Orthojoe's track build journal
#1156
Originally Posted by Manifold
Wound up replacing the rear tires, looking forward to trying the car with both front and rear grip this weekend at a new track.
Here's my hypothesis regarding what's happening with the rear tires (could be totally wrong): the RWS and e-diff are reducing the rear tire wear, enabling the rear tires to seemingly outlast the front tires, but putting all that power down is causing the tires to heat cycle out before the tread is worn. By contrast, the front tires aren't getting hammered by the power, and thus less issue with heat cycling, but are working hard to find grip when cornering, especially during corner entry, and thus still have decent grip by the time the tread is worn.
#1157
The first set of 20 inch Cup2's, still have a fair amount of tread left rear tread left, so if there's an issue with the rears, my guess is it may come down to heat cycles. The OEM tire sets problem is left front wear. My tire supplier is loath to, and recommending against, replace only one front tire. Best guess is, with track use, the Cups may be running x2 front pair per rear set, subject to whatever limits heat cycling might have on the rear rubber.
I'll try to figure that out with using the new 20" front tire rubber on the 2nd set of OEM 20" wheels.
As for the 19" rims, product availability has me using 235/40 rubber in the front with 325/30x19's in the rear. Have to see if the present guestimated @2 to 1 fronts to rear wear ratio would remain the same or?????? I'm wondering as my guess is the rear 325 tires will/should be running a little bit cooler, and there is a bit more material to wear vs. the OEM 305mm 20" fitment; and conversely the fronts, at 235 vs. OEM 245, a bit hotter, and slightly less rubber. mlp
#1158
Did it with my 15 year old son. Needed his help to get the bar in /out.
Definitely an 8 hour job or so. Take your time. Measure three (or five) times, cut once.
https://rennlist.com/forums/991-gt3/...llation-6.html
#1159
I bought a set of Dunlops more than a month ago because Cup2s were hard to get. I'll be using these Dunlops on the track for the first time in two weeks.
Can anyone comment on what hot tire pressures work best with the Dunlops? There have been many posts here about tire pressures for Cup2s and Trofeo Rs, but I don't recall any posts about the best tire pressure range for the Dunlops.
Thanks!
Thanks!
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
#1160
Thanks!![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Thanks!
#1161
Are you running a new set of Trofeo R's or take off's? Will be interested to see the laptime diff between the R's and Cup2's when both are new.
#1162
Originally Posted by RobertR1
Hey Joe,
#1163
You guys may have covered this, but I'm seeing 991 GT3s now running 19s with R7s successfully. The only change required is the flip of a lower control arm bolt. Has anyone on this thread invested in a set of 19s and run Hoosiers or the like? If so, how much better were they than the cup 2s or Trofeos? Thx
#1164
FWIW, I just spent yesterday at our local track on 19" Forgelines sporting 235/40 x19 in the front and 325/30 x19 in the rear to come as close to the OEM 20" final tire diameter sizes. As best I could tell, the 235F/325R 19" tire combo worked well - I couldn't tell much difference vs. the stock 245F/305R fitment. HTH
#1165
Received 1,224 Likes
New. No difference in times or grip (1.3G) between the 2. However, I was running the wrong pressures with trofeo R (they run much lower pressure than cup2), and then ran in 113F weather, so not a fair comparison. I'm hoping I'll be able to get a fair comparison with this next set of tires now that I know the proper pressure.
#1166
Originally Posted by MaxLTV
For the record, I tried using the same psc2s I had during our extra-toasty private day, and they only do 1.1g. That's worse than supersports . so basically they cooked on that day, even though fronts have about 1 day of tread and rears about 50%. Thinking about trying Trofeos next.
#1168
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,382 Likes
^ Wear pattern of the Trofeo R doesn't look bad, but so far I'm not seeing a strong case for using them instead of Sport Cup 2, considering grip, durability, usability in rain, needed camber, and cost?
#1169
The grip is at least as good as MPSC2, but I'm hoping to prove that they grip better at Laguna next week!
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
