928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 06-11-2020, 12:03 AM
  #8071
928 GT R
928 GT R's Avatar
Received 5,365 Likes on 2,062 Posts
Pete,
It is on the north shore of Little Traverse Bay on Lake Michigan. About three miles from our home...
Today I did nothing on any 928... But I did work on the garage design...
Old 06-11-2020, 01:38 PM
  #8072
Dark shark
Dark shark's Avatar
Smile
Today I scheduled the body work to repair the quarter panel on my 84 928S.
Old 06-11-2020, 08:05 PM
  #8073
808c2s
808c2s's Avatar
Took the S3 out for a drive today after a 2-3 wks hiatus to replace the rear leaking A/C defroster, changing to R134, replacing the broken original Blaupunkt Radio with another same refurbished one, and doing a 928 Intl RMB swap. That RMB along with Ott's Catless X-Pipe really wakes up the 5L V8. The sound is just intoxicating as the needle sweeps over the rev range, and after 5k, OMG, Nirvana . I should have done this much sooner
Old 06-12-2020, 10:58 PM
  #8074
AirtekHVAC
AirtekHVAC's Avatar
Cleaned out the inside of the euro to get her ready for stereo /amp/speaker/sub wiring, and installed the old seat from my 82 into her temporarily so I can finally move the car in and out without sitting on a piece of 4x4 post, which not only killed my herniated disc, but also caused me some tail-bone pain!
Old 06-14-2020, 01:00 PM
  #8075
jej3
jej3's Avatar
Lost the battle for Fuel Pump and Fuel filter replacement. Prior Fuel Pump and filter had been on so long they essentially were a bear to get the S Pipe off between the pump and filter. Got it undone, put it all back together with new filter and fuel pump and couldn't stop the leaking. Turns out the S-Pipe is leaking at a junction by the check valve.
Time to put in an order with overnight shipping from 928intl.
I've got other projects to keep me occupied but UGGHHHH
Old 06-14-2020, 02:13 PM
  #8076
Christopher Zach
Christopher Zach's Avatar
Spent the weekend repacking the grease in the front hubs. Nice shiny green Mercedes Benz high temp bearing grease replaced whatever was in there before. New rotors and pads are also on, just need to wait for the rotor screws to arrive (Monday, sigh) and I'll be able to close everything up and start working on bleeding the brakes from the rear forward.... I think it's passenger rear, then driver's rear then passenger front then driver's front with outboard caliper first then inboard. Or something like that :-)
Old 06-14-2020, 09:37 PM
  #8077
slownrusty
slownrusty's Avatar
Giving the suspension and brakes some much needed love over the past few months. New ball joints, tie-rod ends, rack boots, Bilsteins, strut mounts, brake rotors & pads, pad sensors, paint, fender linings, lots of powder coat down to new lug nuts. Before and after pictures.
The following 4 users liked this post by slownrusty:
aseem (06-16-2020), Bertrand Daoust (06-15-2020), Brent A. (06-16-2020), Geza (06-15-2020)
Old 06-14-2020, 10:01 PM
  #8078
Tony
Tony's Avatar
Nice ^^^^^
flushed the cooling system..
Old 06-14-2020, 10:13 PM
  #8079
islaTurbine
islaTurbine's Avatar
Looks great. Did you use a steam cleaner? If so, which model?
I readjusted the rear latch on my hatch. It would previously only shut with a “gentle” slam. Turns out that someone had removed the shim under the lower strike. The PET confirms two part numbers for two different thickness shims. Adding a 1mm shim back fixed her right up.
Old 06-14-2020, 11:36 PM
  #8080
16vsilverstreak
16vsilverstreak's Avatar
Default Signal Light Trouble Shooting
Old 06-15-2020, 12:32 AM
  #8081
slownrusty
slownrusty's Avatar
Thanks.
I scrubbed and scrubbed followed by sanding and the repainted them. Good prep was the key.
islaTurbine (06-15-2020)
Old 06-15-2020, 05:48 AM
  #8082
Vipermn1961
Vipermn1961's Avatar
LOOKS GREAT!!!!
slownrusty (06-15-2020)
Old 06-15-2020, 08:18 AM
  #8083
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,317 Likes on 498 Posts
A lot of elbow grease in there SR!
Beautiful.
Old 06-16-2020, 11:56 AM
  #8084
928nut
928nut's Avatar
Gone to the Dark Side .... or .... the Enlightened Side, depending on your religion ;-)
The following 2 users liked this post by 928nut:
Bertrand Daoust (06-16-2020), PorKen (06-16-2020)
Old 06-16-2020, 01:05 PM
  #8085
Petza914
Petza914's Avatar
Received 6,513 Likes on 4,148 Posts
Welcome to the enlightened side from another '79 owner (but with an '83 motor).
Quick Reply: So what did you do to your 928 Today......
