Jensen repeating myself thinking the post failed. First post of the day on iPad often does that to me :-(
#9720
Bugger. Buyers and sellers remorse? You still technically own the C3, no? Back out and make a profit on the 993?
I'm sure Macca will have something to say in the 993s defense.
In time you'll get it going fast and feeling great I'm sure.
