Any Rennlisters from New Zealand?
Originally Posted by Kiwi Carguy
So I've always said with Porsche history has shown us as far as values go and collectables history repeats. More so with the 911 range but not exclusive to it. Anything with the RS or CS moniker or limited numbers aka Sports Classic etc hold their value and over time can increase in value. So here's a "limited edition" Boxster "one of only 4 in the world"?? Sitting rather cheaply at $19990.... Future collectible or simply a dull 2.7 Boxster with some badges and not special enough?
http://www.trademe.co.nz/motors/used...056239662.htmr
I'm entering the Targa Tour in May and looks like we have to use their "livery" including their banner. I'm guessing this means taking my Rennsport one off and putting their one on.... thus I'll need a new one? I'll get another red on black if thats the case....
Originally Posted by John McM
Oi, don't splash these details around. There maybe lurkers and I don't want to get gazumped with my latest brain fade.
.... The time between trying to push out of the spin and trying to stop before the wall was very short - when I over corrected I quickly realised that my only hope was to try take advantage of the kitty litter and slow down before the wall (thanks Chris, your lesson on "braking needed to slow down in sand" worked. If I hadn't jumped on the brakes after going off the track, I suspect the rear of the car would have ended up in the wall.
Just thankful the damage is minor and my only injuries to my ego. Apologies to all that had their last session cut off 3 mins early!
One thing Mike Eady taught me a while ago was to get onto the brakes as soon as possible. This saved me from hitting the wall on the back straight at Taupo in the 1M when I got caught out by turbo boost on a slalom - stopped 30cm from the wall. And I'm sure it contributed to my pretty much staying on the track after the spin at Highlands. I think that if you don't get control on the first phase, then keep trying for sure but get hard onto the brakes as well to minimise the damage.
Originally Posted by peterC2S
It's not an auction so you should be safe from brain fades...
I really don't have the energy to save an unloved 964 and to be honest it's hard to see the value when the older kettles are so cheap. Just need to make sure an older boxster is a low 1.2x lapper at HD and not high 1.2x.
If you're just lapping for fun, do the lap times really matter? Don't get me wrong, I enjoy improving my driving and a bit of competitiveness, but the possible times with a car shouldn't really matter? If they did, you'd not have sold the Cayman R...
Originally Posted by Leong72
Hi Jake,
That boxster looks reasonable value. Its just a local exclusive option special tho. Doubt the factory took any notice at all.
Thanks for the analysis Walt... I've watched the videos too many times, and the noise you can hear when it breaks loose is now exaggerated, playing into my suspicions that something influenced my ability to control the car. I've not experienced the sudden loss of control like that before, but in actuality I suspect it was just that it's the first time I've truly run out of talent.
Seems a bit too coincidental to be just chance that you ran this over, got a weird noise, and lost control all around that very moment. My revised take on this is that it maybe wedged somewhere under your car and thrummed in the airflow, with the sudden weird noise throwing you off enough to see you lift or brake a bit, thus inducing that oversteer.
Or more likely - bearing in mind the brief vibration your other cam picked up - it went under one or both of your outside wheels, acting as a bit of a roller bearing to kick the rear end out.
That said, there are other, more irregular white marks further back on that corner entry which I guess are mostly just chalk or sikaflex crack sealant. If it wasn't for the sudden weird noise and vibration I'd have thought this one likely to be that too, but in the circumstances it looks to have maybe been a thick wire, steel wiper backing, or maybe a radio antenna from an air-cooled?
Bloody hell Walt. You should work for insurance companies! Well done and spotted tho. That noise had me thinking twice too. Jason had some barbed wire he found under his car on the day. No one was driving anything Italian on the day so it cant be that. Looks like it could be a wiper blade insert from a white 1990 964. Maybe Chris M T1 club calling card coming back from the land fill to claim another victim?
Jake - in your hi rez originals can you pull individual frames? I remember walking up to the start of the skids with you and noticing a number of white gauges in the tarmac - it might just be one of those artifacting.
I took a few pics looking up the hill, but no luck finding debris in them, though if you went over something it'll have moved a long ways.
Walt, you should work in forensics. Had a look through the footage in slow motion, and that mark looks to be a scratch/mark in the track surface. Looking at the exit tyre marks, there's a discernible tyre pattern in both (the right is more pronounced but assume this is due to load), and aside from the strange shudder the ride out is relatively smooth.
