OEM Navigation Retrofit DIY
#661
Check GPS Menu in M.I.B GEM.
It can take a couple of minutes before a SAT fix is established.
I have seen issues from time to time with these cheap antennas. For me they always worked.
#662
It says, "open" in MIB. Does it need to acquire a signal first before it shows as installed in MIB? I've only tried it while in my garage and without the engine cranked.
#663
Try again outside with a clear view of the sky...
#664
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/1881x759/screenshot_2023_07_05_140223_164d6eec9de8d9a11ef42c9cbe76613f1e0a4361.png)
#665
I did notice that even after doing the install several times the swdlautorun did not have an underscore in front of it. Isn't the car supposed to put that in automatically?
#666
Decided to try this out. Bought a 64gb SD card. Put in my windows computer. Went to format but it's only giving my exFAT as an option. Not FAT32. Will exFat work or should I find an older laptop and try to find Fat32. Someone at work may have one.
CaneTLOTW (07-05-2023)
#667
#670
- Your picture above shows a USB memory device, we are talking about SD cards for the map update, correct?
- Now assuming a SD card, is it formatted in FAT32?
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/363x481/mih2_pcm_4_map_update_sd_card_format_366b9529fde0068969cf2f8792d98f23378ed4d5.png)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/585x352/mih2_pcm_4_map_update_sd_card_files_1c6626f84b13549324833b21961eec3ce0c99f6a.png)
#671
Because SD card format and size was recently mentioned... I thought I would ask/mention a couple of things. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1077x1416/screenshot_2023_07_05_170309_f640b7661b2afdcd16b606af13757697f1fdecc9.png)
#672
Just another heads up, although I have been successful using a micro SDHC card in an adapter for the map update, I also have had a lot of grief with poor quality microSD to SD adapters failing during the update, so if you are using one, try a different adapter.
#673
Hmmm, So it saw that there was a SD card in Slot 1 but when you selected it, it didn't find the update?
#674
It is not going to help to find a different computer, it is because of the size of the SD card, here is a program tool to allow you to format the SD card or even a USB stick to FAT32. How to Format 64GB SD Card to FAT32 Free Windows 10: 3 Ways (minitool.com)
Westcoast (07-06-2023)
