Isudar Carplay for PCM 3.1
#484
I need to figure out where in the main plug the power is and I'll make sure power is getting TO the stereo, but that's about all I can do.
I went to Crutchfield but they don't have fitments for Porsche online. I have to call them. And it looks like steering wheel controls are going to be a problem. Does anyone have recommendations on a moderately-priced ($500-$600) Carplay/Sirius compatible unit? I don't know much but I'll look at Pioneer, JBL, Sony, Alpine, Kenwood, JVC because they're names I recognize. I'm not an audiophile but I hope I can get something in that price range.
stevepow (05-26-2022)
#486
@LarryB make sure that your battery is good / charged. I had all of those warnings (start-stop not working, steering wheel, etc.) in the past and the PCM restarting when my battery was low and I started the car.
#487
To each their own, but I'd definitely put a voltmeter on the battery to be sure, and poke around a bit more with a multimeter before going shopping at best buy for a Kenwood.
Dumb question re: those may be symptoms of a weak battery - have you cranked/started the car since they showed up? If the car is running you should have ~14v of alternator output so you can rule out weak battery theory if the errors remain with the car running/immediately after shutting it off.
#489
Here is more detailed installed video for isudar wireless carlay kit pcm 3.1
1. https://www.youtube.com/watch?v=Gll_rbeSon4&t=335s
2. https://www.youtube.com/watch?v=nXC4jxxhztI
Has anyone asked for...and received this new improved version ?????
#490
If the car starts instantly there's 95% chance you don't have a weak battery, and if it remains running for more than 30-60min then you have a functioning alternator recharging the battery. So unfortunately "weak electrical system" is likely not your issue.
LarryB (01-14-2022)
#491
Downloaded the new firmware from Kimii and unzipped using WinRAR.
I tried 3 different USB disks formatted with Fat32. The unit did not recognize the firmware. The Update button did not turn on. What am I doing wrong?
