Any Rennlisters from New Zealand?
Originally Posted by esonefour
So a GL5 75w90 any particular flavour I was going to try Kendall as my dad rates it in his drag car,
have read that people would rather use bacon fat than redline. Most of my gearbox parts are here I just need to pull the trigger.
50 buck semi fix would be great.
I reckon the Middle East countries have more chance of agreement than a group of petrol heads talking about engine oil, transmission oil, brake pads, brake fluid and tyres. To make it worse there are 'enablers' out there fanning the flames.
Here's Dan showing me a synchro working. I'd love to get him to give a proper talk on this. Personally I can't see how a different oil will make a poorly functioning synchro better when it's job is to slow the gear down to mesh
Once had a Mitsi Pajero which was undriveable, would catch every gear up to 4th changing up or down.
Redline 250wt shockproof oil in that sucker and good as gold, most recently had mate with a 08 Polo GTI would catch 2nd unless shifted with a big pause between gears, same oil drove like a new car.............he couldn't believe it.
Not saying this is a permanent fix but oil does make a huge difference.
Believe it or not but it does, proven it 3 times now. Once had a Mitsi Pajero which was undriveable, would catch every gear up to 4th changing up or down. Redline 250wt shockproof oil in that sucker and good as gold, most recently had mate with a 08 Polo GTI would catch 2nd unless shifted with a big pause between gears, same oil drove like a new car.............he couldn't believe it. Not saying this is a permanent fix but oil does make a huge difference.
Btw I finished the engine tonight. Valve covers on, engine tin and heat shields fitted. A spanner check tomorrow night then I'll deal to the Cat. 10 easy HP there.
Had a trawl through the Early 911 FB page today. Looks like a great little local home brew community. Good spirit and some interesting cars. Love some of the ST/RSR/IROC style replicas. As I said they dont fit int my lifestyle at least not right now, but they are quite fun to look at.
Looking through the photos from the Milford Xmas the cars that interested me most were the "hot rods". Really like Shannons RUF replica and on the modern front the 997 GTS looked really nice.
I only just came across this photo essay of the '15 Porsche reunion on Stanceworks. I periodically cruise the site for its eye candy. Andrew Ritter is one of my favourite car snappers along with Sean Klingelhoefer and Linhbergh although there styles are more commercial
http://www.stanceworks.com/2015/10/p...-reunion-2015/
Absolutely. Keeping oil clean is the best way of improving gearbox life!
Here's an analysis I did on bearing life versus load and filtration "quality".
Better filtration allows you to run higher loads for the same life expectancy.
(gears and bearings behave similarly)
Cheers,
Mike
Cheers,
Mike
Some years ago I purchased a 964/993RS front hood strut stick (removed the need for the front hood shocks). The hood shocks at front and rear way 350grams a pair. So 700 grams front and rear. Its not the weight that is the issue just the fact that they fail over time (Im on my second set after 15 years), that they are relatively expensive (for what they are) and are a PITA to remove and refit (with their circlips).
Over the years the RS front hood stick has sat in my storage shed reminding me one day when the existing struts loose their oomph I need to fit this. Unfortunately it requires riveting to the front hood (as the factory did with the 96 & 993 RS).
Ive been thinking of other alternatives (as I don't like non reversible modifications to carriage work).
Today I purchased a Seine systems front + rear assembly (the factory never made one). Its designed for the 993/964 (heavier rear lids due to electric spoiler - thus beefed up build) and has a carbon rod with a nice heime jointed end. Can be fitted without drilling using factory existing mounting holes. Seine systems in CA make them and Ive been meaning to bag them for years. A USA Youshop opportunity to freight came up with some clothes my wife purchased so that was all the excuse needed. $50 USD fr the rear. Not sure when I will fit it...here is the rear one, pictures of the front to follow shortly...
Mike. Interesting graph. Really a no brainer. If its being used on the track/Targa or under load change the gearbox oil minimum annually with the engine oil. Reminds me, I need t add that to the 993 service sheet for Feb!
John. Looking good! The engine is now looking worthy of the car! Looks like you will be n the road before Xmas!
Are those Daves valve covers fitted? If so give us an update and some piccies...
No, they are the original covers, but powder coated. Dave's CNC shop has a pre Xmas rush and couldn't be sure of the timeframe. I need the engine ready for this weekend's install and even if they arrived tonight I couldn't anodise them in time.
I've booked in for a WOF pre Xmas so I'm optimistic of a running car by the 19th. There might be surprises yet, but as each assembly is sorted that reduces.
Here is the attachment for the front "Ultimate Strut". Fits to factory position 964/993 and is beefy enough for steel lids. $40 USD.
