Isudar Carplay for PCM 3.1
#856
Just wanted to drop in after 2-3 weeks of this guy and say my experience has been pretty great. Only issue - that isn't a huge one really - is the BT connection being lost and having to reconnect every so often. Really only if I haven't driven in a couple days. I work from home so that can happen in the week.
Otherwise, everything is working great.
I did notice there were some artifacts around UI elements in Carplay (most noticeable in Maps) which I initially just figured was how it would be. But my curiosity got the better of me and I tracked down some much better ribbon cables than the ones found on Amazon and replaced them all including the original factory ones - and display is crystal clear now.
50 Pin
30 Pin
Those have the "ears" and snapped right in much easier than the ones that shipped with the Isudar unit (even before I broke one haha) as well as the factory ones. Hope that can help some of yall having connectivity issues.
Cheers!
50 Pin
30 Pin
Cheers!
aenemated (03-22-2022)
#857
Just an update here on an issue I've been experiencing with my Isudar installation. I reported earlier in the thread somewhere that the Isudar boards wifi has been hijacking my phone wifi connection when home. I use the term hijacking because even if my phone is connected to my home wifi, the phone gets bumped from that and connects to the car when parked in the garage and well after parking. Not sure why this happens, but it does. The only solution up until today to disconnect the phone from the car wifi, was to turn off the connection manually on my phone and then manually connect to home wifi. It was a true annoyance and somewhat disconcerting. Not sure what was happening to any security protocols. I have two other vehicles with wireless Carplay adapters - a 2018 Boxster GTS with PCM 4.0 native CarPlay and a 2017 Ram Limited in which I replaced the head unit with a later model that also has native wired CarPlay. Neither of these has ever had this issue. Each uses a different dongle for wireless. The Ram has a Carlinkit 2.0 and the Boxster has a CarPlay2Air dongle. I hooked each up to the USB cable that connects to the Isudar board without the Isudar wifi active and low and behold, each worked flawlessly. Actually the Carlinkit has better rendering of the interface - seems a bit sharper - than both the Isudar or with the CarPlay2Air dongle attached. The Carplay2Air dongle works fine in my Boxster, so I just ordered a Carlinkit 3.0 for my Ram and I'm leaving well enough alone in the 911.
#858
#859
Based on conversations here in the past the iSudar board is transmitting WiFi for at least 30 minutes after shutting down the car. In my case this isn't an issue as I live in a Condo building and the garage is underground, so I when I get to my apartment I am connected to my home WiFi. The solution for you might be to manually select your home WiFi I guess. As I remarked earlier, this has been brought up multiple times, but I fail to recall if a viable solution from the company was ever provided.
BW369 (03-23-2022)
#860
I posted a solution. I deleted the Isudar wifi credentials from my phone and hooked up a Carlinkit dongle. They're 85 bucks on amazon right now. I'm GTG. Works just like native Carplay. The Isudar board was an easier install that the others that require their own housing. That's about all the good I can say other than it works now as it should.
Edit: I found this Carlinkit 3.0 on Amazon - https://amzn.to/3JC9vQC
Live Steam (04-01-2022)
#862
#863
Android Auto issue possible solution
Android phone (not sure if iPhone has something similar) I found that if you go to settings / android auto/ there is an entry that you can deactivate called "automatically starts media". I did it and didn't lost connection since. I noticed that my disconnections were related to some activities happening in the phone. I have the original fw and I was going to try the update route when I realized that this does the trick for now. It has been a week and everything is stable.
kludger (04-02-2022)
#864
Isuda board went bad?
Installed and the board was working nicely for 2 weeks then went black. I opened the PCM and reseat all ribbon cables but still not working.
Removed the board and PCM works fine - is the board fried now? I searched the forum and haven't seen any case like this..
Just sent a message to Isudar support for help; has anyone done the replacement?
-andy
-andy
ralpheickhof (09-11-2022)
#865
I have the same issue, mine failed on the 24th February after 4 months!
I'm currently in the process of dealing with Kimi @ Isudar support but it seems that nothing happens quickly, i keep getting replies asking me to provide video's of the fault, current software and hardware versions and telling me that the most likely cause is poor ribbon cable connections, even though I've told them on numerous occasions that it was working fine, and just stopped working one day while i was driving. I've also explained that I've checked and double checked all connections, and have finally removed the board so that my PCM works!!
I'd guess you are now in for the same uphill struggle!
Good luck
Good luck
#866
Good luck
Good luck
I CAN'T SHOW YOU A VIDEO OF IT MALFUNCTIONING BECAUSE IT WON'T EVEN FRICKIN' TURN ON. YOU WANT A VIDEO OF A BLANK SCREEN, SERIOUSLY?
I'm not SAYING you should commit fraud, buuuut...
That's the kind of customer service that makes people just buy a second unit, and then swap the broken unit into the new box and say, "IDK what happened, it was broken when I took it out of the box. Please refund my money..."
