Thinkdiag Magic
Old 06-16-2024, 06:07 PM
  #691
Wayne Smith
Wayne Smith's Avatar
Received 1,210 Likes on 776 Posts
Originally Posted by itbme
I'm a little unclear on what works on the 991.1 vs 991.2
Clearly the GT3 doesn't work due to the 991.2 updated steering.
But it's unclear of comfort windows/rolldown with fob works, or illuminated dashboard?
A friend has been unsuccessful getting GT3 steering to work on his 991.1 TTS as well. Just putting this out here in case anyone has specific instructions ...
Old 06-16-2024, 06:11 PM
  #692
bmxtreme
bmxtreme's Avatar
The GT3 steering option just disables your PSP which disables any assist and gives you a more raw feeling. If you don't have PSP, you won't feel any difference.
Old 06-16-2024, 06:47 PM
  #693
nsau
nsau's Avatar
I don’t think that’s true. My car didn’t have power steering plus and the GT3 software made the steering completely different, in a good way.
If I remember correctly, the TTS has a different steering rack than the regular Carrera and the GT3, so the ECU is different.
Old 06-16-2024, 11:45 PM
  #694
Wayne Smith
Thanks for the responses!!!
Old 06-19-2024, 03:21 PM
  #695
Porsche_nuts
Porsche_nuts's Avatar
Received 1,202 Likes on 725 Posts
My car stopped chirping when I lock it. Changed siren, still no chirp. Researching the issue, read that chirps can be programmed on or off. Anybody know how to do that?
Old 06-19-2024, 03:25 PM
  #696
Ken718B
Ken718B's Avatar
Here is the code:
Front-end Electronics: Coding value- General- Acoustic feedback for central locking (only permitted in North America)
My car was set to yes to make it chirp when locking.
Old 06-19-2024, 04:41 PM
  #697
Porsche_nuts
@Ken718B hey thanks a lot. Went through the coding, and Thinkdiag already had the code set to yes. Accepted it anyway and still no chirping. I think a sensor in the rear hatch has gone bad or is misaligned as this happened after I finished changing the oil. Get solid door LED when I lock it for about 5 seconds before it starts to blink.
Thanks anyway for the info.
Old 06-19-2024, 05:32 PM
  #698
Ken718B
Ken718B's Avatar
I thought it was odd that the code would have changed by itself. Good luck finding the issue!
Old 06-19-2024, 07:25 PM
  #699
biggreek
biggreek's Avatar
So I recently installed new exhaust on my .2 GTS. And it seems as if the exhaust valves are reversed. On normal mode, they're open, and in sport/sport plus, they're closed. I've gone thru the coding options in the Think diag app, one in the ECM and one in Rear Electronics. Both either are "Yes" or "No" for exhaust flap operation. I didn't do both at the same time, but I did do one and the other separately. The ECM option just removed my console button functionality, but it functioned with the steering wheel selector. The "rear electronics" option just kept the valve closed at all times.
I assume OEM flap is normally open and this one is normally closed. (With no vac applied).
Is there a way to reverse the exhaust flap operation? I don't want it to close during high rpm, that defeats the purpose... Any help is appreciated. Thanks.
Edited for context: this is a VR performance exhaust, it was a prototype and they supplied an aftermarket vacuum box for running the flaps. When I bought the exhaust they couldn't confirm the flap operation, theirs vs oem. I obviously don't want to use the aftermarket box, since this has oem functionality already there.
Old 06-21-2024, 03:44 PM
  #700
Irfan
Irfan's Avatar
Android tablet just came in, but play store will not let me download? “This app won’t work for your device”. Any suggestions how to get around it?
Old 06-21-2024, 04:23 PM
  #701
nsau
nsau's Avatar
You have to “side load” it directly from the think diag site. It doesn’t work from the android app store but you can install directly from think diag site
The following 2 users liked this post by nsau:
911T4ME (06-21-2024), Irfan (06-21-2024)
Old 06-21-2024, 04:26 PM
  #702
Irfan
Irfan's Avatar
do I need to download Porsche software? Also can the GT3 steering soft installed with IOS? That’s all I care about at the moment, if I can’t get the android to work.
Old 06-21-2024, 05:31 PM
  #703
innout
innout's Avatar
I struggled with my iphone. Buying and Android tablet solved all my connection issues.
Old 06-21-2024, 05:55 PM
  #704
Irfan
Irfan's Avatar
someone needs to make a guide for dummies. Lol. Still can’t figure it out on the tablet.
Old 06-21-2024, 06:21 PM
  #705
innout
innout's Avatar
Another thing i will mention is, I first tried a cheapo 50 dollar Android tablet (like this one
Amazon Amazon
) which had BT connection issues, so I returned it. Instead I bought a Samsung Galaxy Tab A9 which worked flawlessly. So, i tried iPhone (fail) => iPad (fail) => chinese android 14 tablet (fail) => Samsung tablet (success)
The following 2 users liked this post by innout:
Irfan (06-21-2024), martkat (07-04-2024)
Quick Reply: Thinkdiag Magic
