Any Rennlisters from New Zealand?
#3781
Paul. Thats a huge improvement! The new engine must be running sweet as because Im sure the handkooks couldnt have given all of that difference in time....good work
#3782
I posted some data on the Rennsport Gruppe.
The AIM Solo proved itself today. Swapping easily between cars and a no brainer to use. The PC analysis pack takes some time to understand. Maybe I should read the manual! I can understand some of the data already, very instructive.
#3783
Here's a screen shot. Peter's fastest lap compared to mine. The steepness of the lines denotes rate of speed change. Peter's graph line is the steepest. Peter, are you hitting 5th on the straight?
#3785
#3789
Its interesting data John. Particularly Petes car with two different drivers as its a good comparison. Tony is right on the pace but braking earlier - probably because hes driving someone elses car! (if Im reading this right of course)
#3791
That would be great. But I'm confused - if the low points on the graph represent low speed then it looks like there are 8 corners. And there are only 6 at HD??
#3793
Fascinating data John, thanks for posting! Thanks for letting me have a session with the Solo too, much appreciated. No need to compare my data with anyone else's though...
#3794
You're welcome. I'll keep your data out of public viewing. My real interest was using Peter's car as a base, as It's essentially my car with a better driver, which gives me times to strive towards.
#3795
I'd be interested to see the graph of my fastest lap though, when you've got time to send it -- no hurry.
PS Have you tried using the Print Screen button on your keyboard to take the screen shots, and then Paste in Paint? Might give better images.
