Any Rennlisters from New Zealand?
Jesus. $500 NZD plus for a single new rear indicator lamp for a 964!!!! Unbelievable. I think it's probably time someone made a great replica foe $200 as happens without the 993.
That said the $250 per side lens only DIY is a viable alternative though you need to be an enthusiast to give it a try. They will be writing off 964 on light rear impact soon just for the cost of the bumper, indicators and rear reflectors!! Make sure it's insured for the track next season John!!
Jake. Just received the invoice for the tyres. Appears price held. Will email introduce you to the suppliers By PM and you can ask for a quote for PSS & MPSC2 etc.
There are different centre versions for US & ROW so the options narrow down markedly if you want the correct look. I'll be doing it all for ~ $1,200
Warwick, Steve has racing spares so I may try a real roughy first, but I have my spare as a back up. Faint heart never squired a fair maiden and all that.
Just for you Dave, war wounds fixed on the plastic underbelly. Interesting to note that the plastic is not weldable so epoxy and mat was the only way to sort this.
^^^^ A thing of beauty Dave.
http://www.roadandtrack.com/new-cars...gt3-rsr-rumor/
^^^ Marketing Dept going hard at Porsche GT3 RSR, along a 991R and a Gt4 club sport all within weeks - no shortage of rare limited production Pcars coming out??
GT4 "Clubsport" is the only one of those rumors I put any credence in right now (its a done deal as I understand)...911R I think was confused reporting on 911 GTS "Rennsport Reunion V edition". 911 GT3 RSR for the road smells wrong. There will be a limited edition low volume GT3 before the 991 gen cars are over but Im not sure it will be anything like they think it might in the article....Id love to be wrong tho....can only imagine what the new metal will be costing in NZ next year?
On to things that are real the new BMW M2 broke cover today....
Just working through the parts list and costs eek
This is what Herman is getting
Replace control arm bushes
Replace rear spring plates
Replace all spark plugs
Replace oil
Replace distributor caps and rotors
Replace alternator fan
Replace Rear Main seal
Place sleeve on nose bearing
Replace rear reflector
Replace lenses on rear indicators
Replace side indicator plastics
Replace rear licence light fittings
Repair cracks in rear bumper, shark fin, and side sill plastics
Replace CV boot and regrease CV joint
Replace two hard clutch lines
Fit speed bleeders to clutch slave cylinder and diff locks
Replace all body seals except window seals
Replace felt window scrapers
Replace all black door and window trim
Replace front portion of carpet
Repair cracks in door pocket screw areas
Replace inner door handles
Replace door sill covers and carpet trim trip
Replace Porsche bonnet emblem
Adjust valve clearance
Replace fuel filter
Re-anodise Gemballa aluminium pedals
Refurb rear shocks
Replace gearbox diff clutch pack
Replace synchros in 2nd, 3rd and 4th gears
Replace third gear set
Replace transmission mount
Replace door wire loom rubber bellows
Replace 3rd/4th gear guide sleeve
Replace dog gear on 4th gear set
Fit reinforcement kits to both door checks
Repair damage to hinges from hyper extended driver door
Repair bumps from bonnet closing on over filled frunk
Replace crank ref sensor
Replace or refurb upper valve covers
Gut catalytic converter
Powder coat engine tin
Powder coat intake runners
Replace oil breather pipe
Fit exhaust cut out
Fit PDAS light
Respray car in L908 Grand Prix White
Replace oil
Replace fuel filter
Refurb rear shocks
Fit exhaust cut out
Fit PDAS light
Layup carbon fibre over front splitter
Replace distributor belt
New front frunk struts
Replace rear decals
Replace engine decals
Plus replace hot air hoses in engine.
Replace rear decals
There is a lot of value. I've gone a bit over the top. Most of it I will keep as Herman is aiming for no excuses refurb whereas a rough 964 would be enhanced by the cast offs here. At some stage I will own other 964s in addition to Herman. As Steve says, don't sell parts to a car you still own.
John. Impressive list. But as you look like you are repairing not replacing most stuff apart from gearbox bits and hard lines etc that are beyond economical repair I shouldn't think there's a lot there another 964 owner would crave? I have followed Steves advice and now have a few hundred Kgs of take off parts from my 993. I wish Steve was paying my storage costs LOL!
Great day at track today. I was the only aircooled there.
John, am I too late for a banner? Blue writing on black (or would black on blue look better)? Also I have some polished 964 exhaust heat shields I can donate if they hold any interest?
