Was coding EBD and got a little confused with all the menus and steps and may have changed something I should not have. Can anyone confirm that 0 is the correct default setting for EBD stop lamp flashing - speed off
Unfortunately I could not see these options/codes for my 991.2.
Thanks for posting though.
Try typing in 'comfort functions' in the search bar? With my Launch X431, I couldn't find everything by skimming the menus, but searching for the keywords would pop them up.
Thanks.
On my 718, that code is set to 1. I assume that is the factory setting because I don't believe I ever changed it.
@slowrey did you ever get this figured out? I’m having the same issue on my 991.2
Originally Posted by slowrey
Tried to do this on my 2017 991.2, and no dice. Funny thing is that I didn't have a menu that said: Additional Instrument: Watch but I did have one that said Additional Instrument: Clock. I also have a coding value PWM_maxS (set at 30) and also a PWM_MaxS 2. When I tried the first one it gave me a write failed error. Not sure what the issue was. Would be great to hear if other's have the same issue or if I'm an oddball.
Mine are all set to "KI Side Vehicle" but I also see that when I select any of the keys all the options that come up have "KI" in front of them like "KI-Sportchrono". I see in your list that you have some option that have the "KI" in front but also others that don't. Do you have Key 1-4 as options? if so what are they set to? Not sure if Keys are for keyfob's 1-4 that can be programmed to the car.
On my car the multifunction codes for each key show the function I have selected in the mfd. The code I previously sent shows next track which is what I have it set to. I changed it using the MFD to sports plus and it now shows the attached. I can also change it using my thinkdiag rather than the MFD and that also changes what function the joker button is set to.
I tried this but in my case I can change the coding for that same line and that change is not reflected on MF display. So my joker button is currently set to “vehicle display” using MF controls. When i change that line of coding to “PCM source” there’s no change on cluster.
I was able to find how to add an activation code for sport chrono to the air conditioning module using my Thinkdiag. I also see how to add an activation code for cruise control, multifunction steering wheel and steering wheel heater to the electronic steering wheel module. I did not see where to add activation codes for the PCM . Can someone take a look and see if they can find it? It is odd because I get a popup when I enter the PCM module that many functions require activation codes.
I have attached instructions for the ones I have found.
@Ken718B Does this enable the MFD menu in the instrument cluster? I’m retrofitting a mfd wheel and can’t figure out how to get that menu. Thanks!
My 718 came but a multifunction wheel so I have not swapped one in . However, try the joker button in the instrument cluster that @josepaq mentioned. see attached. You may also have to enable the multifunction wheel in the steering wheel electronic module. See attached.
