Any Rennlisters from New Zealand?
Old 08-10-2013, 08:30 AM
  #4231
Macca
Macca's Avatar
Originally Posted by John McM
Macca, full auto. The drive out of the slow corners is outstanding. The box always seems to know what I'm likely to need. You can see that on the straight out of turn 9.
While it's great to drop 8 seconds in one go I can't but think it's less satisfying than pedaling the 964. Full air con, George FM on the radio, hands never having to leave the wheel. Power to burn. ABS , PSM. You get the idea.
Figures John. Bloody smooth trace showing minimal up shift loss of pace. Must make a difference to the cars mechanical cadence. Keeps it a bit latter and more predictable during the shift.
Sean joins the boys tomorrow!
Old 08-11-2013, 02:58 AM
  #4232
John McM
John McM's Avatar
OK. Peter's best lap was #5 of the last session....1.19.649! Here compared to his best recorded lap on 20 July. Blue is 11/8, red is 20/7.
Old 08-11-2013, 03:09 AM
  #4233
John McM
John McM's Avatar
Sorry Doug, not sure what to compare your best semi-wet lap against so chose Peter's best dry lap. Yours was 1.25.092
Old 08-11-2013, 03:17 AM
  #4234
kiwi 911
kiwi 911's Avatar
Well done Peter - into the 1.19's. I hope that's not a damp track time..??? - no pressure Dave and John.............
All you have to do now is strip a little weight with racing seats, removing the back seats, spare tire and some RS brakes, and you will be challenging Sean in the 1.16's............
Sorry for the no show - ended up having to work the entire day..........
Old 08-11-2013, 03:20 AM
  #4235
kiwi 911
kiwi 911's Avatar
Interesting analysis - Peter is carrying more speed into all the corners and achieving the same higher speed at the end of each straight.
Looks to be holding the car in 4th over front straight too.
Old 08-11-2013, 03:25 AM
  #4236
peterC2S
peterC2S's Avatar
Times from the PCNZ day on Sat are now online:
http://www.marktime.co.nz/results/po...aland/13/08/10
John - I think you have some explaining to do with 1.22 recorded in the regularity trials... which has a limit at 1.28....!
Thanks for collecting the data again today. Doug was at his best in the wet so not fair to compare with a dry lap! He reeled me in on all of the wet sessions - I ran the AIM on a couple of wet sessions so you should have a comparative - be interesting to see just how much better Doug was on the corners.
Old 08-11-2013, 03:38 AM
  #4237
John McM
John McM's Avatar
Unfortunately the wet laps are all over the place. We need some more AIMs out there so we can compare like with like on the same run.
Some pics from the day. Mr Black and Peter's C4 now branded.
Old 08-11-2013, 03:49 AM
  #4238
John McM
John McM's Avatar
Roll out for the last session
Old 08-11-2013, 03:57 AM
  #4239
John McM
John McM's Avatar
My 1.22.98 was not the only shame on the day! Not many of us have gone backwards up the main straight.
Old 08-11-2013, 04:22 AM
  #4240
peterC2S
peterC2S's Avatar
Indeed - and I thought that had gone unnoticed. Note to self for next time "listen to the briefing..."
Old 08-11-2013, 04:23 AM
  #4241
kiwi 911
kiwi 911's Avatar
$95K for a 997T, seems only yesterday they where $250K used???
Looks like 997's are heading for the serious depreciation curve (with the help of cheap UK imports)...............
http://www.trademe.co.nz/motors/used...-625716093.htm
Old 08-11-2013, 04:25 AM
  #4242
John McM
John McM's Avatar
Captured on video for later use....
Old 08-11-2013, 04:42 AM
  #4243
O2GO
O2GO's Avatar
Thanks John for sharing this. It certainly would be pretty cool to have a number of units and overlay each other on the same run. Wound be interesting to compare speed in/out of the corners on the same run. The conditions today were pretty variable and I loved the challenge and it was nice to be able to keep up for a change in the Boxster with it being wet. Evens out the horsepower advantages :-). Thanks again.
Old 08-11-2013, 04:54 AM
  #4244
John McM
John McM's Avatar
Not totally dry but probably close to perfect balance for tyre temp. More pressure for Dave, his C2 should be 1 sec faster in the 1.18's. Seriously some great times being posted from 20 year old technology. It's a pity that I didn't have my C4 there today. The 964s would have been even more dominant in numbers. Sean seems unlikely to be back at HD soon, but Sam will hopefully be around more often.
Old 08-11-2013, 05:06 AM
  #4245
John McM
John McM's Avatar
Variable is the word. Fully wet and all times were in the 1.30+, partially dry and they drop at least 6 seconds. Too hard to compare.
Not sure if it breaks the Prestigio rules but we could 'race' indirectly with just a couple of units. Safer than actual racing, as illustrated by Dave's pirouette in front of me on turn 8. If the red mist had descended I would have collected him, possibly t-boning him in the driver door.
Quick Reply: Any Rennlisters from New Zealand?
