Any Rennlisters from New Zealand?
#9094
Sam, that looks god damn jaw droppingly beautiful! It has to be the most stunning 964 in the group now. The stnace and height is just perfect! Without doubt you will drop 2 seconds next time at HD I guarantee it. The confidence this set up will give you alone will make it seem faster still. Great worth, worth every penny...
#9098
Turbo comes home tomorrow. New tyres and control arm bushes. No plans to repaint as I don't think I could keep it clean enough in any other colour. Depending on Herman's running status I may take it to Tauranga for the day over the weekend. K gorge will be great in either 964.
#9099
might have to join you for a leg of this, but not the whole shakedown, I'll get some proper measurements from ground to chassis at some point too, as this seems to be the only correct way with differing tyre/wheel combos. alignment doesn't have those stats.
#9100
[QUOTE="Runtothehills;11104272"] Time for another 'how to' in the air cooled section, Followed your scuttle replacement one over the weekend, took longer than I thought and all I can say is you can't use too much lube to get that job done.[/QUOTE
Steve did say I was a lucky beggar that mine came out easily and went back in the same. Did you get the result you wanted? Please share your experience on that thread. Good or bad it helps others.
The shark fin is beautifully engineered. When properly fitted the trim strip sits perfectly. I'll see if there's already a DIY. I can't be the first to do it.
#9103
