996 Forum 1999-2005
What did you do to your 996 today?
Old 01-26-2020, 10:56 PM
  #2476
Gingerman
Gingerman's Avatar
Default Changed my right front axle (c4)
Thanks the charlieaf92 for the video tutorial. The outer CV was clicking quite a bit in tight turns and even a little when driving straight. Some odd bolt sizes on a few parts, like two that were not a 17 and not a 19. We ended up using some English sixes to get it done. Felt great on the test drive.
Old 01-27-2020, 09:10 AM
  #2477
wkf94025
wkf94025's Avatar
Fun Sunday for my C2 coupe and I.
  • Drove my favorite tight, windy roads pre-dawn for an hour, albeit in light rain.
  • Got my manometer and oil cap set up for AOS check. Happy with readings (~5.5in).
  • Updated my Foxwell OBD2 reader and can now check cam variations (0* and -3*).
  • Used my new second floor jack for a twin lift of the back end to torque up oil drain plug with new torque wrench.
Bore scoping next on the list. Grateful for all the shared expertise by members of this forum.
Old 01-27-2020, 08:04 PM
  #2478
Jengah
Jengah's Avatar
Originally Posted by 808Bill
I suggest you shop around and avoid Pelican Parts! Amozon for a fraction of Pelican will save you over and over in the long run, next RockAuto...
There’s value in purchasing from the places that participate in the Porsche/BMW community. I’m happy to pay a few bucks more to Pelican for all the great info they put out. Can’t remember the last time I read a DIY on Amazon... (coming from a small business owner). ;-)
The following 3 users liked this post by Jengah:
85eurocarrera (01-28-2020), Gingerman (01-27-2020), Ratchet1025 (01-28-2020)
Old 01-27-2020, 09:36 PM
  #2479
Brian_C
Brian_C's Avatar
Changed the oil. Forgot the crush washer...reinstalled Drain plug with crush washer with ninja-like speed.
Made mental note to use 0w-40 next winter.
Spent 30 minutes with a wire brush removing road salt. Still worth it.
Received new Rein motor mounts today
Old 01-28-2020, 05:14 AM
  #2480
Jure
Jure's Avatar
Changed the oil and recorded a video along the way! It's surely one of the most common and easy jobs out there, but still figured I'd use it to practice my DIY making skills.
The following 5 users liked this post by Jure:
Battery Guy (01-29-2020), Brian_C (01-28-2020), Ratchet1025 (01-28-2020), Robert Allinson (01-29-2020), supersquid (01-31-2020)
Old 01-28-2020, 01:35 PM
  #2481
808Bill
808Bill's Avatar
https://www.youtube.com/watch?v=I8SfuOgYrfM
Good job!
Short and right to the point.
The following 2 users liked this post by 808Bill:
Jure (01-28-2020), Robert Allinson (01-29-2020)
Old 01-28-2020, 11:41 PM
  #2482
sgt1372
sgt1372's Avatar
Originally Posted by Idaho911
If you want to ditch the wheel locks altogether I have some extra bolts you can have. I ordered a set off Ebay, and used them to replace my wheel locks (key also missing), and replace some bolts that were very rusty.
Thanks for the offer but, if the dealer can buy me a replacement key, I'll just go w/that.
Old 01-28-2020, 11:46 PM
  #2483
sgt1372
sgt1372's Avatar
Ouch!
Have you looked under the seats for the Lug key, or in the frunk/spare tire cover?
I'd ditch the locking lugs all together!
Looked all over the car; no wheel lock key to be found. Of course, prior owner said he didn't have it either. He owned car for several years and the tires on the car are relatively new. So, that really doesn't compute but I don't see why he'd lie about it if he had it. Whatever . . .
Anyway, just going to order a replacement key from the dealer, assuming they can identify which key needs to be purchased. I'm planning to buy a new OEM set of wheels for the car which will probably require new lugs because I'm switching from aftermarket 19s to stock 18s. Would rather buy new OEM lugs to match the new OEM wheels when the time comes.
Update: The dealer identified the wheel lock key as #58 and a new one has been ordered. Delivery/pickup pending in a couple of days.
The following 2 users liked this post by sgt1372:
Ratchet1025 (01-29-2020), Robert Allinson (01-29-2020)
Old 01-29-2020, 06:28 AM
  #2484
Robert Allinson
3rd Gear
Robert Allinson's Avatar
Great!
DIY Skills and YouTube earning skills Why not upload more videos and apply for monetization?
Old 01-30-2020, 12:30 PM
  #2485
cwbrown
cwbrown's Avatar
Originally Posted by pauldvazquez
Oh, yeah, also removed the cigarette lighter and replaced it with a double USB charger outlet. The car is no longer a completely unmodified, bone stock car.
