Panamera 2010-Current
Received my new PIWIS III
Old 11-23-2023, 12:42 PM
  #1681
edsonreds
edsonreds's Avatar
What do you mean "about to pull the trigger"? I would have assumed you already found your vendor and on the verge of paying... so you are still evaluating/selecting/researching.
Originally Posted by 99-911
I'm too about to pull the trigger on PIWIS 2 hardware + software, any recommended vendor?
Old 11-23-2023, 12:45 PM
  #1682
Jonny9999991
Jonny9999991's Avatar
I used rnlst and I can recommend based on response time to questions and ease of installation, but if you’re not very tech savvy and don’t have experience with computers you may need some additional guidance which he can provide or I’m happy to help if needed.
its piwis 3 and I believe the latest version, just waiting for hardware to arrive tomorrow.
Old 11-23-2023, 01:14 PM
  #1683
MemoS
MemoS's Avatar
@rnlst_log is the guy. You need to contact him with what cars you have. Purchase a certified laptop from Amazon send it to @rnlst_log done! He is always there to support.
Porschetuner2005 (12-05-2023)
Old 11-23-2023, 01:16 PM
  #1684
Marcus13190
Marcus13190's Avatar
Lenovo T460 it's ok with RAM 8Go.
Old 11-24-2023, 10:17 AM
  #1685
GT3dailydriver
GT3dailydriver's Avatar
Be careful with your VAS 6154. I just broke the USB connector off inside mine. Barely bumped the cable with my foot. Connector broke off the circuit board. Not something that can be easily repaired. Looks like I need to buy a replacement. Any suggestions for a reliable source?
Old 11-24-2023, 10:22 AM
  #1686
edsonreds
edsonreds's Avatar
Got mine from: Buyobdii.com. No complains.
Old 11-24-2023, 11:34 AM
  #1687
edub
edub's Avatar
Soldering a USB is usually pretty simple. If you want to include a close up photo of the damage I could tell you whether you could just buy a new USB port and solder it.
Old 11-24-2023, 11:59 AM
  #1688
Chimuel
Chimuel's Avatar
Can confirm the USB port is fragile but it was also pretty straightforward to re-solder whine mine fell off. I did make some modifications to stabilize the port by adding some foam padding and hot glue.
  #1689
GT3dailydriver
Thanks, but the connector pulled off some of the printed connections. It could be resoldered, but I don't have the ability to repair the damaged printing. I will use it in Wifi mode.
Old 11-24-2023, 12:08 PM
  #1690
JB911
JB911's Avatar
I use mine with wifi to avoid the cable issue-prices have significantly dropped, a list of current vendors would be good for new buyers-
JB
Old 11-24-2023, 12:09 PM
  #1691
Chimuel
Chimuel's Avatar
Even with ripped pads it's still possible to repair, the traces are not complicated to just run small wires. I would find a shop that can do microsoldering. I'd offer to do it but I'd rather you have someone who would offer you a warranty with their workmanship!
Old 11-24-2023, 12:12 PM
  #1692
siberian
siberian's Avatar
Received 2,319 Likes on 1,378 Posts
Just use it with WiFi. I broke mine off as well. Also consider migrating to the T6PT3G; lightning speed
siberian
Old 11-26-2023, 04:48 AM
  #1693
rainer
rainer's Avatar
I can confirm the T6PT3G works perfect.
I was finally able to create a VAL in about 3 minutes, which was not possible with LED head lamps using the VAS6154. Thanks for the hints!
siberian (11-26-2023)
Old 12-10-2023, 12:17 PM
  #1694
cayo
cayo's Avatar
Piwis 3 automatic coding do not work, I got error during F-TAB , I have researched without result about solution.
please help me!
in which direction I need to go?
Any help is much appreciated 😉
Old 12-10-2023, 12:29 PM
  #1695
siberian
siberian's Avatar
See if this gentleman can help you @rnlst_log
siberian
Quick Reply: Received my new PIWIS III
