Note to Porsche classic - 997 PCCM plus request
Old 01-25-2023, 07:38 AM
  #901
svandamme
svandamme's Avatar
Originally Posted by Carrera01
I placed it on the shelf but was not able to get the Nav signal so ended up placing on the A pillar like GIG did. When placed here it worked.
My test in a 2 car garage was compared with my other car, a B Class. The Nav on the Merc could clearly show a map of the area with detail. GPS antenna on the shelf could not get a signal, on the A pillar, clearly see a map with detail. This was not an issue as I had removed the A pillar covers to fit the DAB amplifiers so a 5 min task running the cable back.
You sure it wasn't jut a longer pickup because it was the first time looking for satelites?? first time always takes forever.
Only other thing I can think off, is the sport chrono thingie magic blocking signals , I don't have that on my dash and satnav picks up fine.
Old 01-25-2023, 08:24 AM
  #902
JustinCase
JustinCase's Avatar
I finally got around to permanently removing my CD Changer and old Cayenne Sirius XM Receiver. It got a little complicated because of the special harness associated with the old Sirius/XM box, but I re-figured all that out. I left the Nav unit in for the time being because (a) I need another MOST terminal loop to maintain the circuit (I used the one that came with the PCCM+ to terminate the CD Changer harness), (b) because with the CD Changer removed, the Nav unit flushes up with the existing CD Changer shelf and makes a more usable storage space, and (c) because I have never figured out how the Nav unit is fastened down so that I can remove it (the real reason). The car doesn't seem any more responsiveness, but then I could afford to lose 20 pounds, myself.
While I was in there, I removed my old windshield frame-mounted XM antenna and rerouted the cable for an additional XM antenna I had epoxied to the underside of the cowl 7-8 years ago into the space behind the PCCM+ for future use with a new, compatible Sirius/XM receiver. I never used that antenna because reception was flaky in the mountains and tall trees of Washington State, but I am hoping that reception will be better than in the past in the relative flat openness of Tennessee. I'll use Apple CarPlay if I have to whenever I go into other mountains.
The map SD card, defective or not, is due in today. We shall see.
I wonder if the problems with USB thumb drives and missing data on the map SD card are related.
Old 01-25-2023, 11:10 AM
  #903
Alfnado
Alfnado's Avatar
Originally Posted by daddyscar
Call Porsche Marin. They were out of stock two weeks ago but told me what other dealers had in stock without even asking. I got mine from Porsche Vegas. Only downside is I have to send my CA sales tax payment on my own 😁
Thanks!
Old 01-25-2023, 11:45 AM
  #904
fritzcurtis
fritzcurtis's Avatar
Albeit minor, there seems to be an issue with Siriusxm as well. Logo data for stations is flakey. You can go into maintenance mode and hit update button. That brings up another screen that allows you to update Sirius logo data. I hit it and it took about 20 seconds and came back with success on the screen. I exited the maintenance menus and went back to xm and sure enough all the station logos were there. Then the thing updates with a circling logo on top left and they disappear. The thing is then Sirius slowly tries to update them into the screen over time, but none of them stick when you turn off the car. Next time you turn on radio all logos are gone.
Old 01-25-2023, 11:51 AM
  #905
fritzcurtis
Maybe the new and improved units will be called PCCM Plus Plus!
  #906
JustinCase
JustinCase's Avatar
What Sirius receiver are you using?
Old 01-25-2023, 11:55 AM
  #907
fritzcurtis
Sirius receiver recommended is:
SiriusXM SXV300AZV1 on Amazon.
The following 2 users liked this post by fritzcurtis:
defunct_neurons (08-11-2023), JustinCase (01-25-2023)
Old 01-25-2023, 01:13 PM
  #908
ishmclaughlin
ishmclaughlin's Avatar
Just wanted to update my posts above.
Called Porsche Palm Springs on Monday afternoon per your advice. They did have a unit in stock, I paid for it Monday afternoon and it arrived at my door Tuesday morning!
Thrilled with the service from Porsche PS and happy to report I now have the Carplay unit. Thanks for the help. Now for the install...
To those looking, give them a call.. maybe they have more!
Old 01-25-2023, 03:09 PM
  #909
svandamme
svandamme's Avatar
I think I figured out how PCCM deals with MP3 files.
It reads the MP3 tags for the Album, and groups the music according to the album tag.
So regardless of directory structure, if you have 2 files with same album, it will group across the entire folder structure
Stb for confirmation, will test
The following 3 users liked this post by svandamme:
babylonboots (01-25-2023), defunct_neurons (08-14-2023), Woodsprite (01-26-2023)
Old 01-25-2023, 03:53 PM
  #910
svandamme
svandamme's Avatar
Can confirm.. MP3 tag for album is what sorts out Back/Forward or shuffle
However... for browsing, you still need the directory structure, since the browsing really only works on the file system.
This is designed by Germans, and there is no such thing as any random list with mix mash files from random albums with missing MP3 tags
ORDNUNG MUST SEIN!
So to get along
put your stuff in directories
make sure the directores have files from 1 album only, that the MP3 album tags are properly set
If you want a mix directory, overwrite all the tags for that mix directory so they all have the same album tag, and "Bob's your uncle", or rougly translated "Dieter ist Deinen onkel".
The following 2 users liked this post by svandamme:
Old 01-25-2023, 04:10 PM
  #911
medicus
medicus's Avatar
ORDNUNG MUST SEIN!
So to get along
For a Belgian, your German is really terrible.
Net als mijn Vlaamse
Old 01-25-2023, 04:12 PM
  #912
svandamme
svandamme's Avatar
Well off course it is, we aren't German and are no longer under German military rule :P
Old 01-25-2023, 04:16 PM
  #913
medicus
medicus's Avatar
svandamme (01-25-2023)
Old 01-25-2023, 05:43 PM
  #914
benessere
5th Gear
benessere's Avatar
Originally Posted by jonan
where are you guys sourcing these? i'm still on the suncoast waiting list...
I was able order from Gaudin Porsche in Las Vegas.
jnb
Old 01-25-2023, 07:49 PM
  #915
babylonboots
babylonboots's Avatar
Update
Hello, this is Porsche North Houston parts dept. Very sorry for the mixup, but my colleague must have been confused.
PCCM+/PCCM's for 996 and older vehicles WERE recalled but have since become available again. PCCM+ for 997.1/987.1 have NOT been recalled and are currently available... albeit on currently limited supply. If you have any questions or would like to purchase please DM.
Quick Reply: Note to Porsche classic - 997 PCCM plus request