Maybe post some video and photos so the rest of us can tackle this mod; I'm planning to do this over the weekend.
Dyno sheets would help as well....thanks
Old 01-30-2020, 12:35 PM
  #2486
Scott at Team Harco
Just a car guy
Scott at Team Harco's Avatar
Dyno sheets. Yeah - I'd like to know how much torque I've gained from this mod as well.
Old 01-31-2020, 12:33 AM
  #2487
pauldvazquez
pauldvazquez's Avatar
Uh...apparently I was pretty challenged just doing the project, much less taking pictures and creating videos of the project. A few takeaways from the project:
I used the Mantra kit as supplied by Crutchfield. I am pretty happy with the trim kit. The instructions could have been a little better, but all in all were pretty thorough.
I opted for the wiring kit. The wiring kit worked well. I did not connect the brake switch wire to the brake switch. I used a brake bypass kit that negates the need to have to have the brake on to perform certain functions of the head unit. Do a brake wire bypass search on Amazon, they have several.
The upholstered side trim on each side of the center stack is removed by pulling the forward ends loose out, away from their clips, then sliding it rearward, toward you. I forgot that minor detail, something I should have known about with all the different write ups and videos I had seen and read.
I decided to remove the plastic lower center stack frame, which made it much easier to route the HVAC control wiring into the lowest opening. It only required removing 4 screws to do that. The only down side I can see with doing this is the reveal line between the upper and lower center stacks is a bit wider than it was before I did the work. I might take the side trims off and see if I can raise the lower center stack by shimming it up to take out any slop in the screw slots on the frame.
The portion of the wiring route between the rear camera location and the head unit is somewhat challenging. There is very thick and relatively firm firm foam rubber insulation behind all the interior trim panels. I ended up removing all the rear deck panels, the passenger side, interior rear quarter panel trim and the section of foam insulation at the rear quarter panel and the door threshold, as well as the passenger footwell under dash panel. As I wrote originally, I was a little sore the next day from the contortions required to do that work. I used a 16” long 3/8” drill bit to create a space for the wiring to pass by removing the tail light, and the grommet the tail light wiring passes through, then drilled through the main wiring grommet and through the foam insulation. You must be careful here. You do not want to damage that wire bundle. My sunroof drain also passed through near that location. I did not know about the sunroof drain until after I had pushed the drill bit through. Luckily, I missed it by a 1/2” or so. I used a 3’ long HVAC zip tie that I had in my collection of stuff to push through the grommet and foam, then taped the wiring to it and pulled it through the grommet and the foam.
One snafu that cost an hour or so of delay was the HVAC unit would not slide completely into the lower space. It would get within around 3/8” of being flush, but would not go further. After much head scratching and measuring I finally determined that the ~1/8” ridges on the top, rear sides, about 2” long, needed to be ground down slightly. Once I did that, the unit fit in the space perfectly.
The microphone for the phone was just clipped to the top of the A pillar trim. I am not really sold on that location, but it probably is the ideal location, acoustically. I watched one video where one of the dummy switch fillers on the drivers side of the console was drilled to fit the diameter of the microphone perfectly. That installation looked ridiculously good. I may reroute my microphone to near that location and temporarily mount it test out the performance. If it performs at least close to the A-pillar location, I think I will do the permanent mount in the console.
I have not received the camera yet. Ordered straight from China, right before the Lunar New Year celebration started. Also right before the coronavirus outbreak started...so it might be awhile before I receive that. It will mount utilizing one of the license plate light lens locations. A combination light/camera assembly is made to fit the license plate light opening, maintaining the light and providing the mount for the camera. I will update the project when I receive the camera....some day.
Hopefully this makes sense. Feel free to ask questions, I would be happy to respond.
The following 2 users liked this post by pauldvazquez:
az968gpw (02-01-2020), Battery Guy (02-05-2020)
Old 02-01-2020, 02:02 PM
  #2488
az968gpw
az968gpw's Avatar
Finished installing the mini-split unit in my garage so now i will have a much more comfortable environment for the overdue projects left to do on my 996, and for the future ones, and there are always future ones.. Don't have to wear mittens now, which makes it much easier to loosen nuts and bolts.
The following 2 users liked this post by az968gpw:
Gingerman (02-01-2020), latonnelier (02-01-2020)
Old 02-01-2020, 07:05 PM
  #2489
JTT
JTT's Avatar
You're going to love it! I put one in my new garage when I built it a few years back. Best EVER. Warm, dry and cool in summer...brilliant!
Old 02-01-2020, 07:31 PM
  #2490
az968gpw
az968gpw's Avatar
Was in the garage today working on my car and it was quite pleasant. Back to working in a t-shirt rather than a sweatshirt and warm cap.
Quick Reply: What did you do to your 996 today?
