Isudar Carplay for PCM 3.1
#1261
I am at the same firmware version as MrLargo, I too experience where the wireless stays active long after the vehicle is removed, in fact even if the door of the Macan gets opened the Isudar WiFi tries to link up with my phone if I am nearby... ![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
I asked Kimi about this and she promised to get back after checking with her engineers, and told me not to install any firmware that didn't come directly from them (I told her I had a newer version I got from another user), nothing so far... Maybe I have send another email?
Subscribing....
I was having a battery drain issue and sent pcm 3.1 and the amp off to Becker in NJ... had a bad amp, but while fixing, I had them install the Isudar board, and only 3 days in after the install, I've noticed the same as what appears to be happening to others... the board never shuts off, so it's going to eventually kill the battery. Last night I locked the car up and when I came into my kitchen this morning, I watched my phone open Android auto and hook up to the car.... so, even after about 7 hours, it's still active.
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/2000x971/isudar_original_firmware_5f130dd56462b3f0f7271238826b54af3ff14429.jpg)
To me this file appears to be a patch, it is very small when uncompressed (58 KB), I used a 2GB USB memory stick formatted in FAT32 but SD card in a USB adapter would work as well (see picture below), this gets plugged into the USB extension cable that is part of the supplied wiring harness. Make sure the memory stick/card is blank and only copy the unzipped patch ( acm_upgrade.bin ) to it in the root location.
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/604x123/usb_file_structure_e22dd9506915f9eb9459ff74feb9d960d40de2e6.png)
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/img_4841_9ddc4bbddb8a5d0879e742480c91451e9e312c45.jpg)
USB cable from Isudar board, with SD memory card in an adapter, or simply use a USB memory stick.
Here are the instructions I received from Isudar support, note the card size and type, also they specified to format it FAT32.
1. Copy the upgrade file (see the attached picture) to an empty SD card, note: Must be 2.0 SD card and which memory should not be larger than 6GB). The file must be copied correctly, otherwise the upgrade will not be successful.
2. In Settings - Version Information - Click Update (the system will recognize the file content).
3. After clicking Update SOC/Update, the screen will be black, and it will take about 15 minutes to wait. Please be patient and wait for the device to restart.
4. Be careful not to power off during the upgrade process!
Below is a video that Isudar support sent that shows how to navigate to the correct screen for upgrade, in practice the file should enable only the appropriate menu choice in the update screen, in this case "MCU"
https://youtube.com/shorts/uc6dc0dGT-M?feature=share
Here you can see the update screen, the only option to proceed with the upgrade is "MCU", otherwise "Cancel".
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1124/pxl_20230424_202623097_24dfc075010c45279b6c0b80aceb3aa2fcdf6c07.jpg)
This shows the updated version for MCU in the upper left: M:230221V1
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1124/pxl_20230424_202804881_781be2f3201f5c9a97d42d40653fd8150fc589d9.jpg)
Finally, the update file itself... This is ONLY for the version shown on the screen at the top of this post and is used at your own risk!If you want to be 100% sure about using the correct file, get it directly from Isudar!
#1262
That's fantastic! I'll have to do some looking tonight. Unfortunately, that means I'll have to get the PCM back out, which in a Panamera is a real PITA... but hopefully now that I've done it once, it'll be easier
#1263
That's too bad, so you didn't leave the USB cable somewhere handy to get to? In the Macan I routed it over to the passenger side of the console and tucked it up under the edge of the panel. IIRC you can use the USB connection like a Juke Box.
#1264
I can confirm that this update worked for me, of course I made sure to make sure I had identical version/hardware numbers to Westcoast. Only difference was it only seemed to take a minute for the update to complete, not 15 minutes.
I can report that when I turned the car off and opened the door it (thank goodness) disconnected me from Android Auto. Yay!
But I haven't actually used it beyond that simple test. No idea if there's other new bugs, or if anything else is improved. (for me, the backup camera trigger is very unreliable, with a manual)
Westcoast (04-27-2023)
#1265
Here's my screenshot. Appears to be the same as yours, so hopefully this fix works for me. Off to buy a USB thumb drive!
#1266
yeah, I saw no reason I'd ever use it, so I just zip-tied all the wires together and pushed them back in. Live and learn. I'll dig it out this weekend.
Either a USB drive or SD card (2.0 version or better) with a USB adapter, they also say no larger than 6GB, FAT32 format.
#1268
I stopped at Walmart to get a SD card or USB thumb drive .... there's nothing smaller than 16 GB... why is there a 6 GB max? Not sure where I'm going to find something so small
#1269
It won't hurt to try a larger device, it won't hurt anything, it will either recognize it and read the file or not.
#1270
Not sure but suspect that the firmware on the board can only address a certain size of memory. (I could ask but it might be a while for a reply), I am a collector of such things and have old ones around, that is what I used. The same is true of a small SD card, I have them as small as 256 MB!
we'll give it a shot this weekend!
JoeB3 (04-28-2023)
#1272
Are you all still finding excessive battery drain? I've driven mine daily since install, so it's hard for me to say... however, I sat down in the car today to do some other maintenance, and heard the fan in the PCM running for a min... I hadn't yet turned the ignition on, and car had been locked in my garage for about 3 hours at that point. I see no reason that fan would be on unless the board is staying alive.... ?
#1274
#1275
Actually, not only in the Macan, but my 718 as well, as soon as you open the door a number of systems come on, including a boot up of the PCM IIRC. As these are computer based the only way they can be ready just after the engine starts is to get up and running, so I am not surprised the fan was running.
