So what did you do to your 928 Today......
#2146
Decided to postpone the AT transmission mounts and compound polish instead. Sadly, the old girl looks better from a distance. The act of polishing every single surface in detail was depressing. Kinda of like watching **** zoomed in too close.
Some things just look nicer from a distance.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
#2147
I finally got off my azz and started to work on it.
First was the passenger seat as the manual gears had jammed and started to strip.
- Replaced gears and the passenger seat works.
Continued to remove both side trays, glove box, Both console sides, removed stereo and getting ready to remove console to tidy up wiring and install Paul's custom window switch's.
Installing the GPS and rear cam as well
![Name: IMG_1727.jpg
Size: 85.9 KB](https://rennlist.com/forums/attachments/928-forum/1208551d1501364932-so-what-did-you-do-to-your-928-today-img_1727.jpg)
![Name: IMG_1724.jpg
Size: 73.5 KB](https://rennlist.com/forums/attachments/928-forum/1208552d1501364932-so-what-did-you-do-to-your-928-today-img_1724.jpg)
#2149
Replaced both coil wires and the drivers-side coil.
#2153
Got movin on the 928leathershop pod and dash install. WOW it's awesome. Still need to get the center console back and wrap things back up. THANKS ROB BUDD!!
![](http://www.nospoons.com/Porsche/dash-928.jpg)
#2154
#2157
Installed my "new" used PSD unit. Flushed and bled with "new" used check valve from 928 Intl. and a new brake hose from 928sRUs. I also have a "new" used slave but couldn't get one of the bolts to break loose so I hope my old one is not leaking
When I do the TT refresh this summer I'll address the bolt issue. Also replaced transmission fluid with fresh Mobil 1 synth and new filter. Nothing in the pan but black/gray smear from clutch linings so I am pleased (considering the unknown past history.) The new PSD has also cleared my ABS fault from the bad Transverse Lock Solenoid. A long, but good day. Now to do some search as to why my hatch release motor cycles but wont release the hatch.
Mike
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Mike
#2158
Drove her up the Merritt to watch the Giants Packers game at a buddies house in CT. And home again. Man it's cold. That cooler thermostat ain't the greatest helper to the heater.
#2160
Electron Wrangler
I think you will need some very thin spring steel JB Welded on each side - at least this is what worked for me finally after several tries via other methods
The original materials choice here just wasn't very good - over time these get more and more brittle - In the end I cut mine back to have a bigger spring steel section - worked like a charm - have fixed about 8 of these that way now...
BTW when I say spring steel - A spring from a ball point pen will work as will a slightly bigger spring section - nothing much bigger though...
Alan
