What did you do to your 997 today?
Old 02-25-2022, 10:56 AM
  #12736
Petza914
Petza914's Avatar
Received 6,681 Likes on 4,241 Posts
Originally Posted by rtl5009
My seats are finally finished! Recaro sportster CS in sand beige
Awesome!
Petza914 is offline
The following 3 users liked this post by Petza914:
ABNJOE (03-01-2022), BHMav8r (02-26-2022), Mayall911 (02-25-2022)
Old 02-25-2022, 11:00 AM
  #12737
Khloesdad
Khloesdad's Avatar
WOW^^^^^^^^^^^^^Thats money well spent.
Khloesdad is offline
Old 02-25-2022, 01:23 PM
  #12738
AmericanSuccess
AmericanSuccess's Avatar
Please advise on installing these, I've been looking at them myself.
Did you get them with the heated seats and airbags as well?
AmericanSuccess is offline
Old 02-25-2022, 03:37 PM
  #12739
Projekt996
8th Gear
Projekt996's Avatar
Originally Posted by AmericanSuccess
Thank you, I have Eibachs and 15mm spacers at the rear and 7mm at the front.
I would recommend 15mm all round as the fronts are not out flush but they do look better than before.
Thank you! I’ve got the Eibach’s sitting in the garage awaiting install. Still piecing together new strut mounts, bump stops, etc, so I can do it all at once.
I was initially thinking of doing 12mm all around, but might just jump up to the 15mm. Thanks!
Projekt996 is offline
Old 02-25-2022, 04:42 PM
  #12740
AmericanSuccess
12mm at the rear is not enough but it might be alright at the front. The Eibachs really made the ride a lot more compliant as well as improving the looks. Only downside is scraping on things but its worth it.
Here's a couple of pics to give you a better idea on the gap.
15mm rear.
7mm Front.
Projekt996 (03-01-2022)
Old 02-25-2022, 05:46 PM
  #12741
AR_Motorwerkz
Basic Sponsor
AR_Motorwerkz's Avatar
Oh and I forgot to mention the new Michelin Pilot Sport 4s tyres. A huge difference to the old Bridgestones. Grip, ride comfort, performance in the wet are all improved.
Looks like someone had a blast! Glad you’re enjoying the ride!
AR_Motorwerkz is offline
AmericanSuccess (02-25-2022)
Old 02-25-2022, 07:43 PM
  #12742
J-Lung
J-Lung's Avatar
Default First Post!!! GoPro Enabled Rear License Plate Bracket
First Post - In March of '20 I moved up from an '18 BMW M2 to my '07 C2S.
I mainly get out on weekends with several trips per year to West Virginia and the Smokies. On previous trips, we often wished we had action camera's to capture the fun, but never took the time to make it happen. I'm going to fix that before our Spring trip coming up.
I purchased several action cameras, a tow hook front mount from Rennline, and several solid suction cup mounts for inside.
I wasn't sure how to get a rear view shot, and didn't want to rely on suction cups outside the car . . . . so I decided to see if I could use the license plate bracket. The issue with my car is that it has a V1 sensor head integrated just above the plate, so the stock bracket doesn't fit.
I had to design something custom, which I did using Fusion 360 and then printed it out on the 3D printer. I used a 1/4 20 GoPro mount on the lower license plate holes, and I think it came out pretty well.
Looking forward to trying these out - great spot to record audio and watch my buddies as they follow.
'07 C2S - new to me in March of '20.
Recent trip to WV . . . . yes we let a GT350 tag along with the 3 P cars.
CAD file of the bracket - see where the 1/4 20 hex bolts slot into the back of the bracket.
With the new GoPro Bracket Attached to the lower bolts. Note the V1 rear sensor so I can't use the stock bracket for the plate. The GoPro mounts are attached with 1/4 20 hex bolts that are locked into the bracket behind the plate.
J-Lung is offline
BLU997 (02-28-2022)
Old 02-28-2022, 08:39 AM
  #12743
rtl5009
rtl5009's Avatar
No heat (easy to add later if I decide I want it) and no airbags- the seats BARELY fit without them, I dont think you could make them work with airbags and be tall.
rtl5009 is offline
Old 02-28-2022, 01:34 PM
  #12744
AmericanSuccess
Thanks for the information and that's a shame about the airbags. I wouldn't want to be without them.
Old 02-28-2022, 02:57 PM
  #12745
BHMav8r
BHMav8r's Avatar
Received 2,806 Likes on 1,777 Posts
New motor mounts, new air filter while the box was out to get to the MM's, fixed the upper console by the rear view mirror that the detailers broke, attached the windshield washer fluid hose that I forgot to last weekend when I r&r'ed the fluid tank. leather repair guy came out and fixed a tear in my seat.
BHMav8r is online now
Old 02-28-2022, 03:14 PM
  #12746
FlatHat
FlatHat's Avatar
I finally took off my front bumper to have it re-sprayed...only two years after I decided this is something I should do...better late than never
FlatHat is offline
The following 2 users liked this post by FlatHat:
misterdega (02-28-2022), RatherJaded (03-06-2022)
Old 02-28-2022, 05:44 PM
  #12747
Darkhorse
Darkhorse's Avatar
It is almost time to install the B16 Damptronic kit in my 997.2 C4S and I decided it needs adjustable camber strut mounts with bearings instead of new factory mounts. Sadly, they're about twice the cost. This is my three season daily.
What would you do?
997.2 C4S and Bilstein B16 Damptronic kit.
Darkhorse is offline
The following 2 users liked this post by Darkhorse:
BLU997 (03-01-2022), cjarrett (03-01-2022)
Old 03-01-2022, 06:22 PM
  #12748
jle86
jle86's Avatar
Originally Posted by camn
Added Apple CarPlay to PCM 3.0 using JoyeAuto kit.
I just picked up a 997.2 pcm 3.0 and was looking into this. Are you still liking the Joyeauto? What backup camera did you go with and we’re you able to connect it to a manual transmission. I spoke to 9xx today, but they only have two shops that do work for them and I’m not sure I feel comfortable doing this work on my own yet.
jle86 is offline
Old 03-01-2022, 06:48 PM
  #12749
kellen
kellen's Avatar
I have the NM automotive version. If you can change your oil you can install this. Nonissue with a manual transmission. Rear camera is up to you, I went with the top rated one on Amazon but they have some that mount in the license plate light.
kellen is offline
jle86 (03-01-2022)
Old 03-01-2022, 08:50 PM
  #12750
jas997
jas997's Avatar
Went for a coffee!
jas997 is offline
The following 3 users liked this post by jas997:
997.1C2S (03-02-2022), jayi836 (03-10-2022), Nine9Se7en_YYC (03-06-2022)
Quick Reply: What did you do to your 997 today?
