Received my new PIWIS III
#1711
@MB 911 I'm not sure anyone will answer that. ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Other dongle I can vouch for is the T6PTG3, lightning fast compared to the old VAS6154; VAL in under 4 minutes.
siberian
siberian
#1712
I recently/possibly wiped out my gateway coding in my 997 turbo when trying to Diag a bad PTM.
I was on the phone when clicking around with PIWIS3 and in gateway I clicked “automatic coding” it immediately failed and the dash went black, wind went up and wipers turned on. Then fans went full speed.
try to recode and it just fails.
car starts but fans are ok high speed, no dash light, spoiler is fully up.
any help would be appreciated.
willing to PayPal for your time.
Christian
Christian
#1713
elga (01-10-2024)
#1714
"Kombilenkstockmodul" is what you most likely look for, it contains coding for e.g. heated steering wheel and all other values around the steering wheel and column.
There's also a module "MFL" which represents the small ECU inside the steering wheel, but nothing to code there. Basically just the part nr you can see there.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
rainer (01-08-2024)
#1717
No. Lightning speed with VALs in 4 minutes
siberian
siberian
#1719
siberian
siberian
#1720
Carlton Bale (03-25-2024)
#1721
Hey folks, I am attempting to recode / 'teach' the headlights in my 2017 Macan (swapped lights) and my VAS6154 clone seems to error out during the process. It works fine for other simple coding functions but this one task seems to be an issue. It sounds like the T6PT3G provides the required bandwidth / is the better option for coding headlights? Just looking for confirmation that it works before ordering one.
Also if anyone has had success with coding headlights on a VAS clone let me know, perhaps I should try PIWIS 2 instead?
#1722
No, just get rid of the VAS6154 and get a T6PT3G instead.
siberian
siberian
jayson (01-11-2024)
#1723
So I was wondering if anyone in the greater seattle area wants a case of beers or good ol' fashion money to do some coding for me. Trying to permanently change the imperial stuff in the car to metric (even when setting to metric it will show MPH in the cluster. It's infuriating) Also would like to code in my overpriced headlamps I have paid for on my GT3RS and Panamera lol.
#1725
