What did you do to your 997 today?
Old 07-25-2020, 08:47 PM
  #10456
platinum997
platinum997's Avatar
Originally Posted by Dents666
Changed wheels again
looks great.. what suspension ?
platinum997 is offline
Old 07-26-2020, 08:25 AM
  #10457
Uwon
Uwon's Avatar
Originally Posted by brocski
DIY'd up some semi solid motor and trans mounts with 30a silicone rubber......
Please explain procedure and post driving experience. Did you gouge out the old rubber or just reinforce it?
TIA
Uwon is offline
Old 07-26-2020, 02:34 PM
  #10458
IrishLegend
IrishLegend's Avatar
Bought it!
IrishLegend is offline
The following 17 users liked this post by IrishLegend:
Achtung7 (07-26-2020), andino (07-26-2020), anewman (07-26-2020), Bleath (09-03-2020), Carreralicious (07-26-2020), Darkhorse (07-26-2020), Emc2design (07-26-2020), hamishpotter (07-26-2020), jayi836 (08-03-2020), myw (08-25-2020), PacNW3 (07-26-2020), Presto (07-27-2020), Ratchet1025 (08-01-2020), rtl5009 (07-26-2020), sandwedge (07-27-2020), tegraphile (07-27-2020), VT Blue (08-01-2020) and 12 others liked this post. (Show less...)
Old 07-26-2020, 05:12 PM
  #10459
Darkhorse
Darkhorse's Avatar
Default What paint did you use?
Originally Posted by rtl5009
I took my cluster out a few years ago to clean all the lenses and I scratched the **** out of the steering column shroud plastics. Today I repainted them and the inner door sills.
turned out great!
Darkhorse is offline
Old 07-26-2020, 05:39 PM
  #10460
brocski
brocski's Avatar
TIA
​​​​​I just reinforced new mounts with the factory rubber intact. Poured the liquid rubber in and let it set up for a day. I went with aftermarket brand mounts as this is more of an experiment than a "I know what I'm doing project".
Can't really speak to improvement over fresh stock mounts, as I bought the car with old sagging motor mounts, but there's no increase in cabin vibrations, everything feels nice and tight, and the motor sits about an inch higher than it did when looking at the tail pipes. Flexing the threaded portion of the mount after filling with urethane was more rigid than prior to filling, so I imagine there's some incremental improvement over stock... hopefully longer life too. Still waiting to do the trans mount, I have to track down a press tool or make one. I anticipate a noticeable difference with that mount as there's more empty space in the stock mount for the rubber to fill. Hopefully its a nice middle ground between the overly harsh inserts and soft stock mount.
brocski is offline
The following 4 users liked this post by brocski:
jayi836 (08-03-2020), Ni_Mo (08-01-2020), Ratchet1025 (08-01-2020), Uwon (07-27-2020)
Old 07-26-2020, 06:15 PM
  #10461
rtl5009
rtl5009's Avatar
rustoleum Matte Black Automotive lacquer
rtl5009 is offline
Old 07-26-2020, 07:30 PM
  #10462
Joehatz
Joehatz's Avatar
Detailed engine bay.
Joehatz is offline
Ironman88 (07-26-2020)
Old 07-26-2020, 08:18 PM
  #10463
Achtung7
Achtung7's Avatar
changed out the factory hood emblem with this matte black one from aase. Excellent quality, metal and exactly what I ordered and was only $40us plus shipping so about 85$ cdn which is a really good price compared to others Ive seen. However Im going to take it off, kind of looks cheap once it's on the hood for some reason.
I will put the original back on for now and might look into getting a silver+black one that they have, they have lots of different colours and variations. I think it would look good on a white paint job so I'll just put it away until I get a Macan or Cayenne, lol.
Achtung7 is offline
The following 2 users liked this post by Achtung7:
Emc2design (07-26-2020), Ni_Mo (08-01-2020)
Old 07-26-2020, 09:58 PM
  #10464
soontobe
soontobe's Avatar
full detail, 2006 997s
soontobe is offline
The following 10 users liked this post by soontobe:
Emc2design (07-26-2020), Ironman88 (07-27-2020), kru911 (07-27-2020), myw (08-25-2020), PacNW3 (07-26-2020), qikqbn (08-05-2020), rtl5009 (07-26-2020), TheTorch (07-26-2020), VT Blue (08-01-2020), WheelsB (07-27-2020) and 5 others liked this post. (Show less...)
Old 07-26-2020, 10:23 PM
  #10465
rtl5009
rtl5009's Avatar
^nice wheels
rtl5009 is offline
PacNW3 (07-26-2020)
Old 07-27-2020, 02:19 AM
  #10466
sandwedge
sandwedge's Avatar
Received 1,031 Likes on 732 Posts
Amazing for a 14 year old car.
sandwedge is offline
anewman (07-27-2020)
Old 07-27-2020, 04:52 AM
  #10467
ogi
ogi's Avatar
Default Just driving - no speed limit
ogi is offline
BLU997 (08-01-2020)
Old 08-01-2020, 07:15 AM
  #10468
Ni_Mo
Ni_Mo's Avatar
Pulled off my alcantara steering wheel for a clean, just felt it would be easier to clean it up with it off the car. It can be done while on but I didn’t want the cleaning spray spraying all over the inside.
20 mins to pull of the wheel, with the downtime once I’d disconnected the battery, took me 30 mins to give it a good clean with Sonax Alcantara cleaner.
Smells nice, the alcantara fibres “puffed” up again, they were kinda flat, I use the paddles constantly - I went with using a clean cut down sponge and a soft toothbrush for the harder to get to areas. I didn’t really scrub it, I let the foam do all the work and then lightly rubbed & brushed the wheel.
As good as new!
Next year I’ll pull it off again
Before
Before
Before
Half done
All done
Like new again!
Ni_Mo is offline
The following 6 users liked this post by Ni_Mo:
ElectricChair (08-01-2020), Emc2design (08-01-2020), FutureClassic (08-04-2020), Ironman88 (08-01-2020), mavfan909 (08-03-2020), myw (09-25-2020) and 1 others liked this post. (Show less...)
Old 08-01-2020, 12:24 PM
  #10469
mujeriega
mujeriega's Avatar
Summer is hot in AZ and with Covid, haven't been driving the car much. Finally got around to giving her a wash early this morning after probably 6 weeks without one... but dang it was still hot.
mujeriega is offline
Old 08-01-2020, 12:48 PM
  #10470
TopKatz
TopKatz's Avatar
TopKatz is offline
The following 6 users liked this post by TopKatz:
Bwoy1981 (08-01-2020), Emc2design (08-01-2020), hamishpotter (08-01-2020), Ironman88 (08-01-2020), myw (08-25-2020), qikqbn (08-05-2020) and 1 others liked this post. (Show less...)
Quick Reply: What did you do to your 997 today?
