Thinkdiag Magic
#633
There are settings for how the rear brakes will blink during emergency braking situations. You can determine at what G-forces it triggers, when it stops and how long it runs. As in, you stab the brakes hard and the brakes blink rapidly. Under normal braking it doesn't happen, they just come on solid when you press the brake pedal.
#634
#635
Running back to programming PSE...
So, after changing the COV for the valves, i have restored my NON PSE behavior. The button lights up, i hear a click (but not the valves fully opening) and nothing happens. I went back and checked my coding, but im assuming there is a step im either missing, or is not possible to do with ThinkDiag (Need PIWIS).
As of right now, the car works like this
PSE on/off---> At idle the valves are open, past 5mph, they close, then will reopen past 3300rpm with moderate pressure. Im assuming this is how it SHOULD world with a Non-PSE car.
I have ran the accusation of the valves in the Rear End Electronics section and can verify that they do indeed work, nothing is stuck.
I understand this is a ThinkDiag thread, but this somewhat applies to it.
#636
I already have emergency braking working on my car and I did not change this code. I agree that it is possible that this code may have something to do with emergency braking. If it does, the question is how does changing this code to yes change the operation of emergency braking?
#637
#638
If anyone want's a Thinkdiag, barely used (maybe 4 times), PM me. $50 shipped. I upgraded to a PIWIS 3.
#641
#642
https://www.planet-9.com/posts/2196907/
c615586 (05-28-2024)
#643
I successfully programed the PSE and have it fully working with only using ThinkDiag. I made a separate thread for it https://rennlist.com/forums/991/1413...thinkdiag.html
Another fun thing i did today, that i haven't seen talked about, is adding the Sport/Sport Plus display in the cluster. When i added a .2 wheel to my .1, i lost the indications on the ugly .1 PDK wheel.
Coding for it is:
Instrument Cluster -> Code/Brush Hiding -> Brush/hidden Modified -> Coding Value -> Coding Byte 3 -- Sport Mode Display = YES (Default=no)
Coding for it is:
The following 2 users liked this post by RwdConnor:
PJK3 (07-09-2024),
thesaintusa (05-27-2024)
#644
Very strange thing happened this morning. I've been all over the car looking for sports plus activation using think diag for a while and it started working with morning with no code. I'm still using stock switch console so I've had to replace switch button functions for testing so stock programming on those buttons was replaced. 2012 991.1S
1. I coded the PSE valves to button #2 on the right (previously coded to auto start/stop) and this is working as expected. Opens valves when button is pushed and turn on whenever Sport or sports plus is turned on.
2. Coded sports plus to the 2nd botton on the left (previously coded to PASM) and this turns on sports plus on cluster as well as changing engine/PDK settings. Shifting happens at redline.
When I turn on the Sports Plus button the "sports Plus" display comes up on the cluster, the car ECU/TCU change to sports plus mode but I'm not seeing any changes on the PCM or SC clock so I'm assuming the change has not been applied to the PCM. Any ideas?
#645
I would appreciate it if you would me let know what coding you used so far to get sport plus to work.
However, it is possible that getting sport chrono to work on the PCM needs the activation code. I would look to see if I could find any codes in the PCM but you have a different PCM than I have.
