What did you do to your 997 today?
Old 08-23-2021, 03:00 PM
  #11941
TerrestrialFlyte
TerrestrialFlyte's Avatar
Originally Posted by Phrog Phlyer
12 gallons later (drain, refill with distilled water, drain, refill with coolant) changed the coolant. After being in the car for 10 years - Looked good, tasted even better (it was really hot outside) , tested below -25, did not test Ph. 10 yrs is long enough for any "lifetime" fluid.
Wow!! I’ve read that it’s “lifetime” coolant but I guess this is something that can be done (or maybe can’t be avoided) when doing a new water pump. Not sure how all the plumbing works on this car yet but definitely something I want to do.
TerrestrialFlyte is offline
Old 08-23-2021, 04:53 PM
  #11942
Edgy01
Poseur
Edgy01's Avatar
Time to clean out grills, replace the lower freq. horn, and perhaps add some leaf grills.
Front bumper work
Edgy01 is offline
The following 2 users liked this post by Edgy01:
cvtuttle (08-28-2021), vg247 (08-25-2021)
Old 08-23-2021, 05:12 PM
  #11943
AmericanSuccess
AmericanSuccess's Avatar
Originally Posted by Carreralicious
Got a 991… brake caliper that is. Makes for some fun office artwork. 😁
Like it!
AmericanSuccess is offline
The following 2 users liked this post by AmericanSuccess:
Carreralicious (08-23-2021), frederickcook87 (08-25-2021)
Old 08-24-2021, 01:14 PM
  #11944
Coppakid
Coppakid's Avatar
Originally Posted by dandaman19
I patched a small scrape on back of leather seat and re-glued carbon trim on cup holder. Then, I got into a mess with a broken bolt that the cup holder secures to and had to re-glue that and tighten everything up again.
Hey @dandaman19 would you share what glue you used and the process to completion?
I have the same issue on my '12 997.2 TTM - carbon face plate is separating from the cupholder chassis.
Cheers
Coppakid is offline
Old 08-24-2021, 11:16 PM
  #11945
dandaman19
dandaman19's Avatar
Gorilla glue. Took out the cup holder and pulled trim off. Used goo gone to get prior adhesive off and get smooth surfaces. Laid the gorilla glue down and used chip clips to hold trim to cup holder. Let it sit for a night.
dandaman19 is offline
Old 08-24-2021, 11:26 PM
  #11946
GermanEngineerin
GermanEngineerin's Avatar
I also re-glued the carbon fibre trim. It may have been poorly re-glued by previous owner, I had to scrape/sand off old glue from both pieces. I used JB Weld and clamped it, great success.
Take the whole cup holder cassette thingy out, only 2 screws. 3.5mm key, iirc. Way easier to do this out of the car.
GermanEngineerin is offline
Old 08-25-2021, 02:09 AM
  #11947
southbay
southbay's Avatar
Originally Posted by preoctavian
Completed my first oil change. Very straight forward. Was surprised by the tight fit when seating the filter within the housing. The only annoyance was the hex bit getting stuck in the oil drain plug during removal and installation of the new plug. Some PB blaster and channel locks worked it free in both cases, but not something I want to repeat every year. Any tips?
Easy trick is to switch your ratchet direction, tap the handle, and it should free up
southbay is offline
maekwl (08-25-2021)
Old 08-25-2021, 03:15 PM
  #11948
frederickcook87
frederickcook87's Avatar
Today’s project, stripping the paddle shifters and this funky selector switch then getting the fire extinguisher mount installed. (The fire extinguisher and quick release are back ordered)
frederickcook87 is offline
Old 08-25-2021, 09:31 PM
  #11949
Jack667
Jack667's Avatar
Car was creaking like a jalopy - mainly in the rear. So I replaced rear sway bar bushings and sprayed some white lithium grease all over the rear suspension. I also removed the front section of the undertray and hit the front. Went out for a test drive and it's a huge improvement - drives like a new suspension. Hope it lasts a while. Will probably shoot some grease in every time I lift the car up.
Jack667 is offline
nicogri (08-26-2021)
Old 08-27-2021, 01:53 AM
  #11950
Full Boost
Why do I feel so left out!
Full Boost's Avatar
Finally got around to polishing the @John D II speedtech tips and giving it a bath!!!
First time i used my (early) Fathers day gift - the BigBoi - WOW - i wish i had gotten one years ago!!
Simon
Full Boost is offline
The following 3 users liked this post by Full Boost:
BLU997 (08-27-2021), frederickcook87 (08-27-2021), John D II (08-27-2021)
Old 08-27-2021, 02:59 AM
  #11951
Full Boost
Full Boost's Avatar
Then moved it back into the GarageMahal (as my wife calls it) - DW i know there is a real one in the US....
The following 6 users liked this post by Full Boost:
Busta Rib (08-27-2021), nydog (09-01-2021), quickxotica (09-02-2021), Snakebit (08-27-2021), southbay (08-27-2021), TerrestrialFlyte (08-27-2021) and 1 others liked this post. (Show less...)
Old 08-27-2021, 04:42 AM
  #11952
Wayne Smith
Wayne Smith's Avatar
Received 1,199 Likes on 766 Posts
What ceiling lights are those?
Wayne Smith is offline
The following 4 users liked this post by Wayne Smith:
ABNJOE (09-07-2021), cvtuttle (08-28-2021), Emc2design (08-30-2021), Skube (08-27-2021)
Old 08-27-2021, 12:14 PM
  #11953
frybear
frybear's Avatar
That's your garage?!?!?!?!?!?!?
frybear is offline
Old 08-27-2021, 09:56 PM
  #11954
Full Boost
Full Boost's Avatar
These are a Hexagrid 6500K LED light system. They are mains power (no need for drivers) and I sourced them direct from China - but are being re-sold (At HUGE mark up) at a few places.
A local lighting shop in AU - is now an agent.
Well worth the effort.....
Old 08-27-2021, 09:58 PM
  #11955
Full Boost
Full Boost's Avatar
I wanted more but due to planning rules - everytime we need more floor space - it cane from my garage, but I'm happy.
Fridge, Coffee machine, Audio and the cars - Its all i need!
BLU997 (08-28-2021)
Quick Reply: What did you do to your 997 today?
