Note to Porsche classic - 997 PCCM plus request
The following 5 users liked this post by RaBe:
Bavarian 997 (12-03-2022),
ekam (12-03-2022),
G.I.G. (12-03-2022),
PowerFlower (12-03-2022),
wjk_glynn (12-03-2022)
#319
It looks similar to the 996 PCCM+ unit, which has a breakout box with the the USB connector. When I installed the 996 version in my GT3, the instructions denote mounting it in the storage cubby underneath the head unit. I elected to mount it in the glove box and use a wireless CarPlay dongle to connect to the head unit from my phone.
#321
Thanks @RaBe ! Looks very complete and plug & play, even comes with the MOST loopback
The microphone is a bit of a cop out if I’m seeing correctly, there’s a company that sells one that fits in the OEM spot but I forgot who it was. That one has a minijack but should be easy to convert?
Easy to forget given this is in the 997 forums but count the 987 owners as well 😉 My RS60 deserves this!
@RaBe You might be the luckiest 997 owner in the world at the moment. lol
#322
BTW, I think I read somewhere (this thread? another?) the new PCCM for our 997 is not compatible with backup cameras. Is that accurate? If I am going to replace the head unit, that's when I'd be wanting to add a backup camera - would be a bummer if the OEM option doesn't support that addition.
PowerFlower (12-04-2022)
#323
@PowerFlower I think you are talking about the Enfig MIC-POR1. I was planning to grab one myself to use with the previous owner's Mr12Volt bluetooth unit. They added a terrible mic and this one should work great. Unfortunately, because of where the Mr12Volt is installed, I might have to remove the whole dash to get to it. That said, at this point maybe I'll wait a tad longer and decide whether to get the PCCM instead.
#324
For the backup camera, this is what I read from the 997 PCCM Plus FAQ.
https://prod.pcom.porsche.com/int/-/...4597A83F0.ashx
"12. Will the factory-installed rear view camera of my first-generation Cayenne continue to be supported?? Yes, the factory-installed rear view camera is connected to the PCCM Plus by means of a multi-adapter"
Not sure if the multi-adapter is included or not.
PowerFlower (12-05-2022)
#325
#326
#327
In the US, it's not offered yet. Apparently someone reached out to Suncoast and they said they were thinking March'23. When I did see it listed on US sites, the MSRP was a little under $1500 with retailers offering it for around $1300. You can check post 233 where I posted a screenshot.
#329
For the PCM3 and up, you can get this: https://www.nmautomotive.co.uk/shop-...roid-auto-kits -- which is cheaper and retains your current unit!
