Any Rennlisters from New Zealand?
Old 08-07-2013, 08:20 AM
  #4171
John McM
John McM's Avatar
Originally Posted by Macca
John. Wheel looks great. Definitely need the spacers. Is that the AIM bracket on the window? Theres no hiding that baby eh?
No, it's pretty much Industrial strength. The cabin ergonomics are coming together. Sports seats and the Mod 07 wheel give better feel and secure seating. I have new bushes for the gear shift and will replace at least the exposed one soon. The AIM is perfectly placed for reading predictive lap times. It's all good.
Old 08-08-2013, 12:11 AM
  #4172
kiwi 911
kiwi 911's Avatar
OK - the call for Sat and Sun - Road tires or track tires - I understand it's going to rain...........
Old 08-08-2013, 12:40 AM
  #4173
mjg
mjg's Avatar
How do you guys get on with spacers when going for a WOF? I was under the impression you need an LVV cert.
New wheels on, shod with my bargain Dunlop DZ03Gs, ready for the weekend (excuse the cellphone quality pic):
Old 08-08-2013, 12:41 AM
  #4174
John McM
John McM's Avatar
I'll be on road tyres with PSM, ABS and 4WD and you'll still likely pass me...so go with track tyres!
Old 08-08-2013, 12:47 AM
  #4175
John McM
John McM's Avatar
Don't know. Never tried it so far. I get my WOF done at CCS. Get a free car wash at the same time.
Old 08-08-2013, 01:12 AM
  #4176
John McM
John McM's Avatar
Nice wheels. What tread is left on the tyres?
Old 08-08-2013, 01:13 AM
  #4177
kiwi 911
kiwi 911's Avatar
Having a bob both ways by going with the Toyo 888's, they work OK in the wet. The Hankooks are a dry tire only.
I'll be gutted if it's dry...............
Old 08-08-2013, 01:18 AM
  #4178
mjg
mjg's Avatar
Ah, will be interesting, they might turn a bit of a blind eye. Kind of like me getting a WOF running -3.0 camber after they change the rules to only allow 0.5 degrees deviation from factory specs.
Quite a bit lighter than the standard ones, didn't bother weighting them as they've got such different tyres on them. There's 3-4mm all around. It's more a question of how many heat cycles they've seen, as many of these R compound tyres get slippery after they heat cycle out (which is often well before the tread is worn down).
Old 08-08-2013, 01:50 AM
  #4179
Macca
Macca's Avatar
Ive never had a WOF issue in 15 years with spacers, cat delete, -2.5 camber. Used the same crowd (CCS) twice annually since te car was new 20 years ago.
I cant see spacers being an issue. Porsche sold a number of 997 cariants with spacers as psrt of teh package (think speedster, Sport Classic some special edition boxster, 993 C2S etc).
Old 08-08-2013, 02:16 AM
  #4180
Maxem
Maxem's Avatar
Tricky situation. My lot is a seat, half cage, adjustable platform suspension and non factory road belt stalk mount. So far I come up with full compliance. I've been prepared all the way along to get a LVVC but only if nescessary, but the word seems to be that I don't need it. Buggered if I'd turn up at a VTNZ though. I'm considering rear 15mm spacers so I'd be interested where these fall. Interesting challenge for the Porsche specialist I end up going with long term - WOF or not?
Old 08-08-2013, 02:32 AM
  #4181
peterC2S
peterC2S's Avatar
Track for me - with fingers crossed. What do you reckon the time diff is wet vs dry?
Biggest problem I have is the air con has just stopped so the car misting up will be an issue.
Old 08-08-2013, 02:44 AM
  #4182
Macca
Macca's Avatar
Ive run bolt on spacers 10mm no issue with WOF. Key is to have the same guy WOF it every time. What does a VNZ station know about accepted noise and specification of a 20 year old 911 (could be factory tolerance back in the day but they wouldnt know).
I have a WOF next week with Cage, R compound, aggressive camber, cat bypass etc so Ill let you know....
Old 08-08-2013, 03:37 AM
  #4183
John McM
John McM's Avatar
What does a VNZ station know about accepted noise and specification of a 20 year old 911 (could be factory tolerance back in the day but they wouldnt know)....
Blind Freddie could tell your noise levels aren't within factory tolerance
Old 08-08-2013, 04:16 AM
  #4184
Macca
Macca's Avatar
LOL! Its only loud at idle. Once around 2000 rpm its no louder than Pete's with his decat.....I tell myself....
Old 08-08-2013, 04:20 AM
  #4185
964X33
964X33's Avatar
Peter, you mean your track times are with aircon on???
Quick Reply: Any Rennlisters from New Zealand?
