Received my new PIWIS III
#931
I've been using the Powermax coupled with a CTEK (depending on what I'm doing) extensively and I've not had any issues, so please post of you find a better unit. I do agree that the setting mode is primitive as well as not having an ON/OFF switch is perplexing.
siberian
siberian
A couple high-quality options look like the Schumacher INC100 (< $550), and the Clore PL6100 (< $450). Both are 100A-capable supplies designed for reflash support with digitally programmable voltages. The Porsche tool spec’d for this is now the VAS5908. It’s a cool $2k though, unfortunately.
#932
Actually not that I recall. I guess the easiest is to have to an additional meter to the voltage display on the dash and one that's connected to the PowerMax showing voltage (and Amps).
siberian
siberian
#933
![](https://www.victronenergy.com/upload/cache/1594624623_upload_documents_1550_1000-Blue%20Smart%20IP22%20Charger%2012V%2030A%20%283%29%20120V%20%28left%29.png)
Some things I liked about this charger:
- Designed by a professional power technology company
- 5 year warranty (I care less about the warranty and more about what that says about the product quality)
- 30 amps continuous charging
- Supports lithium batteries (so I can use the same charger for both topping up the battery and keeping it steady during programming)
- Fully customizable charging profiles (including a fixed output "power supply" mode, though it's not needed)
- Real-time voltage and current monitoring of the output via Bluetooth in their app
- Well-supported with frequent firmware updates and new features (e.g., the "power supply" mode was added in an update)
- Reasonably priced at under $200
Once the battery was charged, the charger never had to source any more than about 10.5 amps while the ignition was on.
#934
30 amps is not enough for any of these cars-the 997 alone requires 40 amps-I have the factory service manual and that's what it says.
JB
JB
#935
x2, it's been mentioned a few times.
Minimum I would recommend is 75A with 100A being now suggested. When coding heavily and connected to the 75A PowerMax, voltage dropped from 13.4v to 12.9 while waiting for a VAL. I wish there was a way to turn off lights etc.; I do turn off the PCM display but still a needless waste of current powering the lights etc.
I ordered a digital LED meter I'm connecting to the PowerMax, alas the PO is backed up and delivery is delayed...maybe today or Monday...
siberian
siberian
#936
siberian
siberian
A tidbit that I also learned on the way is to have the key fob placed on the "learning" spot. On the 992, narrow space just in front of the central armrest. It need to stay open. On the cayenne, inside passenger side cup holder.
#937
DRLs, rear lights, dash drain power needlessly
What's the "learning spot" supposed to do?
siberian
siberian
#938
siberian
siberian
I've forgotten in the past and nothing different happened. I read about it on a TSB, I believe.
#939
I normally put the FOB in the cup holder; I would assume close enough to the point you mention. Do you happen to still have the TSB?
siberian
siberian
#940
siberian
siberian
Note that a partially discharged battery will also draw whatever your supply will give it as it recharges, so the a fair test of what the car is drawing is to first charge the battery fully until it’s not drawing any significant current at the charging voltage, and then go do the diagnostics work.
#941
siberian
siberian
bayite DC 5-120V 100A Mini Digital Current Voltage Amp Meter Ammeter Gauge with Hall Effect Sensor Transformer
#942
It probably depends on your car's configuration (RAS etc.) and number of pending DTCs you have while trying to complete a VAL for example. To my understanding there isn't a defined test you run on PIWIS that will draw this amperage while another one will draw more or less. From all the folks who've been using PIWIS and have done extensive coding with it for lengthier time periods this is what's recommended. If you feel this amperage isn't needed then you should use the tool you think is best.
As to the volt meter, yes, as I mentioned I've ordered one but Amazon deliveries are backed up one week here so who knows when I'll get it.
siberian
siberian
#943
Bur if the battery is already fully charged, then you should only need to deal with the amount consumed by the vehicle electronics during the work.
#944
As I mentioned, you should use the tool you feel is right for you. No sense in beating this to death.
siberian
siberian
