Thinkdiag Magic
#601
Air Conditioning: Coding value- Default Driving State Coding Value = Eco Off {Default: Eco ON}
Air Conditioning: Coding value- Default Driving State Coding Value Last Mode = No {Default: No}
#602
If you set Auto Stop Start to default to off rather than last mode, how does that change what happens to PASM?
#603
Ken718B (05-21-2024)
#605
#607
Unfortunately, it doesnt change PASM. PASM still remembers last state - if off it stays off after restart when you select sport or sport +, but PASM should always be on for those modes. Ill just have to remember to manually select PASM when i want it (mostly at the track)
#608
If you coded to remember last mode you changed the second code to yes. Did you change the second code back to the default of no? Just checking.
#609
Hello All,
I have a 991.1S non PSE and I've been playing around with some button coding to try and activate the exhaust valves using button on console. I can turn flaps on/off by going to actuation in rear end electronics. When I operate them I can here the flaps open/close.
I then went into the AC module:
Just putting this out there in case anyone else is tinkering with this. I'd like to figure out how to code one of the buttons to control exhause valves and then buy used PSE center muffler for a swap.
- changed BKE/right/button 2 from auto on/off to sports exhaust but no change
- took apart button console and removed front cover to expose rubber puah buttons. Then assigned sports exhaust to BKE/right/button 3 that was not assigned to anything but no change.
RwdConnor (05-23-2024)
#610
Hello All,
You made sure to activate the exhaust button in the Aircon>brush/hidden section right?
As of right now, i can hear the valves doing something when i click the button, however im not sure if theyre fully open. Clicking the button with the car on isnt doing anything. However, when clicking the button with the car off, i hear a little sound. Im suspecting my change over valve has gone (or is going) so my first step is to replace that. If that doesn't work, then ill run new lines from the COV.
Thinking about making a youtube video once i figure everything out. There isnt a single thread dedicated to coding in PSE on S cars.
Porsche_nuts (05-23-2024)
#611
Funny enough, im trying to do this same thing right now to my non PSE .1 S. I believe i got it done.
#612
yes. I did code the sport exhaust in AC section so it's there. What button did you assign the "sports exhaust" to on the console? When I use the 'actuate" option in "rear end electronics" I can definate hear the exhaust change so that same change should be heard when it's activated using the console button.
I just tried the Rear End Electronics actuator section and i heard nothing at all. However when i click the PSE button, i hear something happening back there, though it sounds like the valves are opening 10-20%. Since the valve is controlled on vaccum, should the car be running/driving when messing with the button? Im wondering that if because i havent driven the car yet, that there is not enough vaccum to open and close.
Another odd thing is, when i started the car for the first time this morning, i can hear the exhaust open for MAYBE 1 second, then back to the same position it seems to always be in, PSE on/off. I ordered the COV this morning, id assumg that there was a leak in the lines, however, if there were then the valves would be open 100% of the time. Interesting.
#613
In the beginning, i put the PSE button Under the Auto Start/Stop button (this was before coding) i went in and activated the Sports exhaust and then oddly enough, the Auto S/S button was now PSE and PSE was Auto S/S. You can define the placement of the buttons in the BKE tab (i believe that's what its called). But i pulled the buttons off and switched them instead to have the correct layout.
I also pulled bottom off the console and just controlled by pushing buttons without the cover on so that gave me access to all the buttons not just the ones that were setup on the cover. Did you order just the PSE button? If so where did you buy it? Once I get this working I'm going to hunt down a PSE center muffler since I've confirmed with others that the difference in sound from the -S stock center muffler is significant so having the button if nice but the muffler swap is what will make biggest difference.
Catharpin (05-23-2024)
#614
#615
I got this working now as well. I took apart the center console and just plugged in the ciruit board half so I could operate all the buttons even the ones that had dummys on the front. I assigned sport exhaust to the 3rd button on the right hand side that was not assinged to anything and the sports exhaust is operating with the button. Also see the LED works so if the sports exhaust is off it automatically turns on when the sports button is turned on which I think is how it should work. Only issue i have is no PSE button to replace the blank in the front cover. I've looked all over and only see the option to uby the entire switch console/assmebly no way to buy just the PSE button. I may take some pics and video to post in case anyone else wants to give it a try.
