What did you do to your 997 today?
Old 09-29-2019, 07:18 PM
  #8971
ace37
ace37's Avatar
Originally Posted by Joehatz
Went from this
To This
As a person who typically likes both black wheels and the Martini livery, I still think your car looks much better after the update! 👍
ace37 is offline
anewman (09-30-2019)
Old 09-29-2019, 07:48 PM
  #8972
quickxotica
quickxotica's Avatar
Originally Posted by e92insg
Carbon illuminated outer door sills. And my steering is on the right side
Looks cool. Did you do this install yourself or have it done professionally? And how difficult was the wiring?
quickxotica is offline
Old 09-29-2019, 08:14 PM
  #8973
Tkersting
Tkersting's Avatar
Realized my car that I bought nearly 2 years ago has a AWE tuning exhaust. Don’t ask how it took me that long to figure it out.
Tkersting is offline
Old 09-29-2019, 10:10 PM
  #8974
e92insg
e92insg's Avatar
I did the installation of the sills myself, ie removed the stock sills, cleaned up all the gunk, then stuck on the carbon sills.
I went to an audio shop to hook up the wiring, which took all of 20 minutes. Didn't open the door cards, just attached to footwell lights. Works perfectly!
e92insg is offline
Old 09-30-2019, 04:52 AM
  #8975
Zoefhaus
Zoefhaus's Avatar
Big improvement, but would look even better with "regular" silver wheels.
Zoefhaus is offline
Uwon (09-30-2019)
Old 09-30-2019, 01:48 PM
  #8976
Carreralicious
Carreralicious's Avatar
Agree...looks better than before, but white wheels are a little pimp my ride. Silver would look better.
Carreralicious is offline
Zoefhaus (10-04-2019)
Old 09-30-2019, 04:07 PM
  #8977
911URGE
911URGE's Avatar
Updated my Foxwell NT520 Pro to the latest Porsche SW (9-17-2019) and voila! Service Reminder reset works now. 2006 997.1 C2S with no Service Reminder Yeah!
911URGE is offline
Old 09-30-2019, 04:10 PM
  #8978
911mdp997
911mdp997's Avatar
How did you update the Foxwell NT520?
911mdp997 is offline
Old 09-30-2019, 07:34 PM
  #8979
911URGE
911URGE's Avatar
I used the info in this link.
https://rennlist.com/forums/general-...tructions.html
911URGE is offline
Old 10-04-2019, 07:30 AM
  #8980
mujeriega
mujeriega's Avatar
Changed the battery... hopefully this next one will also last over 5 yrs.
mujeriega is offline
Old 10-04-2019, 02:35 PM
  #8981
GoldenGorilla
GoldenGorilla's Avatar
Got some new soap for the foam cannon and bucket. Adams has an apple cider fall soap. I like apple cider, so I'm happy to use it year round. Works really well in the cannon and great in the bucket.
I noticed coming back from a recent trip that Adams Polishes is in Thornton (North of Denver) and decided to go check out their shop. Got a wheel woolie so I could reach to the back of the rear wheel barrels, a few polishing pads and some waffle drying towels (which are going to work great).
Also as some follow up to my DIY ceramic coating, I'm at 4 months and the water is beading and sheeting off the paint same as new. I've applied Turtle Wax seal n shine over top a couple times, but I don't like the way it looks over dark paint. It streaks during the wipe off, so just the ceramic coating and occasionally a detailing spray after drying.
GoldenGorilla is offline
Old 10-04-2019, 02:50 PM
  #8982
Astraelraen
Astraelraen's Avatar
Whats the benefit of using a foam cannon versus a rinseless such as Optimum No-Rinse? My 911 is a semi-daily driver, but it doesn't see lots of dirt/grime/buildup. I have pretty much exclusively washed it with Optimum No-Rinse since I got it and the results are pretty good. I'm not sure I would use the Optimum product if it was heavily soiled though.
I can also use Optimum in the garage, which I consider a bonus.
Astraelraen is offline
Old 10-04-2019, 10:24 PM
  #8983
GoldenGorilla
The foam cannon soap is thick, saturates the dirt and pulls it off the paint. The foam also helps lubricate the paint as you wash. Anything to reduce swirls on black paint.
Old 10-04-2019, 11:44 PM
  #8984
Petza914
Petza914's Avatar
Received 6,519 Likes on 4,153 Posts
+1
You also use less soap and have much thicker bubbles for the entire wash vs the old soap and water in the bucket method. I used my cannon to wash the 928 and Cayenne today.
I actually have 2 of them. In one I mix Sonax wheel cleaner up to the first line, then add hot water and use that to spray the wheels. In the other, I put car wash soap to the first line then hot water to fill it up. They're labeled so they don't get mixed up just in case there's contamination - don't really want to spray wheel cleaner at my paint.
Petza914 is offline
Old 10-05-2019, 12:34 AM
  #8985
TheTorch
TheTorch's Avatar
Default Installed DSC TPC PASM Controller
Yesterday I installed the DSC TPC PASM Controller
This mod took about a minute, which is crazy. First impressions, out of the box, no tuning yet:
  • Below 30mph in normal PASM mode: may have made the ride a little stiffer, compliance about the same. At low speeds, it seems like stock PASM mode to me more or less.
  • Above 30mph in normal PASM mode: highway driving seems much improved, absorbs poor pavement better. On winding roads: definitely recovers from dips much quicker and more composed. Turn in a bit sharper. Hard bumps still jarring but recovery is much faster.
  • in PASM Sport mode: major improvement, bounciness is gone, jarring is gone. Stock PASM Sport mode was almost unusable -- the road has to be nearly perfect or it was too jarring and jiggly. With the TPC controller I can use it on most roads, other than the very worst ones.
Overall an improvement. Not night and day, but good. The sweet spot seems to be how much it improves mid speed (30-75mph), winding-road spirited driving.
TheTorch is offline
The following 4 users liked this post by TheTorch:
anewman (10-07-2019), crazy997 (10-05-2019), irnnr (10-07-2019), jayi836 (10-05-2019)
Quick Reply: What did you do to your 997 today?
