Any Rennlisters from New Zealand?
How did you enjoy your first track day in the Cayman R? Looking forward to seeing one of these in the flesh on the track later this month. I'm sure it will be very quick.
Walter, the 2kcup forum site has a couple of posted videos from Roman. No doubt you will feature in the second one. Just to add to the perspectives.
I have won a Tardme auction for a pair of DC2 driveshafts. $141. We can use one on the Grinch and keep the other as a spare. Is there any work to do on BB2? I will likely have some time this weekend when I get home to do some work as Herman is already ready for the track.
Thanks Macca. I love the wet but I wasn't Peter Perfect. What's wrong with this picture?:
Attachment 929338
ChrisB and Pete - we'll done on the silverware!
Attachment 929338
Looking forward to the 28th to get more time behind the wheel and meeting my new internet friends!
Great first drive thanks Macca. I only got 3 sessions as I ran a bit late getting there, but each session was an improvement on the previous. Car is very balanced and confidence inspiring. Best time was a 120.8... I wasn't trying to set best times, but would be interested to know what I should be expecting.... I reckon there's another couple of seconds in it given it was my first time in the car. Tyres were the biggest weak point, going off pretty quick in the last session. PDK is very precise, I love manuals but the PDK is so efficient it's hard to deny its purpose. The car sounds great through the Fabspeed headers and exhaust. No action shots to post sorry.
FWIW Using an AIM Solo is a great way to get objective data. As you get closer to your optimal time it helps narrow down where you can improve. For me it's turn 1 and the Sweeper.
Under my watch I got her miracle WOFed but I had Simon (her old owner and a 2KCup hotshoe) jump in her on Saturday and confirm that the master cylinder is shot since the pedal sinks to the floor with any sustained pressure. He's a bit of an expert on the problem as he's just replaced the MC in his own Integra after T-boning Ray last time. I should be able to pick a new one up cheap from Partsmaster in Penrose but am probably a better understudy than a mechanic. Or could drop her off to have it done at a garage. Beyond that, some of the lights are playing up - eg I'm indicating but the car isn't. One front and one rear too according to my wife. Not the fuses so could just be bulbs. Was lying under her, feeding the mosquitoes late into Friday night getting that LF engine mount on, but keen to revisit it as I think the proper bolts are still in your garage so I had to scavenge some from elsewhere, including one from the passenger seat. That mount also appears to missing a sleeve, unless they gave me the wrong part. It may be inside that seized one you have?
She was still brilliant to drive and we weren't alone in having issues. Mark Mallard delighted in telling me that he'd had trouble passing me because his car kept going into limp mode - and so each lap he was turning it off and restarting it going into A1 GP corner to clear the fault. Another fast driver had no clutch left and I'm sure there were other stories.
As you know though, one of the best things about Hondas and most 2Kcup cars is how crazy cheap the parts and labour are - often less than a tenth of Porsche prices for parts. And this morning I hopped into the Turbo and for the first time ever it felt like it had a high driving position - after coming from BB2's slammed stance and low set buckets. The bellow of the Turbo's REMUS does more to raise the hairs on my arms, but it's also pretty cool how BB2s exhaust starts buzzing like a mad hornet's nest once she's more than a thousand or two revs into the VTEC. Oh no, I'm probably in desperate need of some boy racer anti-serum...
Just snuck a peek at them with lunch. Here's the view from behind (well in front by then actually):
In Roman's race 2 vid, I'm in the black Integra 4 cars ahead of him at 9:11 (notice the gratuitous Porsche content just for Macca), and directly in front of him at my spin just under two laps later.
As you can see from the lap before the oops, I was dicing over several laps with a couple of 2L cars - Peter in the silver 2L FTO and Richard (who finished 2nd and 3rd that day) in his Peugeot 205. Roman finished 5th in both, so pretty fast company.
I was looking to get a good line onto the straight to catch them both back again (as I had the lap prior) and gave her a light brush of brake alongside the throttle in an effort to tighten the line slightly and get a better exit. Didn't quite get away with it obviously.
Roman's vid:
https://www.youtube.com/watch?v=D0t1CBJMs1E#t=775
Roman's vid:
Will check out the vids after work. Thanks also for staying in touch on the day - felt pretty special knowing you were following progress in real time from Samoa.
Next meet is 2/3 May at HD followed by BBQ meet at HD on 3 July from 4-6pm. Then the big one, the Dunlop 800 on 4 July @ HD. We need to get BB suited up. Ideally get her scrutineered at 2/3 May meet so we know she is good for the 800.
Luckily the above fit in with my travel commitments, although I recognise that having raced we are back of the queue for the above meets, except the 800 where everyone should get at least an hour on track.
If so those tyres should be good enough to get you into the late 1.15s with the cars modifications. Youll need to play with the pressures on them. It can make a big difference and may explain why they were going "off" earlier. Youll find 8 psi change on the track for those so will need to target 4psi under manufacturers recommendation on first session then start dropping them from there. The experience of myself (20") and other GT3 owners is you need to target around 30-32 hot at front and 34-36 Hot at rear but that will differ a little for the cayman on 19". Im sure US Rennlisters who track frequently will give you some advice.
I think you did well for your first time out on that platform. You will find the time drops quickly into the 18s by the end of the 28th and then it will take time and laps to get it into the 16s and beyond. That being said Ive done only three days at HD so probably not the best guy to talk about it LOL!
We need to get BB suited up. Ideally get her scrutineered at 2/3 May meet so we know she is good for the 800. Luckily the above fit in with my travel commitments, although I recognise that having raced we are back of the queue for the above meets, except the 800 where everyone should get at least an hour on track.
Chris - looking forward to meeting you and your R on the 28th.
It's seriously Russian Roulette (when, not if) as anyone on here who's been to the track over the past few years. I think over track 50% of the regulars on this forum have had a miss-hap.
It is one of the big benefits of Play Days and RSG days over 'real man's' racing
$5K deductible is the least of your worries compared to explaining away a circa $100K (or more) to the missus.......
Like John and others have said, unless you are loaded and won't notice six figures missing from our bank account, don't go to the track uninsured.
I count four accidents over two years in RSG track outings from a core group of say 25 participants who regularly attend meetings (usually 15 per track day). 16%. I wont name the incidents but those who have been in attendance since Jan 2013 will know.
I count a further two accidents happening at PCNZ speed series events.
Paul, you yourself have been uninsured for 6 figures+ on at least 3 occasions I can think of including my own car & Neils GT3. Probable a dozen times if you include others in "cheaper" cars. To the best of my knowledge you have circulated HD more than anyone in our group without a single accident!
Just saying thats all. This doesnt have to be a dangerous sport. Depends on your discipline and if you are the competitive type etc.
Its not an undertaking without risk, but I d not think the odds are 50% you will have an incident leading to damage to your vehicle. Probably more like 15% over time.
