Consolidated 991RS thread
#2851
I...believe most of the 1-2 seconds per lap difference between the GT3 and GT3RS on US length Tracks listed by www.fastestlaps.com
lies in the far more effective Wing on the RS, and not the small weight saving.
Saludos,
Eduardo
Carmel
I...believe most of the 1-2 seconds per lap difference between the GT3 and GT3RS on US length Tracks listed by www.fastestlaps.com lies in the far more effective Wing on the RS, and not the small weight saving.
#2856
Thats likely because the rear deck venting is for different purposes. By using the RSR side venting, there will be plenty of air for the engine, and likely some will now directed for cooling, and thus the exit venting on the rear deck, in which this left over air will now likely be part of the aero as well. The GT3 uses the traditional ram air intake of prior designs.
#2857
Lane: Are you talking .1 997 gt3 to .1 997 gt3 RS? Or .2 997 gt3 to .2 997 gt3 RS (3.8) or .2 997 gt3 RS (4.0)? If you are talking .2 997 gt3 to gt3 RS (3.8), wasn't gearing on that RS much better for track work & the 26mm extension to the front & wider front tires made turn-in much better too on that model...to account for the faster per lap differences on that RS?
Saludos,
Eduardo
Carmel
Sccchiii: I think Lane is talking about previous generations (.1 or .2 997 gt3/RS) and not current 991 gt3 or upcoming 991 gt3 RS!
Saludos,
Eduardo
Carmel
#2858
and well within the rear fender widths. Off to see how it works at Sebring tomorrow.
#2859
#2860
Bingo...especially since the original wing was developed in concert with the rest of the engine lid aerodynamics as a wing element also. Will be interested in your report after pushing the car on the front straight at Sebring. And then transitioning into the first fast sweeping left hander at the end of the straight
#2861
By the way, after the initial ducktail design of the production MY1973 911 RS (photo #2), the factory heavily modified the rear 'spoiler' on some of the 1973 RSR for particular competition venues where they thought it would help. The attached are photos (#3 & 4) of the 'Targa Florio' car which later was owned & restored to its original factory specs by a friend - Peter Kitchak! Notice the major modifications on the rear fenders to matched the ducktail on this factory '73 911 racing vehicle!
Saludos,
Eduardo
Carmel
#2862
I wouldn't worry too much about that. He's testing it tomorrow and if it feels like too much rear downforce and not enough grip in front, there's an easy solution to that by using front canards. If they still don't provide enough front downforce, then a modified front lip should do the trick in concert with the canards. That's what Testing is for
#2863
SirMixaLot said it best:
Also, check out the cover of Paper
If Lane's wing needs a little additional front splitter action, then I am still in. I can't wait to hear about Sebring. Just like SirMixaLot said, if you change the splitter and the wing, you've got ..... an "LA face with an Oakland booty!" Baby got grip!
#2864
#2865
The fastest way around a race track is not necessarily finding the most down force. It is a balance between down force, tire patch, suspension, etc. The formula is quite complex and would require a lot of the "testing" you are talking about. Unless you are prepared to spend huge money re-engineering what Porsche has optimized then it is really a futile adventure. With a bigger wing stuck into more air you are then stressing the rear suspension big time. That then means different springs, wheels and tires. Now that you have the rear set-up different you need to get into the front suspension set-up, wheels and tires and additional aero. What concerns me the most is not that he will not turn the lap times improvement he is looking for with the bigger wing but that he is introducing a change in balance that is potentially unbalance and thus unsafe. At the very least he will be stressing the ear suspension more and possibly pushing it past it's designed safety perimeters. For posing on the street, no big deal. But pushing it consistently and hard a the track...I would be VERY careful. Not something I would personally do without a very planned and well thought out engineering exercise.
