What did you do to your 997 today?
Old 07-21-2020, 11:52 AM
  #10441
jayi836
jayi836's Avatar
Originally Posted by ru_stupid2
I put new fuel injectors in and what a PITA. The passenger side was a more difficult than the driver side (after removing the coolant tank).. pulling the tank was well worth it 100%! With the tank in place I could barely get a h d in. With the tank out I can get both arms fully in the cavity.
Nice work Just had mine cleaned, tested and reinstalled,77,000 miles.
1/2 were dripping so Raby is right.
jayi836 is offline
Ratchet1025 (07-23-2020)
Old 07-21-2020, 12:00 PM
  #10442
G.I.G.
G.I.G.'s Avatar
Originally Posted by Iceter
AFAIK, the idea that bore scoring is caused/exacerbated by leaky injectors is still just conjecture. I haven't watched a Jake Raby video in a few months but last time I did, he was saying it was just a theory. In the absence of more definitive evidence, I'm still leaning on the theory that bore scoring is a manufacturing issue.
It can't hurt to replace high-mileage injectors, and in full disclosure, I had mine replaced at 87k miles but that was in the process of trying to track down a fuel pressure leakdown situation. It might also be a good idea if your oil analysis shows fuel dilution.
As a purely preventative measure, it's terribly expensive--especially if you're paying a shop the 8 or 9 hours of labor the book calls for.
This was my understanding as well. I asked my Indy about fuel injectors on the .1 and he said not to proactively change them unless I have a problem. He told me the same thing regarding chain tensioners, which I had also inquired about.
As you pointed out, if you're experiencing high fuel dilution in your UOA's and you're not regularly taking your car on short trips, it might be worth looking into it more. But it's an expensive and time consuming task for something that doesn't have a regular maintenance interval.
Next time my car is at my Indy, I might have him check the fuel trim levels and the camshaft deviation (chain tensioners) but as long as everything is within the specs it should be, I'm not going to change the fuel injectors nor the chain tensioners.
G.I.G. is offline
Old 07-21-2020, 04:16 PM
  #10443
marsh1665
marsh1665's Avatar
installed Fabspeed headers. install would have been insanely quick and easy, but i broke a bolt while torquing them down. 2 hours later, i got it out and finished up. they sounds so nice and full
marsh1665 is offline
The following 2 users liked this post by marsh1665:
frederickcook87 (07-23-2020), tegraphile (07-25-2020)
Old 07-21-2020, 10:19 PM
  #10444
rtl5009
rtl5009's Avatar
Set up a spare oil pan to be ready for a 1/2 qt extension. Will swap next oil change!
rtl5009 is offline
Ratchet1025 (07-22-2020)
Old 07-23-2020, 03:43 AM
  #10445
Dents666
Dents666's Avatar
Changed wheels again🤦🏼‍♂️😂😂
Dents666 is offline
The following 4 users liked this post by Dents666:
CT944 (07-25-2020), frederickcook87 (07-23-2020), Ratchet1025 (07-23-2020), rtl5009 (07-25-2020)
Old 07-23-2020, 08:04 AM
  #10446
benznotmercedes
benznotmercedes's Avatar
Passenger side window regulator! Not too bad DIY honestly. Hardest part was getting the door panel clips to pop out.
benznotmercedes is offline
Old 07-23-2020, 08:45 AM
  #10447
mavfan909
mavfan909's Avatar
Default Got it
Originally Posted by Ohio Performance
thanks for the link. We really need a thread for “stuff your embarrassed to ask about”
mavfan909 is offline
Old 07-24-2020, 11:30 PM
  #10448
415CPA
415CPA's Avatar
Installed a 991 lip and pumped gas
415CPA is offline
The following 8 users liked this post by 415CPA:
Bwoy1981 (07-25-2020), ElectricChair (07-25-2020), Emc2design (07-25-2020), hamishpotter (07-25-2020), irnnr (07-25-2020), myw (08-25-2020), Ratchet1025 (07-25-2020), rtl5009 (07-25-2020) and 3 others liked this post. (Show less...)
Old 07-25-2020, 12:36 AM
  #10449
CT944
CT944's Avatar
Very nice
CT944 is offline
415CPA (07-25-2020)
Old 07-25-2020, 01:59 AM
  #10450
tegraphile
tegraphile's Avatar
Decided to try a new flavor (Castrol Edge 5w-40)
DIY ceramic coat (Carpro CQuartz UK 3.0), 48 hours post application
tegraphile is offline
The following 2 users liked this post by tegraphile:
Ratchet1025 (07-25-2020), VT Blue (08-01-2020)
Old 07-25-2020, 08:04 AM
  #10451
rtl5009
rtl5009's Avatar
Edge is good oil.
rtl5009 is offline
tegraphile (07-27-2020)
Old 07-25-2020, 01:45 PM
  #10452
brocski
brocski's Avatar
DIY'd up some semi solid motor and trans mounts with 30a silicone rubber, replaced my oil pressure switch because of a p1163 fault code, and performed my first oil service on the car. Adding 5w-40 plus Ceratec for piece of mind at my high mileage... have had great experiences with LiquiMoly products of all types. My old VWs love the MoS2 moly additive. Will likely run that or MolyGen oil in the 997 after this cycle with Ceratec.
brocski is offline
The following 2 users liked this post by brocski:
Ratchet1025 (07-26-2020), tegraphile (07-25-2020)
Old 07-25-2020, 02:14 PM
  #10453
tegraphile
tegraphile's Avatar
Originally Posted by rtl5009
Edge is good oil.
Yeah, looking forward to an oil analysis. Fit my criteria of 5w-40, easy to purchase locally (picked up 20qt), inexpensive, and A40 spec.
Quicksilver997S (07-27-2020)
Old 07-25-2020, 06:51 PM
  #10454
Emc2design
Basic Site Sponsor
Emc2design's Avatar
@415CPA that looks MEAN! In a good way, Thanks for sharing.
Visit us online https://emc2design.com
By Porsche enthusiasts
For Porsche enthusiasts
Emc2design is offline
The following 3 users liked this post by Emc2design:
415CPA (07-25-2020), hamishpotter (10-21-2020), myw (08-25-2020)
Old 07-25-2020, 08:36 PM
  #10455
415CPA
415CPA's Avatar
Thanks @Emc2design !! Got inspired by your car and the all black look.
415CPA is offline
Quick Reply: What did you do to your 997 today?
