Thinkdiag Magic
Old 04-06-2024, 05:28 PM
  #466
Porsche_nuts
Porsche_nuts's Avatar
Received 1,185 Likes on 712 Posts
Can attest that the open frunk without unlocking doors does work. I could not follow the steps as per the PDF, so I did a search using 'lid" and was able to write the code.
Note: writing this code does work - with the frunk open the doors remain locked. However, the flashing "locked" red light goes off, even though door is locked.
Old 04-06-2024, 05:49 PM
  #467
Wayne Smith
Wayne Smith's Avatar
Received 1,195 Likes on 762 Posts
Had anyone been able to install GT3 steering in AWD cars?
Old 04-08-2024, 11:58 AM
  #468
duxsi
duxsi's Avatar
Hi folks.
Any worthwhile differences between the Original Thinkdiag and the Thinkdiag2 (other than twice the price)?
Thank you
Old 04-08-2024, 05:55 PM
  #469
Ken718B
Ken718B's Avatar
Originally Posted by duxsi
Hi folks.
Thank you
This website compares the two. I don’t see anything that makes it worth the extra cost. Let me know if anyone disagrees.
http://blog.obdii365.com/2023/10/08/...vs-thinkdiag2/
Old 04-09-2024, 12:03 PM
  #470
GoTime
GoTime's Avatar
Got my car out of storage and coded the temp and boost changes...just for anyone with no technical skills afraid of breaking **** like me, that couldn't have been easier.
Old 04-09-2024, 01:50 PM
  #471
RwdConnor
RwdConnor's Avatar
Is there a master file for all the coding functions? Just ordered the dongle and im excited to use it. Ill miss OBD11 from my audi
Old 04-09-2024, 03:46 PM
  #472
RicB
RicB's Avatar
Hello - A couple of questions:
1. I'm confused by some of the pricing shown on the website. As I understand, it comes with one year of updates. But after that year the following applies?
Per reset service/$49.95/year works for multi cars. Per software for one car model/$39.95/year, $70/year with full software.
You can select any of the manufacturer software in ThinkStore, and you can use them for free for one year.
Manufacturer Software Price for Each: $39.95/year
Reset Software Price for Each: $49.95/year
What do they mean by "per reset service" vs "per software"?
2. I have a 2017 C2S. That is the last year that shows up in the Coverage page. So it won't work for later model years?
Thanks.
Old 04-10-2024, 08:29 PM
  #473
ltcjmramos
ltcjmramos's Avatar
Originally Posted by joserpaq
I tried this on 991.1 but the sound symposer controller was not found with system scan and when I try to select it the unit says it’s not found. So couldn’t adjust it.
Has anyone found how to eliminate the Sound Symposer? Do we have a Sound Imposer?
Old 04-11-2024, 11:32 AM
  #474
Ken718B
Ken718B's Avatar
There are kits you can buy to disable it. You can also remove the bulkhead and plug the hole with a sock (or something else) to drown out the sound entering the cabin.
A user on the 718 forum suggested that there may be coding to disable it but I haven’t seen anyone who has identified it yet. Here is the post:
https://www.718forum.com/threads/718...45#post-393315
Old 04-11-2024, 11:35 AM
  #475
ltcjmramos
ltcjmramos's Avatar
Thanks, i did put a plug in it.
Z06jerry (04-18-2024)
Old 04-17-2024, 07:06 PM
  #476
boxdriver
boxdriver's Avatar
I am installing PSE on my car with the exhaust button in the center console. Does anyone know if the thinkdiag can set that button to work or is that something that is beyond this? It would be cheaper to order this tool than take it to the dealer to set that up, but I am thinking that this can't do things like that.
Old 04-17-2024, 07:30 PM
  #477
joserpaq
joserpaq's Avatar
Question for you. Do you have 991.1S? If so did you just replace center muffler? Did you just install PSE button or did you have run any new cables, valves or vacuum lines?
Old 04-18-2024, 09:09 AM
  #478
boxdriver
boxdriver's Avatar
Joserpaq, I have a 981. I will be installing the entire PSE system. The mufflers, valves, vacuum lines, cables, switch, and will need to program it.
Old 04-18-2024, 01:56 PM
  #479
joserpaq
joserpaq's Avatar
So I've been playing with coding to see what other options could be added to my 991.1S non SC. I installed a SC stopwatch and turned on SC in AC and PCM then programmed the PASM button to turn on SC but no dice. Seams like even if I changed the button assignment in the "AC" section the button continues to control the original item it was set to operate. I thought maybe this was due to the code that is needed to active SC in PCM and AC according to others that have done this using PIWIS. After some additional reading I thought I'd try to program one of the existing buttons to program Sport exhaust to operate the COV valves even if it's on my non PSE center muffler. I can operate the valves in thinkdiag by actuating them but when I assinged "sports exhaust" to the auto on/off button location it didn't work. Any idea on how to move around the button functions on the switch console using coding?
Old 04-19-2024, 07:37 PM
  #480
skru_fase
skru_fase's Avatar
Just a quick thank you for everyone that has contributed their findings in this thread. I finally got around to coding my 991.1 GTS last week. Most of the items weren't too exciting, but the steering change is worth the price of admission without a doubt. One of the best (cheap) mods for the 991.1 imo.
Quick Reply: Thinkdiag Magic
