Panamera 2010-Current
Isudar Carplay for PCM 3.1
Old 05-02-2023, 08:54 PM
  #1276
ottodawg
ottodawg's Avatar
I actually had a newer MCU version (M:221228V1) but went ahead and applied the update anyway. Process went fine and it seems to have resolved the connection issue. Thanks for the info.
Old 05-02-2023, 11:20 PM
  #1277
leedo3
leedo3's Avatar
Default Try update on this version?
Anyone try the update on this Isudar version?
Old 05-03-2023, 11:20 AM
  #1278
Westcoast
Westcoast's Avatar
Received 4,662 Likes on 2,713 Posts
Isudar recommends that you get any software software updates directly from them... have you asked?
Old 05-03-2023, 01:17 PM
  #1279
leedo3
leedo3's Avatar
Yes I have. I received an update from Kimi in April 2022. There was a newer update that was released in July 2022. I requested the update from Kimi in August, but have not heard back from Isudar.
Old 05-03-2023, 01:21 PM
  #1280
Westcoast
Westcoast's Avatar
The update that I applied was to correct the issue of the Isudar board remaining connected after the vehicle was turned off... Was your update a full system update or a specific fix?
This July update, what is it for, or why do you need it, is something broken or not working properly on you Isudar board? How do you even know there is one?
Old 05-03-2023, 08:21 PM
  #1281
leedo3
leedo3's Avatar
Strap me to a chair and shine bright lights in my eyes.
Update was to fix a intermittent dropping of connection between board and phone.
Kimi was the one who informed me of the July update, but no specifics.
Old 05-03-2023, 08:45 PM
  #1282
Westcoast
Westcoast's Avatar
Ahhh, OK?
Your screen shot shows a different hardware version (2.0.0.B) than the latest (S7.B), this might have addressed the dropped connection, but did you try going to 2.5GHz instead of 5GHz?
My board came with version M:220708V1 out of the box and the connection was stable, perhaps because of the fix you mention.
Old 05-11-2023, 02:29 PM
  #1283
themartyk
themartyk's Avatar
You all make me laugh updating firmware when no issues exist. I guess that’s what you think is needed….
FYI, ensure AuxBluetooth is NOT used by w these units. If you so, you’ll find the audio will stop very shortly after starting the car. You’ll need to restart the PCM. Only need Aux.
Old 05-11-2023, 03:31 PM
  #1284
ottodawg
ottodawg's Avatar
Updating the FW corrected my last and only issue with the board, unit staying connected to the phone when car is shut down. Not sure what you're on about but welcome to the forum!!
Old 05-12-2023, 03:18 AM
  #1285
Marcus13190
Marcus13190's Avatar
I've this problem with sound after start car on Mr12Volt card. But it's only spotify and it's not necessary restart PCM, only choose read on the screen
Where is modification Aux ? Thank's
Old 05-20-2023, 10:11 AM
  #1286
BrianA
6th Gear
BrianA's Avatar
Hello everyone. Need some help, please. I have the iSudar version 2.0b in my ‘14 CS that was working ok, until I tried to update my firmware to address a volume inconsistency issue. No I have no sound. It’s set to aux input… I’ve had the unit about a year, but the inconsistent sound was making it hard to use, so I tried and failed to update. Kimi replied to an email, but I didn’t buy it from them. I bought in Amazon.
I spent a few hours go over this whole thread. All 86 pages. I just really need latest firmware p, if some kind person can help me out. Also, MCU update (not exactly sure what that is, tho).
Thanks in advance.
Old 05-20-2023, 10:21 AM
  #1287
Westcoast
Westcoast's Avatar
Thanks in advance.
Sorry to hear about the problems but you shouldn't update the firmware unless you know that it is compatible with the hardware and firmware that your board uses, randomly applying such update are not necessarily going to fix the issue and mat result in a non-working board.
What did Kimi say? Do you have screen shot of the versions, both hardware and software?
Old 05-20-2023, 10:24 AM
  #1288
Willy07
Willy07's Avatar
There was a F/W version that was wacking the AUX. The new file is out now, and fixed the problem.
Old 05-20-2023, 10:27 AM
  #1289
Westcoast
Westcoast's Avatar
And do you have this file and what version of firmware was it for?
Old 05-20-2023, 10:34 AM
  #1290
Willy07
Willy07's Avatar
I have the original 1.2 board. I recently applied it to another board as well, that did not come directly from isudar.
Quick Reply: Isudar Carplay for PCM 3.1
