Any Rennlisters from New Zealand?
Phil. Don't speak bad of the loafers!!
Those Caymans are dangerous aye. My last trip to NZ I had one crash in front of me at the track and one crAsh behind me on the Targa. I will be staying clear of the Caymans during the SITT although this will be hard as at last count there were 5 participating!
pS I cannot compete with cucumber Neil. He who walks away from 720 degree high speed aquaplane has been gifted by the gods!
Far out you boys have been busy with the handbags... get home today and I'm 4 pages behind house prices, bubbles and bubba! The Cayman will be the next collectable as the numbers are dropping fast Video Link: http://www.liveleak.com/view?i=3ac_1427743476
As previously discussed, the list of work I've done to the Turbo in my ownership (1.5 years/34k km). I will crack the ton with the coolant lines being pinned this week...
- Minor fixes: Gear Selector/Seat/Rotor Swap (installed on the wrong side...)/Radiator Cap/Dent Repair
- Passport 8500ci Plus
- Minor Maintanence
- Replace Rear Tyres (RE050A)
- Detail, Paint Touch up and Opti Coat
- GMG Lowering Springs
- Dension 500S Bluetooth Unit
- Replace TPMS Sensors
- Replace CV Boot
- Replace Transmission Sump Gasket & Oil (round 1)
- Michelin Pilot Suport Sport Tyres
- Replace CV Boot
- Replacement set of OEM Wheels cheaper to buy second hand off Rennlist than get the curbing fixed locally!
- TPC DSC Unit third party PASM replacement, gives full dynamic range to PASM shocks, recommended for 997 PASM cars
- Swap Wheels, install second TPMS
- Wheel Alignment
- Replace Transmission Sump Gasket & Oil (round 2)
- Wheel Alignment
- Transmission Connector/Plug Repair (round 3, proper fix by auto trans)
- Aero Front Lips x 2
- Magnetic Stone Guards
- Major Maintenance
- Plugs, Coils, Water Pump, Water Thermostat, Tandem Oil Pump, Castrol SRF, Exhaust Hardware, Rear Brake Pads
- Torque Solutions Transmission Mount Inserts
- Rennline Tuneable Engine Mounts
- LED Interior Bulbs
- Guibo/Flex Disc, Intake Hose
- Coolant Line Repair
As previously discussed, the list of work I've done to the Turbo in my ownership. I will crack the ton with the coolant lines being pinned this week...[*]Minor fixes: Gear Selector/Seat/Rotor Swap (installed on the wrong side...)/Radiator Cap/Dent Repair[*]Passport 8500ci Plus[*]Minor Maintanence[*]Replace Rear Tyres (RE050A)[*]Detail, Paint Touch up and Opti Coat[*]GMG Lowering Springs[*]Dension 500S Bluetooth Unit[*]Replace TPMS Sensors[*]Replace CV Boot[*]Replace Transmission Sump Gasket & Oil (round 1)[*]Michelin Pilot Suport Sport Tyres[*]Replace CV Boot[*]Replacement set of OEM Wheels cheaper to buy second hand off Rennlist than get the curbing fixed locally![*]TPC DSC Unit third party PASM replacement, gives full dynamic range to PASM shocks, recommended for 997 PASM cars[*]Swap Wheels, install second TPMS[*]Wheel Alignment[*]Replace Transmission Sump Gasket & Oil (round 2)[*]Wheel Alignment[*]Transmission Connector/Plug Repair (round 3, proper fix by auto trans)[*]Aero Front Lips x 2[*]Magnetic Stone Guards[*]Major Maintenance[*]Plugs, Coils, Water Pump, Water Thermostat, Tandem Oil Pump, Castrol SRF, Exhaust Hardware, Rear Brake Pads[*]Torque Solutions Transmission Mount Inserts[*]Rennline Tuneable Engine Mounts[*]LED Interior Bulbs[*]Guibo/Flex Disc, Intake Hose[*]Coolant Line Repair
Man there's some messed up cars out there when you go looking! http://www.car-accidents.com/2007-au...911-crash.html
Dynamically, it's the best car I've ever driven. I wasn't once out of control on that run from Helena Bay Cafe. Next time I'll play rabbit
