Received my new PIWIS III
#1606
I have a couple of 6154 for sale if anyone want to go cheap. Like with speakers in an audio system, spend it on that not an amp or in this case buying more bling. YMMV
siberian
siberian
#1607
Does it support DoIP?
siberian
siberian
#1610
siberian
siberian
I might get this and update my PIWIS or buy another one to get back in the game. I plugged the cayenne MY24 to my PIWIS v38, and it was as good as if it was a different brand. Most of the modules that could be read, the coding options came as gibberish.
#1611
I want to reprogram my entire DME (or do it to a new one). Does anyone have the WN/tech bulletin on steps with PIWIS 3?
I was going to get a PowerMax power supply. Is this the current recommendation?
PowerMax 12v 100 Amp Charger Converter Power Supply w/ Alligator Clamps
Part No. PMBC-100LK
$298.95
Part No. PMBC-100LK
$298.95
@siberian IIRC you have this one too? To connect to the car, you don't disconnect the battery do you? See the first bullet on the instructions?
Thanks!
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1460x2000/pmbc_instructions_page_1_15a2946ba0bc1be022f134e3b0de3c198880aff8.jpeg)
Ghostbuster (09-15-2023)
#1612
Hi, yes I have the 100A version. No, you do NOT disconnect the battery
siberian
siberian
#1613
[QUOTE=Westcoast;19015230]Mine just arrived, did you go with this one?
Thanks!
We have our 100A unit in use every day, for over 2 years now, and holding up well.
If U start your engine with that hooked to it, and then shut it back down, U need to cycle the Power Button on the maintainer, so it starts working again.
[Once it senses charge rate from the car, it goes into stand by 13.60V, but not putting anything in the battery. ]
Thanks!
#1614
[QUOTE=Ghostbuster;19015288]
Thanks!
Thanks!
#1615
I had mine set to 13.4v but now, given my current predicament, recommendation is 14.2v - especially if doing any Campaign updates. Yes fixed voltage
siberian
siberian
#1616
Yes, car is dead. I'll leave it at that for now.
siberian
siberian
#1619
I'll belay that reply until I can resurrect the car. 2021
siberian
siberian
