Isudar Carplay for PCM 3.1
#511
One more question:
Today I tried to use jukebox function of PCM and it seems, that it won’t shows up anymore, after installing the board. (New v2 Board)
Same for PCM iPod function, I see that my phone charges, when I plug it in into factory glove box USB slot, but if I press „MEDIA“ button, there is no iPod function, to hear music from my phone.
Same problem if I try to use AUX BT, it also won’t appears.
Iam using v2 board of Isudar.
Can anyone confirm that?
It worked before installing CarPlay module.
I also chose the right audio source on my phone.
#512
One more question:
#513
#514
#516
So 2.0.0 b latest FW is 1124
and board with v2 the 105b.
But that's my experience,
#517
There are 2 different boards the 2.0.0,b board has a big problem with the 105b firmware the latest good working FW is the 1124, loud pink sound with 2.0.0.b on 105B, no way to get rid of that.
#519
Kimi,
The 0105.B firmware fixed the reconnection problem on the latest Isudar board. But, here is the ongoing problem: after we turn off the PCM and go back into the house, Isudar remains running and the iphone does not switch back to house Wifi for a long time. Please make Isudar turn off Wifi when we turn off PCM.
Is this issue being addressed? It should be able to turn-off Carplay when PCM is turned-off even if there's still power on the line.
Porshatt (01-15-2022)
#520
#521
AngelDutchy (01-16-2022)
#522
Kimi contacted me as well. Sent me a FW update for board CP31DCBSJ8813WP3 (board version 2.0) that she says resolve the connectivity issues, but it turns out it is the same 0105 firmware update that was sent to @marcr92 and that I have transferred to the google drive.
On another topic, she also responded to another email I sent. I had been asking for months for a solution for the steering wheel return button behavior. It seems they have developed a solution for that and she is going to send to me for testing. Stay tuned.
Edit: Add info that my system is PCM 3.1, with iSudar V1.2 board running 1124 firmware.
#523
Hi guys, I had a question if anyone knew potential troubleshooting steps for the isudar module? Basically I got everything installed and plugged it all in and my display never turned on. My dash states no video signal as well when on navigation. I can visibly see lights shining on the inside of the PCM 3.1 housing so I do believe it is getting power and have since taken it apart and reseated all the flat cables multiple times. I can’t figure out what’s wrong. The most I could think of is perhaps how tight the folds are because I had the extended siriusxm port and thus needed to raise the board’s standoffs but that shouldn’t matter. Thanks for any help! I’ve also contacted Isudar, hopefully I can get this fixed and let anyone know the steps.
Just in case any of the cables are damaged does anyone know where I could get replacements in the states? Thanks!
#525
@kimi I updated to the latest software 0105 and the reconnection issue seems to be gone which is great. I am now running in the same problem @Porshatt mentioned. The CarPlay stays connected for a while after I 'lock' the car but seems to stay forever if I don't lock it. The main issue is the following use case which just happened to me today... I stopped the car and start working on it (installing the aftermarket backup camera). This took a few hours with lunch in the middle, after 4h the CarPlay was still connected to the car while PCM was complety off for all this time. This seems a very normal use case where we turn-off car and don't lock the car (I have keyless if that matter). It seems to be draining battery since when I went back inside the car and turn the key, the PCM came up and I saw a warning with low battery and something saying that socket and pcm was going to be turned-off. At that point, battery was at 11v. I had to plug-in the battery maintainer.
It seems to me Porsche designed the PCM not to fully shut down when the ignition/Aux is switched off, only the display is off, probably for fast boot up if your in and out of the car. The Isudar is staying on with the PCM, its around 30 mins in my case. @RR911 Having a live connection to a phone might keep it live longer, I don't know as it drops connection if I park in my garage and go into my house.
What the Isudar board needs to do is shut down with the PCM display not the main unit, that will be a via a signal from the cars Canbus system. I'm not sure if the Isudar board reads the Canbus but guess it does for the reverse camera switching....how do I make a video of all that
